Hi!
My HTPC has an ASUS E45M1-I Deluxe mainboard. I updated the AMD RAID ROM from version 3.2 to 3.3.1540.19.
There is also a VBIOS but without GOP driver. The BIOS has no “Fast Boot Mode” setting, too.
Even more interesting, it has no AHCI ROM, only a RAID ROM. But this board doesn’t even support RAID configurations.
Is it possible to insert a GOP driver?
Is the AMD GOP driver that comes with UBU an universial binary?
Would the insertion of a GOP driver bring some benefits even for a mainboard without “Ultra Fast Boot Mode” support?
Here is the output of UBU:
2
3
4
5
6
7
8
Scanning BIOS... Please wait...
Platform BIOS AMI Aptio 4
Brand ASUSTeK COMPUTER INC.
Found Option ROM in GUID A062CF1F-8473-4AA3-8793-600BC4FFE9A8
Extract OROM
Found EFI AMD AGESA GUID 6950AFFF-6EE3-11DD-AD8B-0800200C9A66
Found OROM-in-EFI AMD RAID MISC.SIG GUID 9BD5C81D-096C-4625-A08B-405F78FE0CFC
Found OROM-in-EFI AMD RAID MISC.SIG GUID 9BD5C81D-096C-4625-A08B-405F78FE0CFD
2
3
4
5
6
7
8
9
10
11
12
13
1 AMD OROM and EFI Nodules
OROM AMD RAID MISC 4392 - 3.3.1540.19
EFI AMD RAID - Not present
2 AMD OROM VBIOS and EFI GOP Driver
OROM VBIOS AMD - 012.036.000.009.000000
EFI GOP Driver - Not present
3 LAN OROM PXE and EFI UNDI - Intel, Realtek, BCM, QCA
OROM Realtek Boot Agent - 2.61
AMD AGESA CPU Support
EFI AMD AGESA OntaroPI - 1.0.9.0
9 Look the Version of all UBU modules in VerDID.txt
0 Exit
Press ENTER - Re-Scanning ALL EFI modules.
Best regards,
mr_nuub
EDIT: If I select 5 to auto-update the OROMs, only the one with GUID ending in "FC" gets updated.
As you can see above, there is also also a GUID ending with "FD".
2
3
4
5
6
7
8
9
10
11
1 - Update to v3.3.1540.19 RAID OROM
5 - Update all modules
0 - Exit Main Menu
Enter number:5
* Update OROM AND RAID Device ID 4392 ...Ok!
* Update EFI AND MISC 4393_FC.ffs GUID 9BD5C81D-...-FC -...Ok!
