I am a PB70DF2 user. I7-10875H, 2070 super mobile are mounted, 230W adapter is provided.
I set IMON Slope to 50 and IMON Offset to 61999 in BIOS. This makes the CPU report the power consumption in half. Nevertheless, Power Limit Throttling inevitably occurs when I play the game.
When I do Cinebench and FireStrike physics test, my GPU goes into idle state, and Power Limit Throttling does not occur on the CPU.
If the temperature of the CPU does not exceed 98 degrees, my CPU can continue to consume more than 120W of power.
But the problem is the game. When I play, the GPU consumes 115W of power, and the CPU has Power Limit Throttling.
The method of maximizing Turbo Boost Short Power Max and Turbo Boost Long Power Max cannot eliminate Power Limit Throttling.
And how to manipulate IMON Slope and IMON Offset also couldn’t get rid of Power Limit Throttling.
The only way I could get rid of the Power Limit Throttling I found was to put the GPU into idle state.
But I am looking for another way. Can someone advise on this?
