Corrupt ME Region - No Display on HP ZBook Laptop
I’m getting error while opening in FIT Tool (Version: 12.0.70.1652)
Loading C:\Users\tyroa\Desktop\ME Tools\HP zbook\old_bios.BIN
Error 9: Failed to decompose Image.
Error 42: Failed to open with processed commands.
Unable to open file: C:\Users\tyroa\Desktop\ME Tools\HP zbook\old_bios.BIN. Reverting to default configuration.
Kindly help/guide me in fixing the ME region of this BIOS. Current situation of laptop is No Display.
Edit by Fernando: Thread moved into the “Intel ME” Category and title customized
@tyroafsal
Welcome to the Win-Raid Forum!
Your problem while trying to modify a BIOS file by using Intel’s Flash Image Tool may have been caused by the path to the file (too many characters and with a space within it). It is never a good idea to customize a BIOS from within a personal Windows folder.
I hope, that you will get help to get the Intel ME Region recovered.
Good luck!
Dear,
Thank you for your response. i have changed location and error Still exist.
Any other solution ?
ZBook model, mb model? Bios version? Shared dumps? The operation goal, cleaning CSME?
Laptop Model : HP ZBook Studio x360 G5 Convertible Workstation
Mother Board Model : DA0XW1MBAI1 REV: 1
BIOS Version : CSE ME (12.0.69.2562) Corporate H (B,A)
Problem : No Display
Operation Goal : Clean ME region of BIOS File (32MB)
You can use below link to download the downloaded bios file from laptop
BIOS File from Laptop
here already cleaned
Thank you. Will let it you know if it works.
Is it possible to explain, how you have overcome the FIT errors i have mentioned above?
if used another method, possible to explain how you have done the ME region cleaning ?
Thank you.
