Ch341a programming question
I’m trying to program my bricked board with this tool problem is my bios update file comes in the forum of a .cap file am I able to flash using this .cap file or does it need to be modded a certain way the file like converted ?
The extension is just a naming convention, but cap means often ‘capsule’ which has to be removed
Thank you I didn’t go this route my old ssd had a .rom file from when I did some afuwin serial changing and it worked beautifully my chip didn’t have support for the normal tools but I used neoprogrammer which seemed to pick it up really well went very good
