EFI AMD GOP Driver - 2.8.0.0.0_signed (>2.7.0.0.0_signed)
OROM VBIOS Picasso - 016.002.000.011.048929 (>016.002.000.010.000000)
This is the BIOS file of Acer ATC-220
An error occurred after using UBU
Already got a solution from #519
P11-A4.rar (2.08 MB)
I used UBU first time and i will Update my Bios. Here some Screenshots. Microcode i see new Update, Disk Controller i have the latest but Network and VideoOnboard i see nothing. Which file i need for both?
My Board is a Gigabyte z390 Designare and latest Final Bios is F8.
@jordanpchome
See #519
Add:
Fix in 1.75.3.2
@Lost_N_Bios
I have reached out to Asrock support. They responded with usual BS how it does not need to be updated. Called them out on it. Flashed my hex edited bios. Willing to share it with others. if they need it.
@honeybadger - so your edit worked OK? If yes, and you didn’t touch that header I was concerned with, then my edit would be OK too, but not done in same way you mentioned since nothing needed trimmed.
If you want my edit let me know and I will send to you.
Can where help me to find the latest Video Onboard update for my Board (see Screenshot above)?
@Lost_N_BIOS
@SoniX
Thx for the offer. At this point I don’t need your edit since the one I have Hex edited worked. If SoniX is able to add support/update/patch the rest of the bios with UBU then I could use fully updated BIOS ROM.
file.php?url=http%3A%2F%2Ffiles.homepagemodules.de%2Fb602300%2Ff16t4531p95626n2.jpg&r=1&content=J4205_bios_updated_to_3C_MC_Code_version
@SoniX
Raid ROM and EFI modules version 6.2.0.1034 are availabe in their respective threads.
is same version for VROC VMD modules available???
Yes should be available.
VROC (old name IRSTe) consists of 6 files:
RaidDriver
RaidOrom
sSayaDriver
sSataOrom
VMD and VMDD
But it may well be that the VMD/VMDD files may not be in the BIOS file.
In addition, I do not know how users extract new files.
Therefore, in UBU 1.76, I started the implementation of the new "Share Files" feature. Which will allow you to save files in a separate folder for archive or exchange between users.
The first test version is available in the Cloud. In the near future there will be a second test implementation.
Here anybody can download the latest 6.2.0.1034 VROC VMD modules:
https://mega.nz/#!J7BRGKDR!KB_GbCXuWekEg…GwwHMeG8w5j2nnI
Hello Lost_N_BIOS,
today i odered such an ASrock j5005 and while reading around about this weird TXE jumper thing i found these posts. I couldn’t use UBU with the available file to update µC so i ask if you may have some time to do a new one for us wiith the recent 32 µC?
Cheers!
@SoniX
MC 65 is not booting Windows in my Asus Omega Bios…
@pokuly - before I do anything, message that user and see if he ever tested that BIOS.
@SoniX
The SsataDriver.efi is being updated along with the RaidDriver.efi for RSTe in the latest UBU’s???
Checking the total files replaced seems it is not being updated in my Asus R6E Omega…
@vmanuelgm :
The Intel RSTe BIOS modules will only be updated, if the UBU user has put the desired modules with the correct file names into the related UBU subfolder named "RSTe_VROC".
@Fernando
Thanks for your reply. Yep, I usually put the 2 efi files and the 2 vroc vmd files (with their respective proper names) in their specific directory under UBU.
But Once UBU updates the modules, only 5 total updates are visible, when 6 should be the total.
I’ve uploaded a video of this issue:
https://mega.nz/#!Z3oEjCAC!KbpcLiE3VPunM…ofaG31etAp3gUjM
Tried other bios’s and a total of 6 updates are done, while in my Omega only 5.
@vmanuelgm
Link on BIOS file.
Added
Asus R6E - Omega BIOS 0802
1) There are no sSATA files in this BIOS, therefore these files are not updated.
2) The OROM IRSTe SATA file is located in another GUID and cannot be replaced with standard tools, only manually.
@SoniX
So, in order to update the IRSTe OROM, what steps should I follow???
Thanks in advance!!!
@SoniX #537 #538 #539
My bios looks the same as OMEGA in UBU, So does this apply to my bios as well ?
"The OROM IRSTe SATA file is located in another GUID and cannot be replaced with standard tools, only manually."
https://dlcdnets.asus.com/pub/ASUS/mb/LG…E-ASUS-2002.zip
Steps to update manually ?
Thanks,
Biozzz
