Vcore requirements went down because you lost about 100 mhz worth of performance on Cinebench R20/R15 / LinX 0.9.6 (Gflops), etc. So of course vcore requirements will get lower when your CPU is running slower thanks to all the security stuff
No, theres no difference in performance here with CA vs some before it (C6, BA, etc), the voltage increase requirements started after 84 and were the same, till now. On this system anyway, went back and forth between mcodes, dfference is definitely there.
Hi,
I tested CA and C6 and both of them scored 2185 CB at 5 ghz consistently.
With BE and AE and A2 microcodes, I scored 2240. (5.1 ghz scores 2283 on this).
Anyway,
Someone actually used microcode 906EC "84" with a 9900k (P0 stepping)?
I have it but afraid to mod it into the BIOS because I donβt even know if it works (who actually tested that old microcode? You said you tested 84?)
And the vmware microcode windows loader (microcode cpu updater 2.1, with microcode.dat created with the famous "dat converter", with the older microcodes) wonβt run it because itβs older than the microcode in the BIOS. How did you manage to run it without modding it into your BIOS?
This old 9900k microcode required less voltage than newer ones?
906EA not 906EC, EA is 8700k. When i switched through mcodes to test i mod it into bios then flash with intel flash program tool, and disable OS microcode replacement temporarly.
