Send this BIOS file.
To all UBU users.
Please just describe the problem and attach the BIOS file or link.
Example:
-The GOP Driver file is not being replaced
The version is not defined.
-<βBIOS fileβ>
Thank you all very much,
This is the FPT dumped full bios.
Dell Vostro 3670 2.33.zip (7.8 MB)
As a side note, when I downloaded your entire (a15) Modding.rar, the UBU_v1_80_a15.rar wouldnβt open, so I downloaded the UBU_v1_80_a15.rar individually, and it did open/extract.
-The intel EFI GOP Driver Xe file is not being replaced
I found the BIOS of both Z590 mobos share the same issue.
Sorry the BIOS file size is too big for the forum limitation. I linked it to MEGA cloud.
ASUS ROG Maximus XIII BIOS file link
I am aware of this problem of two different versions of the GOP,
Try the following:
- Open UBU.cmd
- Find string
31003700 - Change the entire line
set str_patt=310037000000000000000000
This should help you
Unfortunately, the microcode update hasnβt been working since version 1.80a14. ASRock Z790 Pro RSβ¦
The MMTool variant doesnβt seem to be in order.
Works with mmtool_a5.exe (v5.2.0.25).
I placed both MMT 5.2.0.24 and 5.2.0.25 directly into the UBU folder. This time, the script indicated it was using MMT 5.2.0.24 (which makes sense given my carryover thread post), and the microcodes were replaced.
Iβm still having the removed Padding file issue, but MC replacement did process in the UBU a15 folder with the inclusion of MMTool 5.2.0.24.
Still getting the EFI Realtek UNDI Driver - Unknown issue.
I completely forgot that AMI doesnβt want it to be distributed.
But thereβs a new problem.
Network Realtek modules are not being swapped. The CMD stops, see the image!
The unknown EFI problem is independent of MMTool. It is only responsible for replacing the files. Since that EFI part is unknown to UBU, it naturally does not offer anything instead. Even if it could replace it without problems.
But the UBU works exactly as it should. Hopefully you didnβt try this with MMTool, but without.
In general: BIOS can be modified in several rounds, not just one. If something does not work, you should try it with MMTool. If it doesnβt work, try it without. Itβs not complicated.
Without MMTool, it works. But thatβs not really a solution, is it?
As far as I understand, itβs about the AMD platform, where there were issues replacing the microcode.
The UEFI Replacer had worked for all modules (Intel) for me so far. But starting from version 1.80a14, it no longer doesβ¦
14a UEFIReplace v0.25.0 will be used:
Details: (open/hide by a click)
Main Menu [Current version in BIOS file]1 - Disk Controller
EFI Intel RST RAID Driver - 17.8.1.4572
EFI NVMe Driver present
2 - Video OnBoard
EFI GOP Driver SKL-AML - 9.0.1085
RAW GOP VBT SKYLAKE - 221
3 - Network
EFI Realtek UNDI Driver - 2.041
4 - Other SATA Controller
5 - CPU MicroCode
View/Extract/Search/Replace
S - AMI Setup IFR Extractor
O - Option ROM in other GUIDs
0 - Exit
RS - Re-Scanning
A - About
Choice:
14a MMTool 5.2.0.24 used:
2 - Video OnBoard
3 - Network
5 - CPU MicroCode
0 - Exit
RS - Re-Scanning
A - About
Choice:
westlake, 14a had no EFI issue running with and without MMTool. Iβm not posting choice 3, but it shows a newer (2.067) replacement option.
Edit 1: The Realtek folder under Files in 15a is identical to 14a.
Edit 2: Full 14a run with MMTool:
Scanning BIOS file backup.bin.
Please waitβ¦
Manufacturer - Default string
Model - Default string
BIOS release - 5.13 08/31/2023
BIOS version - 00.30
BIOS platform - AMI Aptio 5
[EFI Drivers - Find and Extract]
Intel RST GUID 8C2E10DB-280F-4D4C-9B6E-C4C2A8A4C629
Intel GOP SubGUID D8248140-88B5-4C14-9E9F-FD1CFA9D071E
AMI NVMe GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Realtek Undi GUID 4953F720-006D-41F5-990D-0AC7742ABB60
Intel GOP VBT GUID 56752DA9-DE6B-4895-8819-1945B6B76C22
[OROM - Find and Extract]
VBIOS in GUID FD41D244-F0FB-4FD0-8FD6-4276BD4323D0
OROM in GUID 7C3B8701-2C3B-49FA-A529-F31D441265B1
OROM in GUID 6357578A-52D1-4517-BE96-10391404754C
OROM in GUID 914AB3BE-A2C2-463A-B77D-F820FBBA180E
UEFIReplace v0.25.0 will be used.
MMTool Aptio v5.02.0024
Waiting for 3
Main Menu
1 - Disk Controller
2 - Video OnBoard
3 - Network
5 - CPU MicroCode
0 - Exit
RS - Re-Scanning
A - About
Choice:5
βββββββββββββββββββββββββββββββββββββββββββ
β MC Extractor v1.94.2 r276 β
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β Intel β
βββ¬ββββββββββ¬ββββββ¬ββββββββββ¬βββββββββ¬βββββββββββ¬ββββββ¬ββββββββ¬ββββββββββ¬βββββ’
β#β Type βCPUIDβPlatformsβRevisionβ Date βStateβ Size β Offset βLastβ
βββΌββββββββββΌββββββΌββββββββββΌβββββββββΌβββββββββββΌββββββΌββββββββΌββββββββββΌβββββ’
β1βMicrocodeβ906EAβ 22 (1,5)β F4 β2023-02-23β PRD β0x19800β0x1D50400βYes β
β2βMicrocodeβ906EBβ 02 (1) β F4 β2023-02-23β PRD β0x1A000β0x1D69C00βYes β
β3βMicrocodeβ906ECβ 22 (1,5)β F4 β2023-02-23β PRD β0x19C00β0x1D83C00βYes β
β4βMicrocodeβ906EDβ 22 (1,5)β FA β2023-02-27β PRD β0x1A000β0x1D9D800βYes β
βββ§ββββββββββ§ββββββ§ββββββββββ§βββββββββ§βββββββββββ§ββββββ§ββββββββ§ββββββββββ§βββββ
These microcodes are in your BIOS file
GUID 17088572-377F-44EF-8F4E-B09FFF46A070
[Intel CPU MicroCode]
F - Find and Replace from MCUpdate.txt
V - View/Edit MCUpdate.txt
U - Find and Replace from USR_mCode.txt
E - View/Edit USR_mCode.txt
[MC Extractor]
X - Extract all CPU microcodes
S - Search for available microcode in DB.
0 - Exit to Main Menu
Choice:F
CPUID 906EA found.
Files\Intel\mcode\1151v2\cpu906EA_plat22_ver000000F8_2024-02-01_PRD_47291E44.bin
Checksum correct.
CPUID 906EB found.
Files\Intel\mcode\1151v2\cpu906EB_plat02_ver000000F6_2024-02-01_PRD_9F8FF344.bin
Checksum correct.
CPUID 906ED found.
Files\Intel\mcode\1151v2\cpu906ED_plat22_ver00000100_2024-02-05_PRD_78F54C97.bin
Checksum correct.
Generate FFS with Microcode
β Intel β
βββ¬ββββββββββ¬ββββββ¬ββββββββββ¬βββββββββ¬βββββββββββ¬ββββββ¬ββββββββ¬ββββββββ¬βββββ’
β#β Type βCPUIDβPlatformsβRevisionβ Date βStateβ Size β OffsetβLastβ
βββΌββββββββββΌββββββΌββββββββββΌβββββββββΌβββββββββββΌββββββΌββββββββΌββββββββΌβββββ’
β1βMicrocodeβ906EAβ 22 (1,5)β F8 β2024-02-01β PRD β0x19C00β 0x18 βYes β
β2βMicrocodeβ906EBβ 02 (1) β F6 β2024-02-01β PRD β0x1A000β0x19C18βYes β
β3βMicrocodeβ906EDβ 22 (1,5)β 100 β2024-02-05β PRD β0x1A000β0x33C18βYes β
βββ§ββββββββββ§ββββββ§ββββββββββ§βββββββββ§βββββββββββ§ββββββ§ββββββββ§ββββββββ§βββββ
Note: Microcode #1 is not in the database! You can help this project
by sharing it at https://win-raid.com forum. Thank you!
Note: Microcode #2 is not in the database! You can help this project
Note: Microcode #3 is not in the database! You can help this project
These microcodes will be entered into your BIOS file
R - Start replacement
A - Start replacement Alternative with MMTool
0 - Cancel
Choice:R
[Preparing for replacement]
BIOS file backup
[Replacement]
mCode FFS: parseIntelImage: unknown flash descriptor version 0.0
parseVolume: non-UEFI data found in volumeβs free space
parseSection: section with unknown type 00h
parseSection: section with unknown type 1Ah
parseFile: non-empty pad-file contents will be destroyed after volume modifications
reconstructIntelImage: discovered unexpected 0.0 descriptor version, trying to continueβ¦
File replaced
Real Pointer
FIT Offset - FFD50100 == FFD50100
Real FIT
01 mCode Offset - FFD50298 != FFD50400
Fixed - FFD50298
mCode Size - 19C00
02 mCode Offset - FFD69E98 != FFD69C00
Fixed - FFD69E98
mCode Size - 1A000
03 mCode Offset - FFD83E98 != FFD83C00
Fixed - FFD83E98
mCode Size - 1A000
Changes FIT saved
Press any key to continue . . .
β Intel β
β1βMicrocodeβ906EAβ 22 (1,5)β F8 β2024-02-01β PRD β0x19C00β0x1D50298βYes β
β2βMicrocodeβ906EBβ 02 (1) β F6 β2024-02-01β PRD β0x1A000β0x1D69E98βYes β
β3βMicrocodeβ906EDβ 22 (1,5)β 100 β2024-02-05β PRD β0x1A000β0x1D83E98βYes β
[MC Extractor]
Choice:
Edit by Fernando: Postβs length shrinked by putting the details into βspoilersβ
:lol:
The bios is new, the sizes are 32, and the problems are old - there is no free space in the volumes.
If you donβt want to use MMTool to replace files then:
- Open UBU.cmd
- Find string
::efi_rebuild - Changed
if %mmtool%==1 to 0
@SoniX Hi, any new info about adding new option rom into the bios?
Also I tested ubu a15 with βif %mmtool%==β 1 and 0, I just updated the realtek network. At 79% Gigabyte QFLASH says βINVALID BIOS IMAGEβ for the new bios files:
Hi,
Starting with Z400 series motherboards, there is no way to flash directly using onboard tools. The board manufacturerβs signature is altered by the UBU modification.
Either you flash the BIOS chip using a flash module (programmer) or you use βFPTw.exeβ via Intel CMS tools from version 16 onwardsβ¦
"Update your BIOS with UBU, and save it as βBios.binβ.
Run the Write.bat with administrator rights."
Flash.zip (471.5 KB)
@RoadrunnerDB
I tried it:
Reading HSFSTS register⦠Flash Descriptor: Valid
--- Flash Devices Found --- ID:0xC22019 Size: 32768KB (262144Kb)Error 167: Protected Range Registers are currently set by BIOS, preventing flash access.
Please contact the target system BIOS vendor for an option to disable
Protected Range Registers.FPT Operation Failed.
This is caused by the BIOS Lock variable set to 0x01 (Enabled):
Code:
BIOS Lock, VarStoreInfo (VarOffset/VarName): 0xA12
How to set the BIOS Lock variable to 0x00 (Disabled):
- Make sure you have following values set in BIOS:
- Legacy Support: Disable
- Secure Boot: Disable
- Take USB stick and format to FAT32
- Create directory structure EFI\Boot
- Download bootx64.zip (765.2 KB)
- Put BOOTX64.EFI into Boot directory
- Boot from this USB stick
- Run command: setup_var 0xA12 0x00
- Run command: reboot
9.Attempt to write the modified BIOS again using FPTw.exe.
"Here, Gigabyte has shut things down. Unfortunately, BIOS modding has become a popular activity, leading to considerable damage.
On my motherboard βASRock,β this restriction is not active."
A post was split to a new topic: Using the UEFITool_NE_A68
Thank you very much for replying . I have tried both UBU a14 and a15, and , yes , UBU could replace Intel EFI GOT Xe driver after modifying the strip. However, both Gigabyte Z590 Aorus Elite and Asus Maximus XIII will experience boot failure after flashing the modified BIOS with EFI GOP Xe driver replaced. If the GOP Xe driver remains untouched, everything will be fine. I can confirm it because I have experimented it on both motherboards for almost 10 times. Besides, the UBU always generates 3 GOP Xe drivers as shown in the attachment of screenshot. I donβt know if repeated Xe drivers count for boot failure because the debug code of ASUS mobo indicates it is I/O related. Again , the link of the BIOS.
3 GOP is bad. Iβll think about it,
