[Discussion] UBU Tool related Questions/Reports/Suggestions
New AMD Video
AMD GOP Driver v2.15.0.17.10
AMD VBIOS Cezanne & Renoir v017.010.000.028.000000
AMD VBIOS Picassso & Raven/Ravwen2 v016.002.000.012.000000
More tnx to @Ruin
and fix "_List_vbios.txt"
Edit:
Del file. Upd to 1.79.12
Again… :slight_smile:
BIOS file
2 options for fixing
"Files\AMD\VBIOS_List_vbios.txt"
1 - disabled (#) line with "Van Gogh"
or
2 - temporarily replace “vbios_163F.dat” with "_List_vbios.txt"
Edit:
Fixed in 1.79.12
Two RKL modules, in case you don’t have them. It seems that Drvver needs an update.
ubu.rar (163 KB)
First of all, thanks a lot for the effort. I used the tool, and so far, no complaints and everything I did, it worked and flashed the updated BIOS. Then I had a look at the MCUpdate.txt file that I downloaded from the linked MEGA repository and found this lines:
# Latest
306C3 1150\cpu306C3_plat32_ver00000028_2019-11-12_PRD_DBD4CFD1.bin
# or non-K
#306C3 1150\cpu306C3_plat32_ver00000007_2013-01-21_PRD_4F685CCF.bin
About the commented out line, what’s the purpose of that, can I find some info about it ? What if I replace one with the other ?
BIOS file
v17 - RKL? Strange…
Edit:
Updated DrvVer, but I have it recorded as TGL.
@westlake
Try 1.79.12.1
@SoniX
The PCH/SoC of 400-series is Comet Point (CMP) but the PCH of 500-series is Tiger Point (TGP). Rocket Lake (RKL) works at both 400 and 500-series. Tiger Lake (TGL, CPU) is not the same as Tiger Point (TGP, PCH/SoC). When it comes to the TGP PCH/SoC architecture, we have had only LP platforms so far (TGP-LP). The H platform will be introduced with the 500-series boards (TGP-H).
bump for #1562 in case it got missed.
Friends!
Happy New Year everyone!
Health, happiness and fulfillment of desires.
Happy and Healthy New Year to you as well SoniX
OROM Intel Boot Agent GE - 1.5.84
BIOS file
@westlake
OROM is in the second BIOS, in order to replace it you need to split the main BIOS file into two.
Use Splut from EDK2
1
2
3
split -f <main BIOS> -s 16M
Replace the required modules.
Then combine 2 BIOS files into one.
1
2
copy /b <BIOS part1>+<BIOS part2> <maub BIOS>
I’m using UBU v1.79.10, trying to modify this BIOS: http://www.huananzhi.com/html/1//184/185/380.html (Download link: http://www.huananzhi.com:8080/driversdow…12-6%20BIOS.rar )
However, UBU reported a strange version number for the network: "OROM Realtek Boot Agent GE - LIDv"
What’s the reason of this?
@bsdko
Do not pay attention. This is the same OROM, just another match was found in the file for the version
#1592 - There are a couple of ideas. I’ll think about which one to implement.
#1594 - fixed
EFI GOP Driver Unknown - Unknown
(17.0.1039?)
IntelGopDriver.rar (65.9 KB)
GOP 18.0.1034 (I think). This is for Jasper Lake (JSL), the successor of Gemini Lake (GLK).
JSL.rar (55.1 KB)
I noticed that the Gigabyte A520I AC has unusual network drivers.
Different version and also the old version 1.37
What’s that got on with it?
Hi there, I downloaded the latest UBU 1.79.12.1 and started using it to update a BIOS file, when
I went to look at changing the CPU code this fault showed up, what am I doing wrong here?
