The ASUS Flash Utility v1.13 for WinPE (x86/x64) can flash locked? bioses / extraced bodys / modified BIOS even in no PE but regular W10 environment.
Seems also that the /gan command is back. Flased my Z170 PRO GAMING successfully under regular W10 via cmd: wAsusFUX64.exe modified.rom /gan .
I don´t know if thats already known to the public, fyi.
Regards, Ingo
Post the file, and thanks for sharing info!
Can we use it to flash modded BIOS?
Any download link? Thx
I am not sure if this is a file
source:
http://drivers.stonegroup.co.uk/ftp/Bios…%20Intel/Tools/
AsusFlashUtility v113.rar (132 KB)
So I just tried running this, and keep getting an ‘input parameters error’ on my screen…
Show screen with input and error visible, then maybe we can help figure out the issue. Did you try both versions? What /flags if any are you using?
I’ve not seen much luck with this either, I think it’s only for certain series BIOS? Maybe @IngoPan knows more info?
