AsRock 990FX Extreme 9 Raid 0
Currently using AMD Raid Driver v3.8.1540.14 -DEV_4393 on AsRock990fx Extreme 9 floating on Windows 8 Pro x64 in Raid 0.
Working great so far I will update at the end of the week.
Thanks for providing updated driver’s as they can be a pain to find even if found at all.
@ Primordial:
Welcome at Win-RAID Forum and thank you for your feedback!
Regards
Fernando
I know I had said I would update at the end of the week but I can’t wait to report my findings. So far there are no hick-ups when playing games or running guitar rig. I will update on Friday as I had said still once I run my pc under normal operation.
I’m happy to report the drivers are working fine. I did and I place update to windows 8 pro x64 tested all day Friday and decided to do another I place update to windows 8.1 pro and so far it is working also. I will be upgrading hardware on a per month basis but still keeping the AsRock board. I will update as needed on the changes. Thanks again for your hard work and providing an very valuable resource for enthusiasts to test .
