Hello,
I’m having some problems enabling \ something with dci.
my setup is as follows.
I got an asus h110m-k with the following changes made using AMIBCP
I enabled “DCI enable (HDCIEN)”, “DCI Auto Detect Enable”, changed “USB/UART” to USB,
enabled "Debug Interface ", “Direct Connect Interface”, and disabled "Debug Interface Lock ".
I also changed the trace hub to “host debugger” as I read somewhere I should try doing that.
I can see Intel USB Native Debug Class Devices on usbview and on device manager.
but sadly when I run DAL can’t see my CPU and getting the following output:
2
3
4
5
6
7
8
9
10
Using Intel DAL 1.1839.428.100
Using python.exe 2.7.15 (64bit), .NET 2.0.50727.8937, Python.NET 2.0.19, pyreadline 2.1.1
DCI: A DCI device has been detected, attempting to establish connection
DCI: Target connection has been fully established
Target Configuration: KBL_SPT_OpenDCI_DBC_Only_ReferenceSettings
Note: Target reset has occurred
Note: Power Restore occurred
Note: No devices found to initialize control variables
Warn: Cores previously specified in the 'coregroups' control variable are no longer present(may have been powered off?).
Using KBL_SPT_OpenDCI_DBC_Only_ReferenceSettings
Does anyone know what else I should try? or something?
Thanks!
