Bios downgrade without TPM key reset
Hi,
I am trying to solve the problem with Lenovo Yoga 700 14isk BIOS update. It was accidentally flashed to a newest firmware but without Bitlocker suspending. After that, OS found BIOS version change and wants recovery keys instead of taking it from TPM module. Unfortunately a pendrive with restore keys was lost, so the only chance is to downgrade the BIOS. It’s based on Phoenix.
I run the OS from external HDD and tried to downgrade it, but it shows warning that downgrade will cause TPM module clear. This notebook has Intel PTT enabled, so the decryption keys are wrote somewhere at Intel’s chip.
I created bootable DOS usb, but I didn’t try to flash it by DOS tool, because I am not sure which options should be marked.
I am attaching unpacked BIOS images (newest and previous) in CAP container with dedicated flash tools.
https://1drv.ms/f/s!AhSrYdRl4bnajUJl1KsXDmq_goKS
I spent a few days trying to find a solution, but I got nothing. So maybe someone from this forum could help me?
Any ideas how to flash it without TPM clear?
Thanks for help!
@D3F :
TPM keys are expected to be lost on BIOS change. I am unaware of a way around it.
Assuming that you can boot into Windows, you should be able to export the BitLocker recovery key again:
https://www.tenforums.com/tutorials/3973…ndows-10-a.html
Do you use TPM for anything else?
TPM aren’t lost already. The status of TPM module shows that it’s owned by other system, so definitively it wasn’t cleared.
As I wrote I booted the other OS from different HDD, so I cannot export key or suspend Bitlocker.
I think that notebook doesn’t have external TPM chip, at all. It has only Intel’s Platform Trust Technology (PTT) which is compatible with TPM standard.
The key is stored inside of some memory in the chipset or flash chip (shares with BIOS).
So I need to know how to safely flash the bios without erasing TPM (or Intel PTT).
Bitlocker checks hardware changes during boot process. If I could recover the previous state it should let me in.
I think that Windows during booting with Bitlocker checks only Bios version or maybe checksum.
Down here I attach list of commands embedded with flasher.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
bak [filename] Backup BIOS ROM before flash.
bbl Flash boot block.
bcp [EVSA binary] Overwrite BCP data.
bcplogo [BCP name] [file name] [Image ID] Replace logo image stored in BCP.
cac Check AC power is on.
cbp threshold Check battery power in percentage.
cvar Clear variables.
dat string Specify the asset tag DMI string.
dmc string Specify the chassis manufacturer DMI string.
dmm string Specify the motherboard manufacturer DMI string.
dks string Specify the SKU number DMI string.
dms string Specify the system manufacturer DMI string.
dos [string;string2;...]|[index1 string1 ...] Specify the OEM DMI strings.
dpc string Specify the chassis asset tag number DMI string.
dpm string Specify the motherboard product ID DMI string.
dps string Specify the system product ID DMI string.
dsc string Specify the chassis serial number DMI string.
dsm string Specify the motherboard serial number DMI string.
dss string Specify the system serial number DMI string.
dus [uuid] [overwrite] Specify the UUID DMI string.
dvc string Specify the chassis version DMI string.
dvm string Specify the motherboard version DMI string.
dvs string Specify the system version DMI string.
endkey Required key press after flashing.
errorkey Required key press after flashing error.
ese Enable security examiner.
exit Exit program after flash completed.
file filename Indicate BIOS image file for flash.
help Show command list.
ipf [region name]|all Flash specific region
logo filename [ImageId] [filename] [ImageId] ... Replace logo.
ls [ImageId] ... Reserve logo in BIOS ROM.
mod filename Replace a FFS module.
nodelay No delay after flash.
nodrom No decomposing ROM when crisis recovery.
noerror Do not display error messages.
nowarn Do not display warning messages.
oc string Specify the OEM command line.
p Production mode. Disable simple text output.
prog start size Flash specific area. Both parameters in hexadecimal.
patch Patch mode. To patch particular data to current BIOS.
raw GUID filename [Index] Replace raw section of FFS module.
rsbr GUID1 GUID2 ... Reserve sub-regions with specified GUIDs.
sd Skip BIOS build date time checking.
silent Silent operation (no beeps).
slp filename Replace SLP marker or MSDM key.
spu filename 20|21 Replace SLP public key.
ss Skip all SLP sub-regions.
sn Skip part number checking.
shutdown Shutdown after flash completed instead of reboot.
v Enable flash verification.
vbl Enable Microsoft Bit-locker check.
vcpu [filename] Update variable size CPU microcode.
wb Flash without skipping same content blocks.
write filename start [fdla] Write a binary file to specific physical address or FDLA.
wsbr GUID filename Write a binary file to specific sub-region.
