Hi all. I’ve been overclocking my t5810 using throttle stop and I’ve hit some limits. I’ve went ahead and order a ch341a and a atx bench kit so I can take an old psu and use the 3.3v rail on it with the programmer since I’ve read there is an issue there. I’ve also managed to download amibcp although not sure if it’s what I need. I’ve attached a report from hwinfo64 and a picture of my bios chip. I got into intel ME to find that it is version 9.1.45.3000. so just looking for any and all software I’ll need to pull a bios dump, modify and flash the modded bios using the programmer and my laptop running win10.
Bios chip.
DESKTOP-BEJAHC2 -----------------------------------------------------------
[Current Computer]
Computer Name: DESKTOP-BEJAHC2
Computer Brand Name: DELL Precision Tower 5810
[Operating System]
Operating System: Microsoft Windows 10 Professional (x64) Build 18363.1316 (1909/November 2019 Update)
UEFI Boot: Present
Secure Boot: Present
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 6
Number Of Logical Processors: 12
Intel Xeon E5-1650 v3 -----------------------------------------------------
[General Information]
Processor Name: Intel Xeon E5-1650 v3
Original Processor Frequency: 3500.0 MHz
Original Processor Frequency [MHz]: 3500
CPU ID: 000306F2
CPU Brand Name: Intel(R) Xeon(R) CPU E5-1650 v3 @ 3.50GHz
CPU Vendor: GenuineIntel
CPU Stepping: R2
CPU Code Name: Haswell-EP WS
CPU Technology: 22 nm
CPU S-Spec: SR20J
CPU Thermal Design Power (TDP): 140.0 W
CPU Thermal Design Current (TDC): 208.0 A
CPU Power Limits (Max): Power = Unlimited, Time = Unlimited
CPU Power Limit 1 - Long Duration: Power = 140.00 W, Time = 10.00 sec [Unlocked]
CPU Power Limit 2 - Short Duration: Power = 168.00 W, Time = 7.81 ms [Unlocked]
Configurable TDP Level 1 (Down): 140.00 W (18.50 W - Unlimited), 3200 MHz
Current Configurable TDP Level: Nominal [Unlocked]
CPU Max. Junction Temperature (Tj,max): 95 °C
CPU Type: Production Unit
CPU Platform: Socket R3 (LGA2011-3)
Microcode Update Revision: 43
Number of CPU Cores: 6
Number of Logical CPUs: 12
[Operating Points]
CPU MFM (LowPower): 800.0 MHz = 8 x 100.0 MHz
CPU LFM (Minimum): 1200.0 MHz = 12 x 100.0 MHz
CPU HFM (Base): 3500.0 MHz = 35 x 100.0 MHz
CPU Turbo Max: 3800.0 MHz = 38 x 100.0 MHz [Unlocked]
Turbo Ratio Limits: 38x (1-2c), 36x (3-18c)
CPU Current: 3591.7 MHz = 36 x 99.8 MHz @ 1.0023 V
LLC/Ring Maximum: 3000.0 MHz = 30.00 x 100.0 MHz
LLC/Ring Current: 2993.1 MHz = 30.00 x 99.8 MHz
CPU Bus Type: Intel Direct Media Interface (DMI) v2.0
Maximum DMI Link Speed: 5.0 GT/s
Current DMI Link Speed: 5.0 GT/s
PCI-Express Current Clock: 99.8 MHz = 1.00 x 99.8 MHz
Number of Overclocking Bins: Unlimited
[IA Overclocking]
Voltage Offset: Supported
Voltage Override: Supported
Ratio Overclocking: Supported
Fused Ratio Limit: 80x
OC Ratio Limit: N/A
Voltage Mode: Adaptive
Voltage Offset: 0 mV
[CLR (CBo/LLC/Ring) Overclocking]
OC Ratio Limit: N/A
[Uncore/SA Overclocking]
Voltage Override: Not Supported
Ratio Overclocking: Not Supported
Fused Ratio Limit: N/A
OC Ratio Limit: N/A
[Cache and TLB]
L1 Cache: Instruction: 6 x 32 KBytes, Data: 6 x 32 KBytes
L2 Cache: Integrated: 6 x 256 KBytes
L3 Cache: 15 MBytes
Instruction TLB: 2MB/4MB Pages, Fully associative, 8 entries
Data TLB: 4 KB Pages, 4-way set associative, 64 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Present
Debug Trace and EMON Store Present
Internal ACPI Support Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Present
Streaming SIMD Extensions 2 Present
Self-Snoop Present
Multi-Threading Capable Present
Automatic Clock Control Present
IA-64 Processor Not Present
Signal Break on FERR Present
Virtual Machine Extensions (VMX) Present
Safer Mode Extensions (Intel TXT) Present
Streaming SIMD Extensions 3 Present
Supplemental Streaming SIMD Extensions 3 Present
Streaming SIMD Extensions 4.1 Present
Streaming SIMD Extensions 4.2 Present
AVX Support Present
Fused Multiply Add (FMA) Present
Carryless Multiplication (PCLMULQDQ)/GFMUL Present
CMPXCHG16B Support Present
MOVBE Instruction Present
POPCNT Instruction Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Present
XGETBV/XSETBV OS Enabled Present
Float16 Instructions Present
AES Cryptography Support Present
Random Number Read Instruction (RDRAND) Present
Extended xAPIC Present
MONITOR/MWAIT Support Present
Thermal Monitor 2 Present
Enhanced SpeedStep Technology Present
L1 Context ID Not Present
Send Task Priority Messages Disabling Present
Processor Context ID Present
Direct Cache Access Present
TSC-deadline Timer Present
Performance/Debug Capability MSR Present
IA32 Debug Interface Support Present
64-Bit Debug Store Present
CPL Qualified Debug Store Present
[Extended Feature Flags]
64-bit Extensions Present
RDTSCP and TSC_AUX Support Present
1 GB large page support Present
No Execute Present
SYSCALL/SYSRET Support Present
Bit Manipulation Instructions Set 1 Present
Bit Manipulation Instructions Set 2 Present
Advanced Vector Extensions 2 (AVX2) Present
Advanced Vector Extensions 512 (AVX-512) Not Present
AVX-512 Prefetch Instructions Not Present
AVX-512 Exponential and Reciprocal Instructions Not Present
AVX-512 Conflict Detection Instructions Not Present
AVX-512 Doubleword and Quadword Instructions Not Present
AVX-512 Byte and Word Instructions Not Present
AVX-512 Vector Length Extensions Not Present
AVX-512 52-bit Integer FMA Instructions Not Present
Secure Hash Algorithm (SHA) Extensions Not Present
Software Guard Extensions (SGX) Support Not Present
Supervisor Mode Execution Protection (SMEP) Present
Supervisor Mode Access Prevention (SMAP) Not Present
Hardware Lock Elision (HLE) Not Present
Restricted Transactional Memory (RTM) Not Present
Memory Protection Extensions (MPX) Not Present
Read/Write FS/GS Base Instructions Present
Enhanced Performance String Instruction Present
INVPCID Instruction Present
RDSEED Instruction Not Present
Multi-precision Add Carry Instructions (ADX) Not Present
PCOMMIT Instructions Not Present
CLFLUSHOPT Instructions Not Present
CLWB Instructions Not Present
TSC_THREAD_OFFSET Present
Platform Quality of Service Monitoring (PQM) Present
Platform Quality of Service Enforcement (PQE) Not Present
FPU Data Pointer updated only on x87 Exceptions Not Present
Deprecated FPU CS and FPU DS Present
Intel Processor Trace Not Present
PREFETCHWT1 Instruction Not Present
AVX-512 Vector Bit Manipulation Instructions Not Present
AVX-512 Vector Bit Manipulation Instructions 2 Not Present
AVX-512 Galois Fields New Instructions Not Present
AVX-512 Vector AES Not Present
AVX-512 Vector Neural Network Instructions Not Present
AVX-512 Bit Algorithms Not Present
AVX-512 Carry-Less Multiplication Quadword (VPCLMULQDQ) Not Present
AVX-512 Vector POPCNT (VPOPCNTD/VPOPCNTQ) Not Present
User-Mode Instruction Prevention Not Present
Protection Keys for User-mode Pages Not Present
OS Enabled Protection Keys Not Present
Wait and Pause Enhancements (WAITPKG) Not Present
Total Memory Encryption Not Present
Read Processor ID Not Present
Cache Line Demote Not Present
MOVDIRI: Direct Stores Not Present
MOVDIR64B: Direct Stores Not Present
ENQCMD: Enqueue Stores Not Present
SGX Launch Configuration Not Present
Control-Flow Enforcement Technology (CET) Shadow Stack Not Present
AVX-512 4 x Vector Neural Network Instructions Word Variable Precision Not Present
AVX-512 4 x Fused Multiply Accumulation Packed Single Precision Not Present
Fast Short REP MOV Not Present
AVX-512 VP2INTERSECT Support Not Present
MD_CLEAR Support Present
Hybrid Processor Not Present
Platform Configuration (PCONFIG) Not Present
Indirect Branch Restricted Speculation (IBRS), Indirect Branch Predictor Barrier (IBPB) Present
Single Thread Indirect Branch Predictors (STIBP) Present
L1D_FLUSH Support Present
IA32_ARCH_CAPABILITIES MSR Not Present
IA32_CORE_CAPABILITIES MSR Not Present
Speculative Store Bypass Disable (SSBD) Present
Control-Flow Enforcement Technology (CET) Indirect Branch Tracking Not Present
Advanced Matrix Extensions (AMX) Tile Architecture Not Present
Advanced Matrix Extensions (AMX) bfloat16 Support Not Present
Advanced Matrix Extensions (AMX) 8-bit Integer Operations Not Present
AVX-512 BFLOAT16 Instructions Not Present
[Enhanced Features]
Thermal Monitor 1: Supported, Enabled
Thermal Monitor 2: Supported, Enabled
Enhanced Intel SpeedStep (GV3): Supported, Enabled
Bi-directional PROCHOT#: Enabled
Extended Auto-HALT State C1E: Enabled
MLC Streamer Prefetcher Supported, Enabled
MLC Spatial Prefetcher Supported, Enabled
DCU Streamer Prefetcher Supported, Enabled
DCU IP Prefetcher Supported, Enabled
Intel Dynamic Acceleration (IDA) Technology: Not Supported
Intel Dynamic FSB Switching: Not Supported
Intel Turbo Boost Technology: Supported, Enabled
Programmable Ratio Limits: Supported, Disabled
Programmable TDC/TDP Limits: Supported, Disabled
Hardware Duty Cycling: Not Supported
[CPU Scalable Features]
GSSE256 Instructions: Enabled
AES: Enabled
LT SX (TXT for Servers): Enabled
LT Production: Enabled
SMX: Enabled
VMX: Enabled
VT-x3: Enabled
VT Real Mode: Disabled
VT CPAUSE: Disabled
Multi-Threading (HT): Enabled
Programmable TDP Limits: Enabled
EX Config: Disabled
EP 4S Config: Disabled
EP (1S/2S) Config: Enabled
EN (1S/2S) Config: Disabled
UP (1S/WS) Config: Enabled
Memory Channel Mirroring Mode: Enabled
Memory LT Support: Enabled
Memory Frequency Support: Over-Clocking Supported
Physical Address Size Supported (Core): 46-bit
Extended APIC (x2APIC): Enabled
CPU HOT ADD: Disabled
GV3: Enabled
Core RAS (Data Poisoning, MCA Recovery): Enabled
DCA: Enabled
QPI Link 2: Disabled
QPI Link 1: Disabled
QPI Link 0: Disabled
Maximum Supported QPI ratio: 6.4 GT/s
NTB: Enabled
RAID-on-load: Enabled
PCIe LT SX: Enabled
PCIe LT: Enabled
PCIe Gen 3: Enabled
PCIe DMA: Enabled
DMI: Enabled
DDR4: Enabled
Monroe Technology: Disabled
SMBus Write Capability: Enabled
Extended Addressing DIMM: Disabled
Extended Latency DIMM: Enabled
Patrol Scrub: Enabled
Rank Sparing: Disabled
UDIMM Support: Enabled
RDIMM Support: Enabled
DIR: Disabled
ECC: Enabled
QR DIMM: Enabled
LOCKSTEP: Enabled
CLTT: Enabled
3N Mode: Enabled
4Gb DDR3: Enabled
8Gb DDR3: Enabled
Memory Channel 0: Enabled
Memory Channel 1: Enabled
Memory Channel 2: Enabled
Memory Channel 3: Enabled
CPU Stepping: R2
DRAM Power Meter: Enabled
DRAM RAPL: Enabled
Overclocking: Enabled
Energy Efficient Turbo: Enabled
Per-core P-states: Enabled
Uncore Frequency Scaling (UFS): Enabled
System Agent Power Management (SAPM) Dynamic Load Line (DLL): Enabled
Targeted SMI: Enabled
SMM CPU Save/Restore: Enabled
SMM Code Access Check: Enabled
Enhanced MCA: Enabled
FMA Instructions: Enabled
Hardware Lock Elison (HLE): Enabled
Hardware Lock Elison+ (HLE+)/RTM: Enabled
Cache Allocation Technology (CAT): Disabled
Cache Monitoring Technology (CMT): Enabled
Voltage Override Overclocking: Enabled
BCLK Coarse Ratio Support (PCIe Ratio Changing): Enabled
Physical Chop: Low-Core Count (LCC)
Product Type: Haswell
PCIE Ratio Change: Enabled
VMCS Shadowing: Enabled
FIT Boot: Enabled
PFAT: Enabled
Error Spoofing: Disabled
COD: Disabled
Haswell New Instructions: Enabled
Second Home Agent: Disabled
[Memory Ranges]
Maximum Physical Address Size: 46-bit (64 TBytes)
Maximum Virtual Address Size: 48-bit (256 TBytes)
[MTRRs]
Range 80000000-100000000 (2048MB-4096MB) Type: Uncacheable (UC)
Range 40000000-80000000 (1024MB-2048MB) Type: Uncacheable (UC)
Range 30000000000-34000000000 (3145728MB-3407872MB) Type: Uncacheable (UC)
Range 3E000000-40000000 (992MB-1024MB) Type: Uncacheable (UC)
Range E0000000-F0000000 (3584MB-3840MB) Type: Write Through (WT)
Range F0000000-F2000000 (3840MB-3872MB) Type: Write Through (WT)
Motherboard ---------------------------------------------------------------
[Computer]
[Motherboard]
Motherboard Model: DELL 0HHV7N
Motherboard Chipset: Intel C612 (Wellsburg-G)
Motherboard Slots: 1xPCI, 2xPCI Express x1, 6xPCI Express x4, 1xPCI Express x8, 2xPCI Express x16
PCI Express Version Supported: v3.0
USB Version Supported: v3.0
[BIOS]
BIOS Manufacturer: Dell Inc.
BIOS Date: 10/19/2020
BIOS Version: A34
UEFI BIOS: Capable
Super-IO/LPC Chip: SMSC FDC37C93xFR
ACPI Devices --------------------------------------------------------------
Programmable interrupt controller -----------------------------------------
Device Name: Programmable interrupt controller
[Assigned Resources]
I/O Port: 0020 - 003D
[Alternative 1]
I/O Port: 00A0 - 00BD
I/O Port: 04D0 - 04D1
Advanced programmable interrupt controller --------------------------------
Device Name: Advanced programmable interrupt controller
Memory Location: FEC00000 - FECFFFFF
[Alternative 1]
System timer --------------------------------------------------------------
Device Name: System timer
I/O Port: 0040 - 0043
DMA: 0
[Alternative 1]
I/O Port: 0050 - 0053
IRQ: 0
High precision event timer ------------------------------------------------
Device Name: High precision event timer
Memory Location: FED00000 - FED003FF
[Alternative 1]
Direct memory access controller -------------------------------------------
Device Name: Direct memory access controller
I/O Port: 0000 - 000F
I/O Port: 008F
Memory Location: 00000000 - 00000086
[Alternative 1]
I/O Port: 0081 - 0083
I/O Port: 0087
I/O Port: 0089 - 008B
I/O Port: 008F
I/O Port: 00C0 - 00DF
DMA: 4
Communications Port -------------------------------------------------------
Device Name: Communications Port
I/O Port: 03F8 - 03FF
[Alternative 1]
IRQ: 4
[Alternative 2]
IRQ: 4
[Alternative 3]
I/O Port: 02F8 - 02FF
IRQ: 3
[Alternative 4]
I/O Port: 03E8 - 03EF
IRQ: 4
[Alternative 5]
I/O Port: 02E8 - 02EF
IRQ: 3
System speaker ------------------------------------------------------------
Device Name: System speaker
I/O Port: 0061
[Alternative 1]
I/O Port: 0061
PCI Bus -------------------------------------------------------------------
Device Name: PCI Bus
[Alternative 1]
PCI Express Root Complex --------------------------------------------------
Device Name: PCI Express Root Complex
I/O Port: 0000 - FFFFFFFF
I/O Port: 03B0 - 03DF
Memory Location: 000A0000 - 0009FFFF
[Alternative 1]
I/O Port: 0000 - 03AF
I/O Port: 03E0 - 0CF7
I/O Port: 1000 - FFFF
Memory Location: 000A0000 - 000BFFFF
Memory Location: 50000000 - F7FFBFFF
System CMOS/real time clock -----------------------------------------------
Device Name: System CMOS/real time clock
I/O Port: 0070 - 0071
DMA: 0
[Alternative 1]
I/O Port: 0074 - 0077
IRQ: 8
Motherboard resources -----------------------------------------------------
Device Name: Motherboard resources
I/O Port: 0A00 - 0A3F
[Alternative 1]
I/O Port: 0500 - 057F
I/O Port: 0072 - 0073
I/O Port: 0000 - 0083
I/O Port: 008C - 008E
I/O Port: 0880 - 0883
Memory Location: FF000000 - FFFFFFFF
[Alternative 1]
I/O Port: 0400 - 047F
I/O Port: 0092
I/O Port: 0010 - 001F
I/O Port: 0080
I/O Port: 0084 - 0086
I/O Port: 0088
I/O Port: 0090 - 009F
I/O Port: 0580 - 059F
I/O Port: 0600 - 061F
I/O Port: 0800 - 081F
Memory Location: FED1C000 - FED3FFFF
Memory Location: FED45000 - FED8BFFF
Memory Location: FEE00000 - FEEFFFFF
Memory Location: FED12000 - FED1200F
Memory Location: FED12010
Memory Location: FED1B000 - FED1BFFF
Numeric data processor ----------------------------------------------------
Device Name: Numeric data processor
I/O Port: 00F0
[Alternative 1]
I/O Port: 00F0
IRQ: 13
SMBIOS DMI ----------------------------------------------------------------
BIOS ----------------------------------------------------------------------
BIOS Vendor: Dell Inc.
BIOS Version: A34
BIOS Release Date: 10/19/2020
BIOS Start Segment: F000
BIOS Size: 16384 KBytes
System BIOS Version: 65.34
ISA Support: Not Present
MCA Support: Not Present
EISA Support: Not Present
PCI Support: Present
PC Card (PCMCIA) Support: Not Present
Plug-and-Play Support: Present
APM Support: Not Present
Flash BIOS: Present
BIOS Shadow: Present
VL-VESA Support: Not Present
ESCD Support: Not Present
Boot from CD: Present
Selectable Boot: Present
BIOS ROM Socketed: Not Present
Boot from PC Card: Not Present
EDD Support: Present
NEC PC-98 Support: Not Present
ACPI Support: Present
USB Legacy Support: Present
AGP Support: Not Present
I2O Boot Support: Not Present
LS-120 Boot Support: Not Present
ATAPI ZIP Drive Boot Support: Not Present
IEE1394 Boot Support: Not Present
Smart Battery Support: Not Present
BIOS Boot Specification Support: Present
Function key-initiated Network Service Boot Support: Not Present
Targeted Content Distribution Support: Present
UEFI Specification Support: Present
Virtual Machine: Not Present
System --------------------------------------------------------------------
System Manufacturer: Dell Inc.
Product Name: Precision Tower 5810
Product Version:
Product Serial Number: HR40SD2
UUID: {4C4C4544-0052-3410-8030-C8C04F534432}
SKU Number: 0617
Family:
Mainboard -----------------------------------------------------------------
Mainboard Manufacturer: Dell Inc.
Mainboard Name: 0HHV7N
Mainboard Version: A00
Mainboard Serial Number: /HR40SD2/CN7220067S02DB/
Asset Tag:
Location in chassis:
Ok. thought I’d do some playing while waiting for a response / equipment to show up. I’m only looking at everything through my laptop and not actually trying to flash anything to the 5810. I downloaded Dell PFS extract v4.6 and used it to un pack the latest bios version listed on dells site for the t5810 which is 34. I then opened up the unpacked bios bin file in amibcp v5.02.0031. From there I can see all the menus and I guess how I make them visible is changing default to USER. However since I’ve never had an unlocked bios I cannot find where tdp control would be and where PPO current would be. The main issue for all of this is my current is defaulted at 208 amps and I need to increase and TDP hits a wall at 158 watts which is very easily hit over clocking the 1650v3. I’m really just trying to learn my way around amibcp right now as I’ve read that the bios exe files are updates and sometimes don’t contain the full bios…not sure so I’d probably prefer to pull a dump straight off the chip so I know that I have a good file and can save it.
@ frankr2994
Your log is showing power limits are capped to some values but unlimited so the TS can’t rise these limits?
I mean it must be just intuitive to find current limit at AMIBCP isn’t it?
Did you read this?
https://forums.anandtech.com/threads/wha…-xeons.2496647/
@ DaCou
TS will not raise the 208 limit. Using amibcp won’t actually change anything for me. Looking at the text of the efi modules in my bios there are actual default values set. These override any changed settings. For instance sata configuration the set variable is for ahci but the variable for raid is set to (default). So even though it’s calling for ahci it always shows up as raid regardless of what I do in amibcp. Now obviously a setting like that I can change in the bios gui because it’s not hidden. Everything else is hidden though. The only thing I can figure is if someone could put my bios information into a different container because my current bios only has room for 1 tab meaning other menus cannot be un hidden. The other option is I modify the settings in the bios efi files and change the default variables. I however do not know how to modify the efi file. I use ifr extractor to get it into text view and I know you use that for reference to modify the file but what do I open the file up with to modify. If I use a hex editor I can’t find my variables so I’m obviously doing something wrong. Oh and since I forgot about this particular thread since I originally posted I have got my programmer pulled dump files try modding myself with amibcp and had someone over at bios mods mod it as well. Everytime I flash the modded bios it actually changes nothing when I boot into the bios.
My bios dump and the bios I changed with amibcp are in my Google drive. https://drive.google.com/folderview?id=1…v9zMeRc2lelg4q3
Like I said what I changed in amibcp made no change. Still looking for anyone that can help.
@ frankr2994
If you can flash bios without problem this is good actually.
This 208 limit is Power limit or your current limit?
For locked power limits it is Must to modify 0x610 register bit [31 or 64]
For current limit the register is 0x601 bit[31]
I haven’t problem to modify these for you but yesterday my Windows Sata cable went wrong, so I am out of Windows currently.
At the evening I will try to make IDA Pro working on Linux and will let you know.
Or just download Readwriteverything, find MSR entry, tap User and write number 0x610 and 0x601, tap enter and your registers will be added to list. Than send me values of your registers.
P. S. Your AMIBCP is showing package power limit lock (0x610) is disabled so yes you should have be able to change PL1 and PL2 in TS.
Did you find your current limit and configurable TDP (up, down, nominal) in AMIBCP aswell?
It should be there.
Tdp is listed as level 1 and level 2. In TS the max current level I can set is 208. Setting it at 208 also sets my turbo power limits to max at 208. All I know about the limit I’m hitting is my package current is at 158 watts when it hits. And what I was getting at before is I need a tutorial on setting variables. I really don’t understand how to do it. All I’ve found online is using a program that you load with rufus and boot to and modify a live bios. I want to modify it while I’m working with the bios on a separate machine.
Also I think it has something to do with bios lock or activate overclocking features that I seen using amibcp but I have to put my machine to sleep then wake it up then open TS for anything to work. I’d obviously like it to where I didn’t have to back door it to that extent.
Setting variables is easy, but if your current limit register is locked at 208 there are no way fiddling with variables.
You probably meant RU tool, but it can help you with Bios Lock etc which is not your problem.
You just can’t modify this register in runtime, forget it. It is locked by Bios routine so Bios mod is needed and even then it is not guaranteed to work flawlessly.
You didn’t send me your values for 0x601, so I can’t help you anymore.
I honestly haven’t had time to tear back into it. Wife has me doing spring house duties. I also thought I was out of luck trying to find someone to help me. I’ll get the information over to you as soon as I can and I greatly appreciate the information. Also I wasn’t referring to modifying anything in runtime. I have been working with my bios dump and modifications on a separate computer. I have the Dell t5810 that I’m modding and a latitude laptop that I’m doing all the actual work on to mod the bios for the 5810.
It is OK no problem, btw TS has option ICC max which is simmilar to Current limit and powercut, did you tried it? Powercut option should be working specially on your 4 gen cpus…
Icc max is greyed out. And checking powercut seems to do nothing. To my understanding iccmax was 5th gen and newer. I’m not sure if it would exist if I was using a Xeon v4 but if I had a v4 it would also be a locked chip. I’ve been through everything I could do with TS with the assistance of unclewebb the developer of the program. I still plan to use TS to overclock because I’m fairly certain there is no way for me to add more menus to my bios so my only resort was to modify the variables and hope to give TS more headroom. I’ve still been kicking around if it’s possible to use a bios rom from some high-end gaming x99 board and use it to change my 5810 bios. Way above my skill level though.
