Hi guys. I have a problem with an Asrock IMB150 (J1900)
I made a wrong update (batch programming error), and update the bios with another motherboard bios.
Now, I recovered the IMB150 with hot flash from another identical Asrock IMB150 (I work with these cards).
The problem is that after this, the death mobo is operating normally, windows too, but I have issue with screen. (similar to the picture, my screen looks better however)
The driver is NOT the problem. The same HDD with Windows 8 works without problems on second mobo.
The bios chip is NOT the problem. On the second mobo works withouth problems.
When I made the wrong bios flash, I used
afudose IMB1501.50D /p /b /n /x
Then, when I recovered the bios with hot flash, I flash the correct bios in the same way. I have tried to flash in different ways, but the problem remains.
I get unrecognized command when i run the whole bios flash in this way. (afudos command)
afudos IMB1501.50D /P /B /N /C /E /K
If I remember correct, I was able to run afudos with /E parameters, but not with /C. However I made different CMOS with jumpers and putting out the battery.
The Intel ME can be the problem? Any suggest?
Thanks
