Bricked h110m-hdv r3.0
Hello,
I have an ASRock H110M-HDV R3.0 (please confirm exact rev printed on PCB) whose BIOS was erased. I need a FULL SPI image (including Flash Descriptor, ME region and BIOS) dumped from a working H110M-HDV R3.0 board (same PCB revision). I have a CH341A and can program the chip myself.
Board details:
- Model: ASRock H110M-HDV R3.0
- PCB rev (printed on PCB): ______
- My backup (made with AFUDOS) contains only BIOS region so board won’t boot.
Please only post/send images from identical rev boards.
Thank you!
Why do you need a bios dump of this motherboard, if the support page presents a full image on their bios files???
So please help me figure out what happened to my computer. I modified the BIOS by adding the microcode for the i5-9400F. My original CPU is the i3-7100. Everything worked fine, I flashed the modified BIOS and continued using the i3-7100 until today when I bought the i5-9400F and decided to install it.
When I tried to start the PC, the LEDs turned on for 1 second and then it shut down immediately. I put back the i3-7100, but this time there was no video output. I assumed the BIOS got corrupted after trying to boot with the i5-9400F.
I erased the BIOS chip, and when I try to reflash it with the backup, it says: “chip main memory with the contents are in disagreement.”, solved this issue by erasing the chip but now there is not even a sign from my pc
I am using a CH341 programmer, but now the PC doesn’t react at all — when I press the power button nothing happens, not even the LED
s turn on.
idk if its the bios cuz i flashed 100 times different sources bioses of my mainboard, including the asrock official and nothing it just doesnt start, even removed other component from pc, ram procesor and still nothing
[Guide] CoffeeLake CPUs on Skylake and KabyLake mainboards - BIOS/UEFI Modding / BIOS Modding Guides and Problems - Win-Raid Forum
Skip to main content
Request FULL SPI dump (FD + ME + BIOS) for ASRock H110M-HDV R3.0 (rev 3.0)
BIOS/UEFI Modding
BIOS Modding/Flashing Tools
Do you want live notifications when people reply to your posts? Enable Notifications
BIOS/UEFI Modding
Mihail777md
16h
Hello,
Board details:
Thank you!
MeatWar
Moderator
16h
Mihail777md
7h
I wouldnt say that its the bios, cuz i reflashrd it more than 20 times with backups, oficial asrock bios and still nothing, all have me and other stuf
