[ACPI Issue] XP on Panasonic Cf-54
Dear Friends,
i like to run win Xp on a Panasonic cf-54 MK2 with i5-6300U
I have an Image with XP but i have the problem with the ACPI 05a failure during booting,
the Image i have is run before on a Dell E6340, I can run the HDD every time back on the Dell, is there any solution to remove the ACPI failure without new Installation?
best regards
@kiranabc
Welcome to the Win-RAID Forum!
Since your ACPI problem cannot be solved by a BIOS modification, I have moved your request into the XP Sub-Forum and customized the thread title.
What you need to load/integrate is an ACPI driver, which is compatible with your modern Panasonic device.
Good luck!
Dieter (alias Fernando)
Unless you absolutely need Skylake’s performance, get yourself a used CF-19 Mk7 or CF-31 Mk3/Mk4 instead. They’re cheap as shit these days and support XP natively.
Or if you insist on using XP on that 54: you need a modified acpi.sys
Dear Friends,
the xp starts
Many thanks for the help
but i need a driver for the lan and wlan,
i have an HDD with Win 7 32 bit and all work there,
how can i use the win 7 driver under XP, maybe somebody know it
best regards
WLAN support is going to be impossible under XP without swapping the module itself. And I can’t seem to think of any M.2 NGFF WLAN cards that support XP.
