Aspire VN7-591G bios extract i need raw format for eeprom programmer
Hello i have Aspire VN7-591G and i need bios extract raw format for eeprom programmer
Bios from official website
Official website
i try extract *.fd with 7zip bios file extracted with 7zip
and i try extract from *.fd my try
can help me someone what is correct raw format for eeprom programmer ?
Thanks Steve.
Cut all after 0x8DE8F0, then cut all from 0x0 to 0xDE8F0 OR Cut all from 0x0 to 0xDE8F0, then cut all from 0x800000.
File should be exactly 8388608 bytes
Beginning:
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
5AA5F00F030004020602101520012100
End
4210F0FFEBFECF000000000000000000
9090E95BF8000000785634120000F0FF
Check result with UEFItoolNE and Hexeditor
Dump your bricked bios before overwrting it…
Thanks
extracted bios:Aspire VN7-591G bios raw
file have 8 388 608 bytes
