DG2 DATA patching
Hi All,
I am working on patching code in an IME image for an Intel DG2 GPU, however altering values in the DATA section causes the GPU to fail to even be recognised. I have been sure to update checksum values and MEAnalyser confirms to the best of it’s ability with this unsupported image that all checksum are valid.
Am I wrong in my understanding of the IME that the DATA section is unsigned? Or have I overlooked something else?
Right now my goal is to simply change a value to see if patching is even viable, as such I have identified several offsets to things like the PCI Sub vendor ID which should be essentially a trivial change that wont impact stock operation.
Just sharing some of the progress here.
The values I am interested seem to be stored in the EFS section. Contrary to what google suggest, the E doesn’t stand for Encrypted as this contains plain text and values I expect to find. I have also managed to acquire a list of files that MEAnalyzer doesn’t seem to find/extract that certainly do exist in the firmware.
I can confirm these exist, but I can’t state how I know this at this time.
/home/fsp/hda_codec               HDA Codec Verbs
/home/fsp/mrc_bdat                MRC BDAT
/home/fsp/mrc_debug               Training Step Level
/home/fsp/mrc_debug               Debug Overrides Control
/home/fsp/spd_0                   MemSS 0
/home/fsp/spd_0                   MemSS 1
/home/fsp/spd_0                   MemSS 2
/home/fsp/spd_0                   MemSS 3
/home/fsp/spd_0                   MemSS 4
/home/fsp/spd_0                   MemSS 5
/home/fsp/spd_0                   MemSS 6
/home/fsp/spd_0                   MemSS 7
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 0
/home/rbe/fsp_oem_cfg             Memory Type 0
/home/rbe/fsp_oem_cfg             Memory Vendor 0
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 1
/home/rbe/fsp_oem_cfg             Memory Type 1
/home/rbe/fsp_oem_cfg             Memory Vendor 1
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 2
/home/rbe/fsp_oem_cfg             Memory Type 2
/home/rbe/fsp_oem_cfg             Memory Vendor 2
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 3
/home/rbe/fsp_oem_cfg             Memory Type 3
/home/rbe/fsp_oem_cfg             Memory Vendor 3
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 4
/home/rbe/fsp_oem_cfg             Memory Type 4
/home/rbe/fsp_oem_cfg             Memory Vendor 4
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 5
/home/rbe/fsp_oem_cfg             Memory Type 5
/home/rbe/fsp_oem_cfg             Memory Vendor 5
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 6
/home/rbe/fsp_oem_cfg             Memory Type 6
/home/rbe/fsp_oem_cfg             Memory Vendor 6
/home/rbe/fsp_oem_cfg             GDDR6 Frequency Setting 7
/home/rbe/fsp_oem_cfg             Memory Type 7
/home/rbe/fsp_oem_cfg             Memory Vendor 7
/home/rbe/fsp_prof_0              FSP Profile 0
/home/rbe/fsp_prof_0              FIVR Data 0
/home/rbe/fsp_prof_0              HDA Subsystem Device ID 0
/home/rbe/fsp_prof_0              GT Subsystem Device ID 0
/home/rbe/fsp_prof_0              Physical Memory Population 0
/home/rbe/fsp_prof_0              DQS Mapping 0
/home/rbe/fsp_prof_0              DQ Mapping 0
/home/rbe/fsp_prof_0              DQS pins interleaved 0
/home/rbe/fsp_prof_0              AC_PKG_PL1 Enabled 0
/home/rbe/fsp_prof_0              AC_PKG_PL1 Time 0
/home/rbe/fsp_prof_0              AC_PKG_PL2 Enabled 0
/home/rbe/fsp_prof_0              AC_PKG_PL2 Time 0
/home/rbe/fsp_prof_0              DC_PKG_PL1 Enabled 0
/home/rbe/fsp_prof_0              DC_PKG_PL1 Time 0
/home/rbe/fsp_prof_0              DC_PKG_PL2 Enabled 0
/home/rbe/fsp_prof_0              DC_PKG_PL2 Time 0
/home/rbe/fsp_prof_0              PSYS_PL1 Enabled 0
/home/rbe/fsp_prof_0              PSYS_PL1 Time 0
/home/rbe/fsp_prof_0              PSYS_PL2 Enabled 0
/home/rbe/fsp_prof_0              PSYS_PL2 Time 0
/home/rbe/fsp_prof_0              RTD3_EN_CAPABILITY 0
/home/rbe/fsp_prof_0              PSYS_ENABLE 0
/home/rbe/fsp_prof_0              Fan Control 0
/home/rbe/fsp_prof_0              ODM EPC: GT frequency/Voltage 0
/home/rbe/fsp_prof_0              ODM EPC: ICCMax/TjMax 0
/home/rbe/fsp_prof_0              VRAM_SR_CAPABILITY 0
/home/rbe/fsp_prof_0              Frequency Override 0
/home/rbe/fsp_prof_0              Audio enabled 0
/home/rbe/fsp_prof_0              PCIe Channel Equalization 0
/home/rbe/fsp_prof_0              P2SB function enable 0
/home/rbe/fsp_prof_0              GT Subsystem Vendor ID 0
/home/rbe/fsp_prof_0              HDA Subsystem Vendor ID 0
/home/rbe/fsp_prof_0              GDDR6 SSC 0
/home/rbe/fsp_prof_0              LMEMBAR 0
/home/rbe/fsp_prof_0              GTMMADDR Prefetch Capability 0
/home/rbe/fsp_prof_0              Display Present 0
/home/rbe/fsp_prof_0              I2C for Third Party Devices 0
/home/rbe/fsp_prof_0              I2C Device Address 1 0
/home/rbe/fsp_prof_0              I2C Device Address 2 0
/home/rbe/fsp_prof_0              I2C Bus speed 0
/home/rbe/fsp_prof_1              FSP Profile 1
/home/rbe/fsp_prof_1              FIVR Data 1
/home/rbe/fsp_prof_1              HDA Subsystem Device ID 1
/home/rbe/fsp_prof_1              GT Subsystem Device ID 1
/home/rbe/fsp_prof_1              Physical Memory Population 1
/home/rbe/fsp_prof_1              DQS Mapping 1
/home/rbe/fsp_prof_1              DQ Mapping 1
/home/rbe/fsp_prof_1              DQS pins interleaved 1
/home/rbe/fsp_prof_1              AC_PKG_PL1 Enabled 1
/home/rbe/fsp_prof_1              AC_PKG_PL1 Time 1
/home/rbe/fsp_prof_1              AC_PKG_PL2 Enabled 1
/home/rbe/fsp_prof_1              AC_PKG_PL2 Time 1
/home/rbe/fsp_prof_1              DC_PKG_PL1 Enabled 1
/home/rbe/fsp_prof_1              DC_PKG_PL1 Time 1
/home/rbe/fsp_prof_1              DC_PKG_PL2 Enabled 1
/home/rbe/fsp_prof_1              DC_PKG_PL2 Time 1
/home/rbe/fsp_prof_1              PSYS_PL1 Enabled 1
/home/rbe/fsp_prof_1              PSYS_PL1 Time 1
/home/rbe/fsp_prof_1              PSYS_PL2 Enabled 1
/home/rbe/fsp_prof_1              PSYS_PL2 Time 1
/home/rbe/fsp_prof_1              RTD3_EN_CAPABILITY 1
/home/rbe/fsp_prof_1              PSYS_ENABLE 1
/home/rbe/fsp_prof_1              Fan Control 1
/home/rbe/fsp_prof_1              ODM EPC: GT frequency/Voltage 1
/home/rbe/fsp_prof_1              ODM EPC: ICCMax/TjMax 1
/home/rbe/fsp_prof_1              VRAM_SR_CAPABILITY 1
/home/rbe/fsp_prof_1              Frequency Override 1
/home/rbe/fsp_prof_1              Audio enabled 1
/home/rbe/fsp_prof_1              PCIe Channel Equalization 1
/home/rbe/fsp_prof_1              P2SB function enable 1
/home/rbe/fsp_prof_1              GT Subsystem Vendor ID 1
/home/rbe/fsp_prof_1              HDA Subsystem Vendor ID 1
/home/rbe/fsp_prof_1              GDDR6 SSC 1
/home/rbe/fsp_prof_1              LMEMBAR 1
/home/rbe/fsp_prof_1              GTMMADDR Prefetch Capability 1
/home/rbe/fsp_prof_1              Display Present 1
/home/rbe/fsp_prof_1              I2C for Third Party Devices 1
/home/rbe/fsp_prof_1              I2C Device Address 1 1
/home/rbe/fsp_prof_1              I2C Device Address 2 1
/home/rbe/fsp_prof_1              I2C Bus speed 1
/home/rbe/fsp_prof_2              FSP Profile 2
/home/rbe/fsp_prof_2              FIVR Data 2
/home/rbe/fsp_prof_2              HDA Subsystem Device ID 2
/home/rbe/fsp_prof_2              GT Subsystem Device ID 2
/home/rbe/fsp_prof_2              Physical Memory Population 2
/home/rbe/fsp_prof_2              DQS Mapping 2
/home/rbe/fsp_prof_2              DQ Mapping 2
/home/rbe/fsp_prof_2              DQS pins interleaved 2
/home/rbe/fsp_prof_2              AC_PKG_PL1 Enabled 2
/home/rbe/fsp_prof_2              AC_PKG_PL1 Time 2
/home/rbe/fsp_prof_2              AC_PKG_PL2 Enabled 2
/home/rbe/fsp_prof_2              AC_PKG_PL2 Time 2
/home/rbe/fsp_prof_2              DC_PKG_PL1 Enabled 2
/home/rbe/fsp_prof_2              DC_PKG_PL1 Time 2
/home/rbe/fsp_prof_2              DC_PKG_PL2 Enabled 2
/home/rbe/fsp_prof_2              DC_PKG_PL2 Time 2
/home/rbe/fsp_prof_2              PSYS_PL1 Enabled 2
/home/rbe/fsp_prof_2              PSYS_PL1 Time 2
/home/rbe/fsp_prof_2              PSYS_PL2 Enabled 2
/home/rbe/fsp_prof_2              PSYS_PL2 Time 2
/home/rbe/fsp_prof_2              RTD3_EN_CAPABILITY 2
/home/rbe/fsp_prof_2              PSYS_ENABLE 2
/home/rbe/fsp_prof_2              Fan Control 2
/home/rbe/fsp_prof_2              ODM EPC: GT frequency/Voltage 2
/home/rbe/fsp_prof_2              ODM EPC: ICCMax/TjMax 2
/home/rbe/fsp_prof_2              VRAM_SR_CAPABILITY 2
/home/rbe/fsp_prof_2              Frequency Override 2
/home/rbe/fsp_prof_2              Audio enabled 2
/home/rbe/fsp_prof_2              PCIe Channel Equalization 2
/home/rbe/fsp_prof_2              P2SB function enable 2
/home/rbe/fsp_prof_2              GT Subsystem Vendor ID 2
/home/rbe/fsp_prof_2              HDA Subsystem Vendor ID 2
/home/rbe/fsp_prof_2              GDDR6 SSC 2
/home/rbe/fsp_prof_2              LMEMBAR 2
/home/rbe/fsp_prof_2              GTMMADDR Prefetch Capability 2
/home/rbe/fsp_prof_2              Display Present 2
/home/rbe/fsp_prof_2              I2C for Third Party Devices 2
/home/rbe/fsp_prof_2              I2C Device Address 1 2
/home/rbe/fsp_prof_2              I2C Device Address 2 2
/home/rbe/fsp_prof_2              I2C Bus speed 2
/home/rbe/fsp_prof_3              FSP Profile 3
/home/rbe/fsp_prof_3              FIVR Data 3
/home/rbe/fsp_prof_3              HDA Subsystem Device ID 3
/home/rbe/fsp_prof_3              GT Subsystem Device ID 3
/home/rbe/fsp_prof_3              Physical Memory Population 3
/home/rbe/fsp_prof_3              DQS Mapping 3
/home/rbe/fsp_prof_3              DQ Mapping 3
/home/rbe/fsp_prof_3              DQS pins interleaved 3
/home/rbe/fsp_prof_3              AC_PKG_PL1 Enabled 3
/home/rbe/fsp_prof_3              AC_PKG_PL1 Time 3
/home/rbe/fsp_prof_3              AC_PKG_PL2 Enabled 3
/home/rbe/fsp_prof_3              AC_PKG_PL2 Time 3
/home/rbe/fsp_prof_3              DC_PKG_PL1 Enabled 3
/home/rbe/fsp_prof_3              DC_PKG_PL1 Time 3
/home/rbe/fsp_prof_3              DC_PKG_PL2 Enabled 3
/home/rbe/fsp_prof_3              DC_PKG_PL2 Time 3
/home/rbe/fsp_prof_3              PSYS_PL1 Enabled 3
/home/rbe/fsp_prof_3              PSYS_PL1 Time 3
/home/rbe/fsp_prof_3              PSYS_PL2 Enabled 3
/home/rbe/fsp_prof_3              PSYS_PL2 Time 3
/home/rbe/fsp_prof_3              RTD3_EN_CAPABILITY 3
/home/rbe/fsp_prof_3              PSYS_ENABLE 3
/home/rbe/fsp_prof_3              Fan Control 3
/home/rbe/fsp_prof_3              ODM EPC: GT frequency/Voltage 3
/home/rbe/fsp_prof_3              ODM EPC: ICCMax/TjMax 3
/home/rbe/fsp_prof_3              VRAM_SR_CAPABILITY 3
/home/rbe/fsp_prof_3              Frequency Override 3
/home/rbe/fsp_prof_3              Audio enabled 3
/home/rbe/fsp_prof_3              PCIe Channel Equalization 3
/home/rbe/fsp_prof_3              P2SB function enable 3
/home/rbe/fsp_prof_3              GT Subsystem Vendor ID 3
/home/rbe/fsp_prof_3              HDA Subsystem Vendor ID 3
/home/rbe/fsp_prof_3              GDDR6 SSC 3
/home/rbe/fsp_prof_3              LMEMBAR 3
/home/rbe/fsp_prof_3              GTMMADDR Prefetch Capability 3
/home/rbe/fsp_prof_3              Display Present 3
/home/rbe/fsp_prof_3              I2C for Third Party Devices 3
/home/rbe/fsp_prof_3              I2C Device Address 1 3
/home/rbe/fsp_prof_3              I2C Device Address 2 3
/home/rbe/fsp_prof_3              I2C Bus speed 3
/home/rbe/fsp_prof_4              FSP Profile 4
/home/rbe/fsp_prof_4              FIVR Data 4
/home/rbe/fsp_prof_4              HDA Subsystem Device ID 4
/home/rbe/fsp_prof_4              GT Subsystem Device ID 4
/home/rbe/fsp_prof_4              Physical Memory Population 4
/home/rbe/fsp_prof_4              DQS Mapping 4
/home/rbe/fsp_prof_4              DQ Mapping 4
/home/rbe/fsp_prof_4              DQS pins interleaved 4
/home/rbe/fsp_prof_4              AC_PKG_PL1 Enabled 4
/home/rbe/fsp_prof_4              AC_PKG_PL1 Time 4
/home/rbe/fsp_prof_4              AC_PKG_PL2 Enabled 4
/home/rbe/fsp_prof_4              AC_PKG_PL2 Time 4
/home/rbe/fsp_prof_4              DC_PKG_PL1 Enabled 4
/home/rbe/fsp_prof_4              DC_PKG_PL1 Time 4
/home/rbe/fsp_prof_4              DC_PKG_PL2 Enabled 4
/home/rbe/fsp_prof_4              DC_PKG_PL2 Time 4
/home/rbe/fsp_prof_4              PSYS_PL1 Enabled 4
/home/rbe/fsp_prof_4              PSYS_PL1 Time 4
/home/rbe/fsp_prof_4              PSYS_PL2 Enabled 4
/home/rbe/fsp_prof_4              PSYS_PL2 Time 4
/home/rbe/fsp_prof_4              RTD3_EN_CAPABILITY 4
/home/rbe/fsp_prof_4              PSYS_ENABLE 4
/home/rbe/fsp_prof_4              Fan Control 4
/home/rbe/fsp_prof_4              ODM EPC: GT frequency/Voltage 4
/home/rbe/fsp_prof_4              ODM EPC: ICCMax/TjMax 4
/home/rbe/fsp_prof_4              VRAM_SR_CAPABILITY 4
/home/rbe/fsp_prof_4              Frequency Override 4
/home/rbe/fsp_prof_4              Audio enabled 4
/home/rbe/fsp_prof_4              PCIe Channel Equalization 4
/home/rbe/fsp_prof_4              P2SB function enable 4
/home/rbe/fsp_prof_4              GT Subsystem Vendor ID 4
/home/rbe/fsp_prof_4              HDA Subsystem Vendor ID 4
/home/rbe/fsp_prof_4              GDDR6 SSC 4
/home/rbe/fsp_prof_4              LMEMBAR 4
/home/rbe/fsp_prof_4              GTMMADDR Prefetch Capability 4
/home/rbe/fsp_prof_4              Display Present 4
/home/rbe/fsp_prof_4              I2C for Third Party Devices 4
/home/rbe/fsp_prof_4              I2C Device Address 1 4
/home/rbe/fsp_prof_4              I2C Device Address 2 4
/home/rbe/fsp_prof_4              I2C Bus speed 4
/home/rbe/fsp_prof_5              FSP Profile 5
/home/rbe/fsp_prof_5              FIVR Data 5
/home/rbe/fsp_prof_5              HDA Subsystem Device ID 5
/home/rbe/fsp_prof_5              GT Subsystem Device ID 5
/home/rbe/fsp_prof_5              Physical Memory Population 5
/home/rbe/fsp_prof_5              DQS Mapping 5
/home/rbe/fsp_prof_5              DQ Mapping 5
/home/rbe/fsp_prof_5              DQS pins interleaved 5
/home/rbe/fsp_prof_5              AC_PKG_PL1 Enabled 5
/home/rbe/fsp_prof_5              AC_PKG_PL1 Time 5
/home/rbe/fsp_prof_5              AC_PKG_PL2 Enabled 5
/home/rbe/fsp_prof_5              AC_PKG_PL2 Time 5
/home/rbe/fsp_prof_5              DC_PKG_PL1 Enabled 5
/home/rbe/fsp_prof_5              DC_PKG_PL1 Time 5
/home/rbe/fsp_prof_5              DC_PKG_PL2 Enabled 5
/home/rbe/fsp_prof_5              DC_PKG_PL2 Time 5
/home/rbe/fsp_prof_5              PSYS_PL1 Enabled 5
/home/rbe/fsp_prof_5              PSYS_PL1 Time 5
/home/rbe/fsp_prof_5              PSYS_PL2 Enabled 5
/home/rbe/fsp_prof_5              PSYS_PL2 Time 5
/home/rbe/fsp_prof_5              RTD3_EN_CAPABILITY 5
/home/rbe/fsp_prof_5              PSYS_ENABLE 5
/home/rbe/fsp_prof_5              Fan Control 5
/home/rbe/fsp_prof_5              ODM EPC: GT frequency/Voltage 5
/home/rbe/fsp_prof_5              ODM EPC: ICCMax/TjMax 5
/home/rbe/fsp_prof_5              VRAM_SR_CAPABILITY 5
/home/rbe/fsp_prof_5              Frequency Override 5
/home/rbe/fsp_prof_5              Audio enabled 5
/home/rbe/fsp_prof_5              PCIe Channel Equalization 5
/home/rbe/fsp_prof_5              P2SB function enable 5
/home/rbe/fsp_prof_5              GT Subsystem Vendor ID 5
/home/rbe/fsp_prof_5              HDA Subsystem Vendor ID 5
/home/rbe/fsp_prof_5              GDDR6 SSC 5
/home/rbe/fsp_prof_5              LMEMBAR 5
/home/rbe/fsp_prof_5              GTMMADDR Prefetch Capability 5
/home/rbe/fsp_prof_5              Display Present 5
/home/rbe/fsp_prof_5              I2C for Third Party Devices 5
/home/rbe/fsp_prof_5              I2C Device Address 1 5
/home/rbe/fsp_prof_5              I2C Device Address 2 5
/home/rbe/fsp_prof_5              I2C Bus speed 5
/home/rbe/fsp_prof_6              FSP Profile 6
/home/rbe/fsp_prof_6              FIVR Data 6
/home/rbe/fsp_prof_6              HDA Subsystem Device ID 6
/home/rbe/fsp_prof_6              GT Subsystem Device ID 6
/home/rbe/fsp_prof_6              Physical Memory Population 6
/home/rbe/fsp_prof_6              DQS Mapping 6
/home/rbe/fsp_prof_6              DQ Mapping 6
/home/rbe/fsp_prof_6              DQS pins interleaved 6
/home/rbe/fsp_prof_6              AC_PKG_PL1 Enabled 6
/home/rbe/fsp_prof_6              AC_PKG_PL1 Time 6
/home/rbe/fsp_prof_6              AC_PKG_PL2 Enabled 6
/home/rbe/fsp_prof_6              AC_PKG_PL2 Time 6
/home/rbe/fsp_prof_6              DC_PKG_PL1 Enabled 6
/home/rbe/fsp_prof_6              DC_PKG_PL1 Time 6
/home/rbe/fsp_prof_6              DC_PKG_PL2 Enabled 6
/home/rbe/fsp_prof_6              DC_PKG_PL2 Time 6
/home/rbe/fsp_prof_6              PSYS_PL1 Enabled 6
/home/rbe/fsp_prof_6              PSYS_PL1 Time 6
/home/rbe/fsp_prof_6              PSYS_PL2 Enabled 6
/home/rbe/fsp_prof_6              PSYS_PL2 Time 6
/home/rbe/fsp_prof_6              RTD3_EN_CAPABILITY 6
/home/rbe/fsp_prof_6              PSYS_ENABLE 6
/home/rbe/fsp_prof_6              Fan Control 6
/home/rbe/fsp_prof_6              ODM EPC: GT frequency/Voltage 6
/home/rbe/fsp_prof_6              ODM EPC: ICCMax/TjMax 6
/home/rbe/fsp_prof_6              VRAM_SR_CAPABILITY 6
/home/rbe/fsp_prof_6              Frequency Override 6
/home/rbe/fsp_prof_6              Audio enabled 6
/home/rbe/fsp_prof_6              PCIe Channel Equalization 6
/home/rbe/fsp_prof_6              P2SB function enable 6
/home/rbe/fsp_prof_6              GT Subsystem Vendor ID 6
/home/rbe/fsp_prof_6              HDA Subsystem Vendor ID 6
/home/rbe/fsp_prof_6              GDDR6 SSC 6
/home/rbe/fsp_prof_6              LMEMBAR 6
/home/rbe/fsp_prof_6              GTMMADDR Prefetch Capability 6
/home/rbe/fsp_prof_6              Display Present 6
/home/rbe/fsp_prof_6              I2C for Third Party Devices 6
/home/rbe/fsp_prof_6              I2C Device Address 1 6
/home/rbe/fsp_prof_6              I2C Device Address 2 6
/home/rbe/fsp_prof_6              I2C Bus speed 6
/home/rbe/fsp_prof_7              FSP Profile 7
/home/rbe/fsp_prof_7              FIVR Data 7
/home/rbe/fsp_prof_7              HDA Subsystem Device ID 7
/home/rbe/fsp_prof_7              GT Subsystem Device ID 7
/home/rbe/fsp_prof_7              Physical Memory Population 7
/home/rbe/fsp_prof_7              DQS Mapping 7
/home/rbe/fsp_prof_7              DQ Mapping 7
/home/rbe/fsp_prof_7              DQS pins interleaved 7
/home/rbe/fsp_prof_7              AC_PKG_PL1 Enabled 7
/home/rbe/fsp_prof_7              AC_PKG_PL1 Time 7
/home/rbe/fsp_prof_7              AC_PKG_PL2 Enabled 7
/home/rbe/fsp_prof_7              AC_PKG_PL2 Time 7
/home/rbe/fsp_prof_7              DC_PKG_PL1 Enabled 7
/home/rbe/fsp_prof_7              DC_PKG_PL1 Time 7
/home/rbe/fsp_prof_7              DC_PKG_PL2 Enabled 7
/home/rbe/fsp_prof_7              DC_PKG_PL2 Time 7
/home/rbe/fsp_prof_7              PSYS_PL1 Enabled 7
/home/rbe/fsp_prof_7              PSYS_PL1 Time 7
/home/rbe/fsp_prof_7              PSYS_PL2 Enabled 7
/home/rbe/fsp_prof_7              PSYS_PL2 Time 7
/home/rbe/fsp_prof_7              RTD3_EN_CAPABILITY 7
/home/rbe/fsp_prof_7              PSYS_ENABLE 7
/home/rbe/fsp_prof_7              Fan Control 7
/home/rbe/fsp_prof_7              ODM EPC: GT frequency/Voltage 7
/home/rbe/fsp_prof_7              ODM EPC: ICCMax/TjMax 7
/home/rbe/fsp_prof_7              VRAM_SR_CAPABILITY 7
/home/rbe/fsp_prof_7              Frequency Override 7
/home/rbe/fsp_prof_7              Audio enabled 7
/home/rbe/fsp_prof_7              PCIe Channel Equalization 7
/home/rbe/fsp_prof_7              P2SB function enable 7
/home/rbe/fsp_prof_7              GT Subsystem Vendor ID 7
/home/rbe/fsp_prof_7              HDA Subsystem Vendor ID 7
/home/rbe/fsp_prof_7              GDDR6 SSC 7
/home/rbe/fsp_prof_7              LMEMBAR 7
/home/rbe/fsp_prof_7              GTMMADDR Prefetch Capability 7
/home/rbe/fsp_prof_7              Display Present 7
/home/rbe/fsp_prof_7              I2C for Third Party Devices 7
/home/rbe/fsp_prof_7              I2C Device Address 1 7
/home/rbe/fsp_prof_7              I2C Device Address 2 7
/home/rbe/fsp_prof_7              I2C Bus speed 7
/home/rbe/fsp_prof_sel            Profile Selector
/home/gfx_srv/aic_uid             AIC customer program unique ID
/home/gfx_srv/device_id           Device ID
/home/mca/eom                     End of Manufacturing Enable
/home/mca/mca_oem_version         OEM FW Version
/home/fwupdate/oem_manuf_data_ver OEM Manufacturing Data Version
/home/pavp/hdcp_ports             eDP Port Config
If we can figure this out, I will be releasing everything to the public needed to patch these values, but as I am new to working with the IME, the learning curve is very steep. Any help by pros that know it well would be much appreciated.
Of note is GDDR6 Frequency Setting which in theory could gain the A770 an extra 6GB/s of bandwidth if we can raise this to 18GT/s from the factory programmed 17.5GT/s, which seems like an artificial limit rather then a hardware limitation.
Additional details from further RE efforts:
FileId       : 00000065
FilePath     : /home/fsp/hda_codec
VirtualFileId: 10035b00
FileSize     : 00002000
FileType?    : 00000064
FullName     : HDA Codec Verbs
OffsetInFile : 00000000
Flags        : 0b011000000
FileId       : 00000066
FilePath     : /home/fsp/mrc_bdat
VirtualFileId: 10007000
FileSize     : 00064000
FullName     : MRC BDAT
Flags        : 0b000000000
FileId       : 00000067
FilePath     : /home/fsp/mrc_debug
VirtualFileId: 1000bd00
FileSize     : 00000800
FileType?    : 000000ae
FullName     : Training Step Level
Flags        : 0b010010000
FileId       : 00000067
FileSize     : 00000800
FileType?    : 00000066
FullName     : Debug Overrides Control
Flags        : 0b000000000
FileId       : 00000068
FilePath     : /home/fsp/spd_0
VirtualFileId: 10007e00
FileSize     : 00008000
FileType?    : 00000090
FullName     : MemSS 0
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000091
FullName     : MemSS 1
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000092
FullName     : MemSS 2
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000093
FullName     : MemSS 3
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000094
FullName     : MemSS 4
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000095
FullName     : MemSS 5
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000096
FullName     : MemSS 6
Flags        : 0b000000000
FileId       : 00000068
FileSize     : 00008000
FileType?    : 00000097
FullName     : MemSS 7
Flags        : 0b000000000
FileId       : 00000069
FilePath     : /home/rbe/fsp_oem_cfg
VirtualFileId: 10004400
FileSize     : 00002000
FileType?    : 0000006d
FullName     : GDDR6 Frequency Setting 0
Flags        : 0b010000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000080
FullName     : Memory Type 0
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000088
FullName     : Memory Vendor 0
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000006e
FullName     : GDDR6 Frequency Setting 1
Flags        : 0b010000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000081
FullName     : Memory Type 1
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000089
FullName     : Memory Vendor 1
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000006f
FullName     : GDDR6 Frequency Setting 2
Flags        : 0b010000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000082
FullName     : Memory Type 2
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008a
FullName     : Memory Vendor 2
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000070
FullName     : GDDR6 Frequency Setting 3
Flags        : 0b010000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000083
FullName     : Memory Type 3
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008b
FullName     : Memory Vendor 3
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000071
FullName     : GDDR6 Frequency Setting 4
Flags        : 0b000000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000084
FullName     : Memory Type 4
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008c
FullName     : Memory Vendor 4
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000072
FullName     : GDDR6 Frequency Setting 5
Flags        : 0b000000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000085
FullName     : Memory Type 5
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008d
FullName     : Memory Vendor 5
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000073
FullName     : GDDR6 Frequency Setting 6
Flags        : 0b000000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000086
FullName     : Memory Type 6
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008e
FullName     : Memory Vendor 6
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000074
FullName     : GDDR6 Frequency Setting 7
Flags        : 0b000000000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 00000087
FullName     : Memory Type 7
Flags        : 0b010010000
FileId       : 00000069
FileSize     : 00002000
FileType?    : 0000008f
FullName     : Memory Vendor 7
Flags        : 0b010010000
FileId       : 0000006a
FilePath     : /home/rbe/fsp_prof_0
VirtualFileId: 10007400
FileSize     : 00003000
FullName     : FSP Profile 0
Flags        : 0b000000000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000006c
FullName     : FIVR Data 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007a
FullName     : HDA Subsystem Device ID 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000076
FullName     : GT Subsystem Device ID 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009a
FullName     : Physical Memory Population 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000069
FullName     : DQS Mapping 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000006b
FullName     : DQ Mapping 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000006a
FullName     : DQS pins interleaved 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009b
FullName     : AC_PKG_PL1 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009c
FullName     : AC_PKG_PL1 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009d
FullName     : AC_PKG_PL2 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009e
FullName     : AC_PKG_PL2 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000009f
FullName     : DC_PKG_PL1 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a0
FullName     : DC_PKG_PL1 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a1
FullName     : DC_PKG_PL2 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a2
FullName     : DC_PKG_PL2 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a3
FullName     : PSYS_PL1 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a4
FullName     : PSYS_PL1 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a5
FullName     : PSYS_PL2 Enabled 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a6
FullName     : PSYS_PL2 Time 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000ac
FullName     : RTD3_EN_CAPABILITY 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000ab
FullName     : PSYS_ENABLE 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a7
FullName     : Fan Control 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a8
FullName     : ODM EPC: GT frequency/Voltage 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000a9
FullName     : ODM EPC: ICCMax/TjMax 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000ad
FullName     : VRAM_SR_CAPABILITY 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 000000aa
FullName     : Frequency Override 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000065
FullName     : Audio enabled 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000099
FullName     : PCIe Channel Equalization 0
Flags        : 0b011010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000098
FullName     : P2SB function enable 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000078
FullName     : GT Subsystem Vendor ID 0
Flags        : 0b010010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000079
FullName     : HDA Subsystem Vendor ID 0
Flags        : 0b010010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000075
FullName     : GDDR6 SSC 0
Flags        : 0b010010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007f
FullName     : LMEMBAR 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000077
FullName     : GTMMADDR Prefetch Capability 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 00000068
FullName     : Display Present 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007e
FullName     : I2C for Third Party Devices 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007c
FullName     : I2C Device Address 1 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007d
FullName     : I2C Device Address 2 0
Flags        : 0b000010000
FileId       : 0000006a
FileSize     : 00003000
FileType?    : 0000007b
FullName     : I2C Bus speed 0
Flags        : 0b000010000
FileId       : 0000006b
FilePath     : /home/rbe/fsp_prof_1
VirtualFileId: 10007401
FileSize     : 00003000
FullName     : FSP Profile 1
Flags        : 0b000000000
FileId       : 0000006b
FileSize     : 00003000
FullName     : FIVR Data 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : GT Subsystem Device ID 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : Physical Memory Population 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DQS Mapping 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DQ Mapping 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DQS pins interleaved 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PSYS_PL1 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PSYS_PL2 Time 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PSYS_ENABLE 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : Fan Control 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : Frequency Override 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : Audio enabled 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : PCIe Channel Equalization 1
Flags        : 0b011010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : P2SB function enable 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 1
Flags        : 0b010010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 1
Flags        : 0b010010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : GDDR6 SSC 1
Flags        : 0b010010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : LMEMBAR 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : Display Present 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : I2C for Third Party Devices 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : I2C Device Address 1 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : I2C Device Address 2 1
Flags        : 0b000010000
FileId       : 0000006b
FileSize     : 00003000
FullName     : I2C Bus speed 1
Flags        : 0b000010000
FileId       : 0000006c
FilePath     : /home/rbe/fsp_prof_2
VirtualFileId: 10007402
FileSize     : 00003000
FullName     : FSP Profile 2
Flags        : 0b000000000
FileId       : 0000006c
FileSize     : 00003000
FullName     : FIVR Data 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : GT Subsystem Device ID 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : Physical Memory Population 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DQS Mapping 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DQ Mapping 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DQS pins interleaved 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PSYS_PL1 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PSYS_PL2 Time 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PSYS_ENABLE 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : Fan Control 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : Frequency Override 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : Audio enabled 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : PCIe Channel Equalization 2
Flags        : 0b011010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : P2SB function enable 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 2
Flags        : 0b010010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 2
Flags        : 0b010010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : GDDR6 SSC 2
Flags        : 0b010010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : LMEMBAR 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : Display Present 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : I2C for Third Party Devices 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : I2C Device Address 1 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : I2C Device Address 2 2
Flags        : 0b000010000
FileId       : 0000006c
FileSize     : 00003000
FullName     : I2C Bus speed 2
Flags        : 0b000010000
FileId       : 0000006d
FilePath     : /home/rbe/fsp_prof_3
VirtualFileId: 10007403
FileSize     : 00003000
FullName     : FSP Profile 3
Flags        : 0b000000000
FileId       : 0000006d
FileSize     : 00003000
FullName     : FIVR Data 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : GT Subsystem Device ID 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : Physical Memory Population 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DQS Mapping 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DQ Mapping 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DQS pins interleaved 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PSYS_PL1 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PSYS_PL2 Time 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PSYS_ENABLE 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : Fan Control 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : Frequency Override 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : Audio enabled 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : PCIe Channel Equalization 3
Flags        : 0b011010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : P2SB function enable 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 3
Flags        : 0b010010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 3
Flags        : 0b010010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : GDDR6 SSC 3
Flags        : 0b010010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : LMEMBAR 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : Display Present 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : I2C for Third Party Devices 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : I2C Device Address 1 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : I2C Device Address 2 3
Flags        : 0b000010000
FileId       : 0000006d
FileSize     : 00003000
FullName     : I2C Bus speed 3
Flags        : 0b000010000
FileId       : 0000006e
FilePath     : /home/rbe/fsp_prof_4
VirtualFileId: 10007404
FileSize     : 00003000
FullName     : FSP Profile 4
Flags        : 0b000000000
FileId       : 0000006e
FileSize     : 00003000
FullName     : FIVR Data 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : GT Subsystem Device ID 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : Physical Memory Population 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DQS Mapping 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DQ Mapping 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DQS pins interleaved 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PSYS_PL1 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PSYS_PL2 Time 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PSYS_ENABLE 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : Fan Control 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : Frequency Override 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : Audio enabled 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : PCIe Channel Equalization 4
Flags        : 0b011010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : P2SB function enable 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 4
Flags        : 0b010010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 4
Flags        : 0b010010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : GDDR6 SSC 4
Flags        : 0b010010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : LMEMBAR 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : Display Present 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : I2C for Third Party Devices 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : I2C Device Address 1 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : I2C Device Address 2 4
Flags        : 0b000010000
FileId       : 0000006e
FileSize     : 00003000
FullName     : I2C Bus speed 4
Flags        : 0b000010000
FileId       : 0000006f
FilePath     : /home/rbe/fsp_prof_5
VirtualFileId: 10007405
FileSize     : 00003000
FullName     : FSP Profile 5
Flags        : 0b000000000
FileId       : 0000006f
FileSize     : 00003000
FullName     : FIVR Data 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : GT Subsystem Device ID 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : Physical Memory Population 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DQS Mapping 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DQ Mapping 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DQS pins interleaved 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PSYS_PL1 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PSYS_PL2 Time 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PSYS_ENABLE 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : Fan Control 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : Frequency Override 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : Audio enabled 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : PCIe Channel Equalization 5
Flags        : 0b011010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : P2SB function enable 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 5
Flags        : 0b010010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 5
Flags        : 0b010010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : GDDR6 SSC 5
Flags        : 0b010010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : LMEMBAR 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : Display Present 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : I2C for Third Party Devices 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : I2C Device Address 1 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : I2C Device Address 2 5
Flags        : 0b000010000
FileId       : 0000006f
FileSize     : 00003000
FullName     : I2C Bus speed 5
Flags        : 0b000010000
FileId       : 00000070
FilePath     : /home/rbe/fsp_prof_6
VirtualFileId: 10007406
FileSize     : 00003000
FullName     : FSP Profile 6
Flags        : 0b000000000
FileId       : 00000070
FileSize     : 00003000
FullName     : FIVR Data 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : GT Subsystem Device ID 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : Physical Memory Population 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DQS Mapping 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DQ Mapping 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DQS pins interleaved 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PSYS_PL1 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PSYS_PL2 Time 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PSYS_ENABLE 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : Fan Control 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : Frequency Override 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : Audio enabled 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : PCIe Channel Equalization 6
Flags        : 0b011010000
FileId       : 00000070
FileSize     : 00003000
FullName     : P2SB function enable 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 6
Flags        : 0b010010000
FileId       : 00000070
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 6
Flags        : 0b010010000
FileId       : 00000070
FileSize     : 00003000
FullName     : GDDR6 SSC 6
Flags        : 0b010010000
FileId       : 00000070
FileSize     : 00003000
FullName     : LMEMBAR 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : Display Present 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : I2C for Third Party Devices 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : I2C Device Address 1 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : I2C Device Address 2 6
Flags        : 0b000010000
FileId       : 00000070
FileSize     : 00003000
FullName     : I2C Bus speed 6
Flags        : 0b000010000
FileId       : 00000071
FilePath     : /home/rbe/fsp_prof_7
VirtualFileId: 10007407
FileSize     : 00003000
FullName     : FSP Profile 7
Flags        : 0b000000000
FileId       : 00000071
FileSize     : 00003000
FullName     : FIVR Data 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : HDA Subsystem Device ID 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : GT Subsystem Device ID 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : Physical Memory Population 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DQS Mapping 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DQ Mapping 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DQS pins interleaved 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : AC_PKG_PL1 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : AC_PKG_PL1 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : AC_PKG_PL2 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : AC_PKG_PL2 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DC_PKG_PL1 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DC_PKG_PL1 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DC_PKG_PL2 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : DC_PKG_PL2 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PSYS_PL1 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PSYS_PL1 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PSYS_PL2 Enabled 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PSYS_PL2 Time 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : RTD3_EN_CAPABILITY 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PSYS_ENABLE 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : Fan Control 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : ODM EPC: GT frequency/Voltage 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : ODM EPC: ICCMax/TjMax 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : VRAM_SR_CAPABILITY 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : Frequency Override 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : Audio enabled 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : PCIe Channel Equalization 7
Flags        : 0b011010000
FileId       : 00000071
FileSize     : 00003000
FullName     : P2SB function enable 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : GT Subsystem Vendor ID 7
Flags        : 0b010010000
FileId       : 00000071
FileSize     : 00003000
FullName     : HDA Subsystem Vendor ID 7
Flags        : 0b010010000
FileId       : 00000071
FileSize     : 00003000
FullName     : GDDR6 SSC 7
Flags        : 0b010010000
FileId       : 00000071
FileSize     : 00003000
FullName     : LMEMBAR 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : GTMMADDR Prefetch Capability 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : Display Present 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : I2C for Third Party Devices 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : I2C Device Address 1 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : I2C Device Address 2 7
Flags        : 0b000010000
FileId       : 00000071
FileSize     : 00003000
FullName     : I2C Bus speed 7
Flags        : 0b000010000
FileId       : 00000072
FilePath     : /home/rbe/fsp_prof_sel
VirtualFileId: 10007500
FileSize     : 00000020
FullName     : Profile Selector
Flags        : 0b011000010
FileId       : 00000073
FilePath     : /home/gfx_srv/aic_uid
VirtualFileId: 1001c500
FileSize     : 00001000
FullName     : AIC customer program unique ID
Flags        : 0b001001010
FileId       : 00000074
FilePath     : /home/gfx_srv/device_id
VirtualFileId: 10021100
FileSize     : 00000010
FullName     : Device ID
Flags        : 0b000000000
FileId       : 00000075
FilePath     : /home/mca/eom
VirtualFileId: 10020000
FileSize     : 00000008
FullName     : End of Manufacturing Enable
Flags        : 0b000000110
FileId       : 00000076
FilePath     : /home/mca/mca_oem_version
VirtualFileId: 1001f000
FileSize     : 00000040
FullName     : OEM FW Version
Flags        : 0b011000010
FileId       : 00000077
FilePath     : /home/fwupdate/oem_manuf_data_ver
VirtualFileId: 1001fc00
FileSize     : 00000020
FullName     : OEM Manufacturing Data Version
Flags        : 0b000000000
FileId       : 00000078
FilePath     : /home/pavp/hdcp_ports
VirtualFileId: 10070000
FileSize     : 00000008
FullName     : eDP Port Config
Flags        : 0b011000000
