In your last BIOS 1.70, Realtek LAN: - OROM v3.00 beta - EFI v2.46 beta 1 I configured OROM to replace. It remains to find a common pattern for finding EFI.
Hi, I’ve problems with 0.8.0.5 intel efi rom which doesn’t display anything inside UEFI bios, while with EFI Intel Gigabit UNDI v0.0.24 no problems at all.
@panosxidis : An update of the Ethernet BIOS modules has no effect on your system unless you are going to boot your PC off the related LAN connection (e.g by using the Wake-on-LAN option).
@panosxidis : Only the manufacturer of the Ethernet Controller knows the reason for an update of a specific LAN BIOS module. You should better ask him. Changelogs of BIOS modules are usually not published.
Dear SoniX, the UBU by mega.nz link or cloud.mail.ru link now I couldn’t download it. Could you send me UBU by email directly? Or try using new a net disk mediafire.com , mediafire.com may is only net disk I could download in contury now. And in this thread, UBU backup download link is also mega link now([Tool Guide+News] “UEFI BIOS Updater” (UBU)) Thanks.
