Hi everyone so wondering if someone can help me either modding a bios or telling me how to disable the write protection for asus x99 ws/ipmi board, the main think i want is rebar running with this being a workstation board the adress space for an 8gb 3060ti should be perfect, i got the rebar modded in the bios but ez 2 flash says this isnt a valid bios now. do i have to use Bios Flashback, or can i just diable the bios check.
i will zip my modded bios and the stock bios
the other thing i was kind of wanting to try is realocation pcie allocation
for example the main slot on this board is slot 2 and if i use slot 1 it turns slot 2 into x8 pcie 3.0 id like for that to not happen as id only be using 4 lanes off the top slot and 1 lane on another slot the card is deshrouded so it eats up alot of slots and cooling is hurt when using the second last slot.
ideally id like to have this order
slot 1 as 4/8 only wired for 8x
slot 2 as always 16x
slot 3 as 8/16
slot 4 doesnt matter
slot 5 4/8
i dont know if that is doable but would be nice if it is or if someone can tell me how to arrange the lane allocation. but my main thing right now is getting rebar working
Well cant upload files
ill send the link to it i am running 4001
