[[File:TIM??20200320134043.png|none|fullsize]]
Do you think it is possible to achieve mutual compatibility through MOD? If there are CPU pin definitions, I can do the test! Already bought the official version of i510400. Can’t find the CPU definition for the 10th generation motherboard, because it is not available yet!
Someone had put the new generation CPU into the 1150 mobo.Finally he burned his 3 mobos.
To make clear the definition of CPU pin, you can test it on the computer after modification. This interface is different, and the power supply is definitely different!
