Wrong place to ask i know. But, are AMD vBIOS GOP’s universal?
Will the included work on mobile APU’s (A10 4600M or A10 5750M)
I have searched everywhere and cant seem to find the answer or an up to date mobile GOP.
Edit: I had a look a couple of pages back, does this mean that i may be able to update the AMD GOP from a laptop with this tool?
Obviously not designed for mobile BIOSes I know
[Tool] “UEFI BIOS Updater” (UBU) (82)
@ clackersx:
Welcome at Win-RAID Forum!
I am sorry, but your questions should be answered by one of our experts with this sort of BIOS modding…
Regards
Fernando
I insert marvell EFI sata driver in UBU… ASROCK x79 fatalty professenal.
ilke this but
marv_ahci_43.ffs
marv_ahci_491.ffs
marv_raid_492.ffs
marv_raid_a2.ffs
all of above do not make diffrence…
not enough just insert.
if there is DEVID inside ffs… and matched divece in mainboard? right??
i need to modifing FSS?
Thanks for the welcome.
Ill start a thread about it later.
The laptop is using a bios version newer than what is listed and when trying to run any software to backup it just gives me a write protected error and exits.
- UBU package was not created only for use with laptops. All modules are oriented only to work with desktop motherboards and not with laptops.
2) All modules in the package UBU, designed to update only available in the BIOS. If there are no modules in the BIOS, and you try to integrate both new and there is no guarantee that this update will work. In most cases, this updating does not work.
Is your board ASRock X79 Fatal1ty Pro with latest 3.10 BIOS? Because I see it has an EFI driver named Marvell_9172_9182_DXE that should at least make the controller visible. At first I thought that maybe your board is not fully OSX compatible, but your picture from the next message shows that the Sandisk is missing even in BIOS, so there’s the problem. Not sure if it is easy to fix this on your own. Have you tried to ask Asrock for a beta BIOS with Marvell UEFI support? They usually are helpful.
I can only think of adding the files attached. They come from an Asrock board. But there are some problems:
- the board was a server one. They probably used different sources. The Marvell AHCI and RAID are provided by Marvell, but Marvell9172DXE is provided by AMI.
- it was built on AptioV, while your board is Aptio4. They definitely used different sources. Again, Marvell9172DXE is the question.
- the dependencies from the files might not be satisfied by your board’s UEFI. But, from what I see, Marvell9172DXE follows PciRootBridge and the other two need Marvell9172DXE.
- don’t know if you should replace Marvell_9172_9182_DXE with Marvell9172DXE or add Marvell9172DXE on its own. Maybe try both ways and add each time the other two files.
- the files are uncompressed, so compress them while inserting.
Given the above problems, I can only provide the files and assistance, but there is no way I can guarantee the safety of your hardware. It is your risk.
Asrock_X79_Marvell.rar (124 KB)
Guys, I try to help as much as I can, but this is not the way to go. I don’t have a magical crystal to read your hardware. If you don’t know a thing (we are all clueless concerning 99% of the things surrounding us), then try to add as much related details as possible. This is what I had to do: check A10 4600, it has HD 7660G GPU, probably 1002-9900 ID; check A10 5750M, it has HD 8650G GPU, probably 1002-990B ID. Too many guesses when the user could just provide :
- the system used. Not really important, but it might come in handy when BIOS related problems arise
- the component in question. If you ask about GPU, then GPU I need, not CPU, RAM or else. Important!
- the ID of the component. Crucial!
- other related details. Full picture of the problem.
Anyway, since this might concern other users, I will look away this time. Here is the list of supported hardware in GOP 1.54.0.0.0:
CARRIZO 9870
MULLINS
AMD Radeon XX-2200M with R2
AMD Radeon R2 Graphics
AMD Radeon R6 Graphics
AMD Radeon R3 Graphics
TONGA
AMD FirePro W-8100
TONGA XT
TOPAZ
TOPAZ LE
TOPAZ XTL
AMD Radeon R7 M255
Cipher
THEBE-J
MAUII
MAUII XT
HAWAII
HAWAII LE
HAWAII PRO
VESUVIUS
HAWAII XT
HAWAII GL Gemini
HAWAII GL40
HAWAII XTGL
BONAIRE
AMD Radeon R7 200
BONAIRE PRO
BONAIRE XT
BONAIRE GL PRO
AMD Radeon R9 M270X
AMD Radeon R9 M280X
SATURN PRO
AMD Radeon HD 8950
KALINDI
DT 2C (N-1)
DT 4C (N-1)
AMD Radeon HD 8250
DT 2C
DT 4C
TM EMB 2C
AMD Radeon HD 8180
AMD Radeon HD 8240
AMD Radeon HD 8280E
AMD Radeon HD 8280
AMD Radeon HD 8210E
AMD Radeon HD 8210
AMD Radeon HD 8330E
AMD Radeon HD 8330
AMD Radeon HD 8400E
AMD Radeon HD 8400
KAVERI
KV SPECTRE EMBEDDED LITE
KV SPECTRE EMBEDDED 35W
KV SPECTRE SL EMBEDDED 17W
KV SPECTRE SL MOBILE 19W
KV SPOOKY MOBILE 35W
AMD Radeon R5 Series
KV SPOOKY DESKTOP 95W
KV SPECTRE WORKSTATION 100W
KV SPECTRE WORKSTATION 65W
AMD Radeon R7 Series
KV SPECTRE LITE MOBILE 35W
KV SPECTRE SL MOBILE 17W
KV SPECTRE LITE MOBILE 17W
KV SPECTRE LITE MOBILE 25W
KV SPECTRE SL DESKTOP 100W
KV SPECTRE SL MOBILE 35W
KV SPECTRE DESKTOP 100W
KV SPECTRE MOBILE 35W
SUN/JET
AMD Radeon R5 M200
AMD Radeon HD 8500M
AMD Radeon HD 8600M
OLAND/Mars
MARS64 LE
MARS64 PRO
MARS64 XT
OLAND PRO GL
AMD Radeon R5 M240
AMD Radeon HD 8790M
AMD Radeon R7 M260
AMD Radeon R7 M265
MARS LP
MARS XTX
AMD Radeon HD 8500M/8700M
AMD Radeon HD 8600/8700M
OLAND64 LE
AMD Radeon HD 8500
AMD Radeon HD 86002
VENUS PRO MCM
AMD Radeon E8860
AMD Radeon HD 8800M
AMD Radeon HD 7700
CAPE VERDE PRO
CAPE VERDE XT
CAPE VERDE XTX
AMD Radeon HD7700
AMD Radeon R7/HD 9000
AMD Radeon HD 7700M
AMD Radeon HD 7800M
WIMBLEDON GL
AMD Radeon HD8970M
AMD Radeon HD 7970M
AMD Radeon HD 7800
AMD Radeon R9 200
AMD FirePro V(FireGL V)
NEPTUNE
TAHITI CE
AMD Radeon HD 7800 Series
AMD Radeon HD 7900
Caicos/Seymour
AMD Radeon HD 6430M
AMD Radeon HD 7400M
AMD RADEON HD 6450
AMD Radeon HD 7000
AMD Radeon HD 7400A
AMD Radeon HD 8490
AMD Radeon HD 6400
AMD Radeon HD6460
Lombok/Thames
AMD Radeon HD 7000M
AMD Radeon HD 7500M/7600M
AMD Radeon HD 7600M
AMD Radeon HD 7400
Turks/Whistler/Onega
AMD Radeon HD 7670M
WHISTLER LP
AMD Mobility Radeon HD 6000
AMD Radeon E6760
AMD Radeon HD 7500/7600
AMD Radeon 6600M and 6700M
AMD Radeon HD 6700M
AMD Radeon HD 7500
AMD Radeon HD 7600
AMD Radeon HD 6600
AMD Radeon HD 7600A
AMD Radeon HD 6500
Barts/Blackcomb/Victoria
BLACKCOMB AIO
AMD Radeon HD 6900M
Cayman/Antilles
AMD Radeon HD 6900
AMD FirePro V (FireGL V)
AMD Radeon HD 7660
AMD Radeon HD 8550D
AMD Radeon HD 8650D
AMD Radeon HD 8310G
AMD Radeon HD 8410G
AMD Radeon HD 8510G
AMD Radeon HD 8370D
AMD Radeon HD 8350G
AMD Radeon HD 8470D
AMD Radeon HD 8450G
AMD Radeon HD 7400G
AMD Radeon HD 7480D
AMD Radeon HD 7420G
AMD Radeon HD 7540D
AMD Radeon HD 7520G
DVST
AMD Radeon HD 8610G
AMD Radeon HD 8570D
AMD Radeon HD 8550G
AMD Radeon HD 8670D
AMD Radeon HD 8650G
AMD Radeon HD 7500G
AMD Radeon HD 7600G
AMD Radeon HD 7620G
AMD FirePro A300 Series(FireGL V)
AMD Radeon HD 7560D
AMD Radeon HD 7640G
AMD Radeon HD 7660D
AMD Radeon HD 7660G
AMD Radeon HD 6300
AMD Radeon HD 7290
AMD Radeon HD 7310
AMD Radeon HD 7340
AMD Radeon HD 6290
AMD Radeon HD 6320
AMD Radeon HD 6250
AMD Radeon HD 6310
AMD Radeon HD 6550
SUMO 964F
SUMO 964E
AMD Radeon HD 6530D
AMD Radeon™ HD 6480G
AMD Radeon™ HD 6520G
AMD Radeon HD 6410D
AMD Radeon™ HD 6380G
AMD Radeon HD 6370D
AMD Radeon™ HD 6620G
AMD Radeon HD 6550D
PARK PRO/XT
AMD Radeon HD 6300M
AMD Radeon HD 7300
AMD Radeon HD 5450
EG CEDAR
AMD FirePro 2270
AMD FirePro (FireGL)
CEDAR XT GL
MADISON Pro
MADISON XT
AMD Mobility Radeon HD 5000
AMD Mobility Radeon HD 5570
EG REDWOOD
AMD Radeon HD 5500
AMD Radeon HD 5570
AMD Radeon HD 5670
AMD FirePro 3800 (FireGL)
AMD FirePro V4800 (FireGL)
BROADWAY Pro
AMD Mobility Radeon HD 6800
AMD Mobility Radeon HD 5800
AMD Radeon HD 6700
AMD Radeon HD 5600/5700
AMD Radeon HD 5700
AMD FirePro V5800 (FireGL)
LEXINGTON XT
EG LEXINGTON
AMD Radeon HD 5900
AMD Radeon HD 6800
AMD Radeon HD 5800
AMD FireStream 9350
AMD FireStream 9370
AMD FirePro V9800 (FireGL)
AMD FirePro V7800 (FireGL)
AMD FirePro V8800 (FireGL)
The names are not always helpful, so here is the list of IDs:
1002-6889
1002-688A
1002-688C
1002-688D
1002-6898
1002-6899
1002-689B
1002-689C
1002-689D
1002-689E
1002-6880
1002-6890
1002-68A9
1002-68B8
1002-68B9
1002-68BA
1002-68BE
1002-68BF
1002-68A0
1002-68A1
1002-68A8
1002-68B0
1002-68B1
1002-68C8
1002-68C9
1002-68D8
1002-68D9
1002-68DA
1002-68DE
1002-68C7
1002-68C0
1002-68C1
1002-68D0
1002-68D1
1002-68E8
1002-68E9
1002-68F2
1002-68F8
1002-68F9
1002-68FA
1002-68FE
1002-68E0
1002-68E1
1002-68E4
1002-68E5
1002-68F0
1002-68F1
1002-9640
1002-9641
1002-9642
1002-9643
1002-9644
1002-9645
1002-9647
1002-9648
1002-9649
1002-9648
1002-964A
1002-964E
1002-964F
1002-9802
1002-9803
1002-9804
1002-9805
1002-9806
1002-9807
1002-9808
1002-9809
1002-980A
1002-9900
1002-9901
1002-9903
1002-9904
1002-9905
1002-9906
1002-9907
1002-9908
1002-9909
1002-990A
1002-990B
1002-990C
1002-990D
1002-990E
1002-990F
1002-9910
1002-9911
1002-9912
1002-9913
1002-9914
1002-9915
1002-9916
1002-9917
1002-9918
1002-9919
1002-991A
1002-991B
1002-991C
1002-991D
1002-991E
1002-991F
1002-9990
1002-9991
1002-9992
1002-9993
1002-9994
1002-99A0
1002-99A2
1002-99A4
1002-9995
1002-9996
1002-9997
1002-9998
1002-9999
1002-999A
1002-999B
1002-999C
1002-999D
1002-6700
1002-6701
1002-6702
1002-6703
1002-6704
1002-6705
1002-6706
1002-6707
1002-6708
1002-6709
1002-6718
1002-6719
1002-671C
1002-671D
1002-671F
1002-6722
1002-6723
1002-6726
1002-6727
1002-6728
1002-6729
1002-6738
1002-6739
1002-673E
1002-6720
1002-6721
1002-6724
1002-6725
1002-6730
1002-6746
1002-6747
1002-6748
1002-6749
1002-674A
1002-6750
1002-6751
1002-6758
1002-6759
1002-675B
1002-675D
1002-675F
1002-6740
1002-6741
1002-6742
1002-6743
1002-6744
1002-6745
1002-6843
1002-6849
1002-6850
1002-6858
1002-6859
1002-6840
1002-6841
1002-6842
1002-6762
1002-6763
1002-6766
1002-6767
1002-6768
1002-6770
1002-6771
1002-6772
1002-6778
1002-6779
1002-677B
1002-6760
1002-6761
1002-6764
1002-6765
1002-6780
1002-6784
1002-6788
1002-678A
1002-6798
1002-6799
1002-679A
1002-679B
1002-679E
1002-679F
1002-6806
1002-6808
1002-6809
1002-6810
1002-6811
1002-6818
1002-6819
1002-684C
1002-6800
1002-6801
1002-6802
1002-6828
1002-682C
1002-6830
1002-6831
1002-6835
1002-6837
1002-6838
1002-6839
1002-683B
1002-683D
1002-683F
1002-6825
1002-6826
1002-6827
1002-682D
1002-682F
1002-6820
1002-6821
1002-6822
1002-6823
1002-682A
1002-682B
1002-6610
1002-6611
1002-6613
1002-6631
1002-6600
1002-6601
1002-6602
1002-6603
1002-6604
1002-6605
1002-6606
1002-6607
1002-6608
1002-6620
1002-6621
1002-6623
1002-6660
1002-6663
1002-6664
1002-6665
1002-6667
1002-666F
1002-1304
1002-1305
1002-1306
1002-1307
1002-1309
1002-130A
1002-130B
1002-130C
1002-130D
1002-130E
1002-130F
1002-1310
1002-1311
1002-1312
1002-1313
1002-1315
1002-1316
1002-1317
1002-1318
1002-131B
1002-131C
1002-131D
1002-9830
1002-9831
1002-9832
1002-9833
1002-9834
1002-9835
1002-9836
1002-9837
1002-9838
1002-9839
1002-983A
1002-983B
1002-983C
1002-983D
1002-983E
1002-983F
1002-6640
1002-6641
1002-6646
1002-6647
1002-6649
1002-6650
1002-6651
1002-6658
1002-665C
1002-665D
1002-67A0
1002-67A1
1002-67A2
1002-67B0
1002-67B1
1002-67B8
1002-67B9
1002-67BA
1002-67BE
1002-67E0
1002-9920
1002-9930
1002-154C
1002-6900
1002-6901
1002-6902
1002-6903
1002-6920
1002-692B
1002-692F
1002-6938
1002-6939
1002-9854
1002-9855
1002-9856
1002-9857
1002-9858
1002-9859
1002-985A
1002-985B
1002-985C
1002-985D
1002-985E
1002-985F
1002-9870
Here is for 1.55.0.0.0, names:
AMUR_NOLAN
AMUR 9890
CARRIZO
CARRIZO 9870
MULLINS
FIJI
FJII XT
TONGA
AMD FirePro W-8100
TONGA XT
TOPAZ
TOPAZ LE
TOPAZ XTL
AMD Radeon R7 M255
Cipher
THEBE-J
MAUII
MAUII XT
HAWAII
HAWAII LE
HAWAII PRO
VESUVIUS
HAWAII XT
HAWAII GL Gemini
HAWAII GL40
HAWAII XTGL
BONAIRE
AMD Radeon R7 200
BONAIRE PRO
BONAIRE XT
BONAIRE GL PRO
AMD Radeon R9 M270X
AMD Radeon R9 M280X
SATURN PRO
AMD Radeon HD 8950
KALINDI
DT 2C (N-1)
DT 4C (N-1)
AMD Radeon HD 8250
DT 2C
DT 4C
TM EMB 2C
AMD Radeon HD 8180
AMD Radeon HD 8240
AMD Radeon HD 8280E
AMD Radeon HD 8280
AMD Radeon HD 8210E
AMD Radeon HD 8210
AMD Radeon HD 8330E
AMD Radeon HD 8330
AMD Radeon HD 8400E
AMD Radeon HD 8400
KAVERI
KV SPECTRE WORKSTATION 95W
AMD Radeon R5 Graphics
AMD Radeon R4 Graphics
AMD Radeon R7 Graphics
KV SPECTRE SL DESKTOP 95W
KV SPECTRE DESKTOP 95W
SUN/JET
AMD Radeon R5 M200
AMD Radeon HD 8500M
AMD Radeon HD 8600M
OLAND/Mars
MARS64 LE
MARS64 PRO
MARS64 XT
AMD FirePro W2100
AMD Radeon R5 M240
AMD Radeon HD 8790M
AMD Radeon R7 M260
AMD Radeon R7 M265
MARS LP
MARS XTX
OLAND64 LE
AMD Radeon HD 8500
AMD Radeon HD 86002
VENUS PRO MCM
AMD Radeon E8860
AMD Radeon HD 8800M
AMD Radeon HD 7700
CAPE VERDE PRO
CAPE VERDE XT
CAPE VERDE XTX
AMD Radeon HD7700
AMD Radeon HD 7700M
AMD Radeon HD 7800M
AMD FirePro W4100
WIMBLEDON GL
AMD Radeon HD8970M
AMD Radeon HD 7970M
AMD Radeon HD 7800
AMD Radeon R9 200
NEPTUNE
TAHITI CE
AMD Radeon HD 7900
Caicos/Seymour
AMD Radeon HD 6430M
AMD Radeon HD 7400M
AMD RADEON HD 6450
AMD Radeon HD 7000
AMD Radeon HD 7400A
AMD Radeon HD 8490
AMD Radeon HD 6400
AMD Radeon HD6460
Lombok/Thames
AMD Radeon HD 7000M
AMD Radeon HD 7600M
AMD Radeon HD 7400
AMD Radeon HD 7670M
WHISTLER LP
AMD Radeon E6760
AMD Radeon HD 6700M
AMD Radeon HD 7500
AMD Radeon HD 7600
AMD Radeon HD 6600
AMD Radeon HD 7600A
AMD Radeon HD 6500
BLACKCOMB AIO
AMD Radeon HD 6900M
Cayman/Antilles
AMD Radeon HD 6900
AMD Radeon HD 7660
AMD Radeon HD 8550D
AMD Radeon HD 8650D
AMD Radeon HD 8310G
AMD Radeon HD 8410G
AMD Radeon HD 8510G
AMD Radeon HD 8370D
AMD Radeon HD 8350G
AMD Radeon HD 8470D
AMD Radeon HD 8450G
AMD Radeon HD 7400G
AMD Radeon HD 7480D
AMD Radeon HD 7420G
AMD Radeon HD 7540D
AMD Radeon HD 7520G
DVST
AMD Radeon HD 8610G
AMD Radeon HD 8570D
AMD Radeon HD 8550G
AMD Radeon HD 8670D
AMD Radeon HD 8650G
AMD Radeon HD 7500G
AMD Radeon HD 7600G
AMD Radeon HD 7620G
AMD Radeon HD 7560D
AMD Radeon HD 7640G
AMD Radeon HD 7660D
AMD Radeon HD 7660G
AMD Radeon HD 6300
AMD Radeon HD 7290
AMD Radeon HD 7310
AMD Radeon HD 7340
AMD Radeon HD 6290
AMD Radeon HD 6320
AMD Radeon HD 6250
AMD Radeon HD 6310
AMD Radeon HD 6550
SUMO 964F
SUMO 964E
AMD Radeon HD 6530D
AMD Radeon HD 6410D
AMD Radeon HD 6370D
AMD Radeon HD 6550D
PARK PRO/XT
AMD Radeon HD 6300M
AMD Radeon HD 7300
AMD Radeon HD 5450
EG CEDAR
AMD FirePro 2270
CEDAR XT GL
MADISON Pro
MADISON XT
EG REDWOOD
AMD Radeon HD 5500
AMD Radeon HD 5570
AMD Radeon HD 5670
BROADWAY Pro
AMD Radeon HD 6700
AMD Radeon HD 5700
LEXINGTON XT
EG LEXINGTON
AMD Radeon HD 5900
AMD Radeon HD 6800
AMD Radeon HD 5800
AMD FireStream 9350
AMD FireStream 9370
and IDs:
1002-6889
1002-688A
1002-688C
1002-688D
1002-6898
1002-6899
1002-689B
1002-689C
1002-689D
1002-689E
1002-6880
1002-6890
1002-68A9
1002-68B8
1002-68B9
1002-68BA
1002-68BE
1002-68BF
1002-68A0
1002-68A1
1002-68A8
1002-68B0
1002-68B1
1002-68C8
1002-68C9
1002-68D8
1002-68D9
1002-68DA
1002-68DE
1002-68C7
1002-68C0
1002-68C1
1002-68D0
1002-68D1
1002-68E8
1002-68E9
1002-68F2
1002-68F8
1002-68F9
1002-68FA
1002-68FE
1002-68E0
1002-68E1
1002-68E4
1002-68E5
1002-68F0
1002-68F1
1002-9640
1002-9641
1002-9642
1002-9643
1002-9644
1002-9645
1002-9647
1002-9648
1002-9649
1002-9648
1002-964A
1002-964E
1002-964F
1002-9802
1002-9803
1002-9804
1002-9805
1002-9806
1002-9807
1002-9808
1002-9809
1002-980A
1002-9900
1002-9901
1002-9903
1002-9904
1002-9905
1002-9906
1002-9907
1002-9908
1002-9909
1002-990A
1002-990B
1002-990C
1002-990D
1002-990E
1002-990F
1002-9910
1002-9911
1002-9912
1002-9913
1002-9914
1002-9915
1002-9916
1002-9917
1002-9918
1002-9919
1002-991A
1002-991B
1002-991C
1002-991D
1002-991E
1002-991F
1002-9990
1002-9991
1002-9992
1002-9993
1002-9994
1002-99A0
1002-99A2
1002-99A4
1002-9995
1002-9996
1002-9997
1002-9998
1002-9999
1002-999A
1002-999B
1002-999C
1002-999D
1002-6700
1002-6701
1002-6702
1002-6703
1002-6704
1002-6705
1002-6706
1002-6707
1002-6708
1002-6709
1002-6718
1002-6719
1002-671C
1002-671D
1002-671F
1002-6722
1002-6723
1002-6726
1002-6727
1002-6728
1002-6729
1002-6738
1002-6739
1002-673E
1002-6720
1002-6721
1002-6724
1002-6725
1002-6730
1002-6746
1002-6747
1002-6748
1002-6749
1002-674A
1002-6750
1002-6751
1002-6758
1002-6759
1002-675B
1002-675D
1002-675F
1002-6740
1002-6741
1002-6742
1002-6743
1002-6744
1002-6745
1002-6843
1002-6849
1002-6850
1002-6858
1002-6859
1002-6840
1002-6841
1002-6842
1002-6762
1002-6763
1002-6766
1002-6767
1002-6768
1002-6770
1002-6771
1002-6772
1002-6778
1002-6779
1002-677B
1002-6760
1002-6761
1002-6764
1002-6765
1002-6780
1002-6784
1002-6788
1002-678A
1002-6798
1002-6799
1002-679A
1002-679B
1002-679E
1002-679F
1002-6806
1002-6808
1002-6809
1002-6810
1002-6811
1002-6818
1002-6819
1002-684C
1002-6800
1002-6801
1002-6802
1002-6828
1002-682C
1002-6830
1002-6831
1002-6835
1002-6837
1002-6838
1002-6839
1002-683B
1002-683D
1002-683F
1002-6825
1002-6826
1002-6827
1002-682D
1002-682F
1002-6820
1002-6821
1002-6822
1002-6823
1002-682A
1002-682B
1002-6610
1002-6611
1002-6613
1002-6631
1002-6600
1002-6601
1002-6602
1002-6603
1002-6604
1002-6605
1002-6606
1002-6607
1002-6608
1002-6620
1002-6621
1002-6623
1002-6660
1002-6663
1002-6664
1002-6665
1002-6667
1002-666F
1002-1304
1002-1305
1002-1306
1002-1307
1002-1309
1002-130A
1002-130B
1002-130C
1002-130D
1002-130E
1002-130F
1002-1310
1002-1311
1002-1312
1002-1313
1002-1315
1002-1316
1002-1317
1002-1318
1002-131B
1002-131C
1002-131D
1002-9830
1002-9831
1002-9832
1002-9833
1002-9834
1002-9835
1002-9836
1002-9837
1002-9838
1002-9839
1002-983A
1002-983B
1002-983C
1002-983D
1002-983E
1002-983F
1002-6640
1002-6641
1002-6646
1002-6647
1002-6649
1002-6650
1002-6651
1002-6658
1002-665C
1002-665D
1002-67A0
1002-67A1
1002-67A2
1002-67B0
1002-67B1
1002-67B8
1002-67B9
1002-67BA
1002-67BE
1002-67E0
1002-9920
1002-9930
1002-154C
1002-6900
1002-6901
1002-6902
1002-6903
1002-6920
1002-692B
1002-692F
1002-6938
1002-6939
1002-7320
1002-9854
1002-9855
1002-9856
1002-9857
1002-9858
1002-9859
1002-985A
1002-985B
1002-985C
1002-985D
1002-985E
1002-985F
1002-9870
1002-9890
1002-98C0
And no, it was not as easy as copy-paste. The ID’s and names are disassembled from the GOP.
I have a UX31A ultrabook. Is this tool also safe to mod the bios for this ultrabook? I am able to run on the updates but I’m a little hesitant to flash the bios since the ultrabook is out of warranty.
Please backread a few posts above: [Tool] "UEFI BIOS Updater" (UBU) (85)
Thank you. for information.
i trying both… inserting and replacing… DEX…
inserting do not make any diffrence
replacing make boot failure. in this case…not even scan marvell divice.
i can not enter cmos. error ocurred befoer bios logo… error code 0d
’0d Problem related to memory, VGA card or other devices. Please clear CMOS, re-install the memory and VGA card, and remove other USB, PCI devices.’
so now i reinstall stock bios and i ask about this to ‘[email protected]’.
I hope you recovered to a working state. This is a good report on NOT to change OEM compiled files. It shouldn’t be too hard for Asrock to add them in the UEFI firmware, the Marvell EFI drivers are already out there. Please report back if they do it, I’m curious to see if their support is really up to it.
Hello, how to get the bios in the picture have to do?
http://www.xtremeshack.com/image/236149.html#
If the process is difficult to tell me … tactfully !!
When I saw this screenshot I’m loving it.
N.B.
Sorry for the English but not speak it very well!
If you have a Z77 machine as your signature suggests then you already have a UEFI motherboard (with similar looks). Other than that, the specific look & feel of the interface has to do with the OEM. You can’t do anything for that.
It is similar, but obviously the icons and background are different.
Too bad, it will mean that I will have to do with reason.
Anyway thanks for the answer!
Hello Cesco, the UEFI GUI that you like so much is from an ASRock Z77 OC Formula.
This is not UBU business, but what Cesco81 needs to change is this:
to this:
Which will look strange with that background around icons. There are at least 78 images in Z77 E6 and 91 in Z77 OCF.
Even if he fixes that, he has a long way to go, since Asrock, unlike Asus, is using a separation between images.
There are tree false positives. The above search was done with the help of UEFIFind
Processor Microcode Data File 20150107
http://downloadmirror.intel.com/24616/en…de-20150107.tgz
In this case, you can download the computer driver on official website to solve your problems if you know the details about your computer or other devices. However, this is not the best way for someone for the driver can not be found on its official website or it will take you much time doing that. You can try [Link deleted by Fernando] which helps me solve my driver problem before. I think it is an useful one. Just have a try.
What are all the command line arguments needed to use UEFIFind?
How did you do these searches???
