Cleaning ME - Boot Guard?
I am cleaning an Apple image following the guide. When I go to step 9 to build the image, a dialog pops up saying "Are you sure you want to choose the Boot Guard Profile: Boot Guard Profile 0 - No_FVME for this build.". How should I proceed? If I click no then it aborts.
Uncleaned bios image is attached. Thanks
A1418 UNCLEAN BIOS.zip (4.3 MB)
Yes you should proceed, the message is normal.
Thanks!
Please, tell me - is the clean bios work correct in your apple system?
