Intel(R) Active Management Technology - PRESENT/ENABLED Intel(R) Capability Licensing Service - PRESENT/ENABLED Protect Audio Video Path - PRESENT/ENABLED Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Intel(R) AMT State: Enabled Cryptography Support: Enabled Last ME reset reason: Global system reset Local FWUpdate: Enabled BIOS Config Lock: Enabled GbE Config Lock: Enabled Host Read Access to ME: Disabled Host Write Access to ME: Disabled SPI Flash ID #1: C22018 SPI Flash ID VSCC #1: 20052005 SPI Flash BIOS VSCC: 20052005 BIOS boot State: Post Boot OEM Id: 00000000-0000-0000-0000-000000000000 Link Status: Link up System UUID: … MAC Address: … IPv4 Address: 0.0.0.0 IPv6 Enablement: Disabled Privacy/Security Level: Default Configuration state: Not started Provisioning Mode: PKI Capability Licensing Service: Enabled OEM Tag: 0x00000000 Slot 1 Board Manufacturer: Unused Slot 2 System Assembler: Unused Slot 3 Reserved: Unused M3 Autotest: Disabled Wireless Micro-code Mismatch: No Wireless Micro-code ID in Firmware: 0x0082 Wireless LAN in Firmware: Intel(R) Centrino(R) Ultimate-N 6205 Wireless Hardware ID: No Intel WLAN card installed Wireless LAN Hardware: No Intel WLAN card installed Localized Language: English Independent Firmware Recovery: Disabled
Intel(R) MEInfo Version: 8.1.56.1541 Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E000255 FW Status Register2: 0x61000100
CurrentState: Normal ManufacturingMode: Enabled FlashPartition: Valid OperationalState: M0 with UMA InitComplete: Complete BUPLoadState: Success ErrorCode: No Error ModeOfOperation: Normal ICC: No valid OEM data, ICC not programmed
Intel (R) Clock Commander Tool Version: 8.1.40.1456 Copyright (C) 2011 Intel Corporation. All rights reserved.
ConnectClient() failed with status: 8205 HECI INITIALIZATION FAILED
Intel(R) MEManuf Version: 8.1.56.1541 Copyright(C) 2005 - 2014, Intel Corporation. All rights reserved.
Get FWU info command…done
Get FWU version command…done
Get FWU feature state command…done
Get ME FWU platform type command…done
Get ME FWU feature capability command…done Feature enablement is 0xC7A5445 gFeatureAvailability value is 0x1
Request Intel(R) ME test result command…done
ME initialization state valid ME operation mode valid Current operation state valid ME error state valid Verifying FW Status Register1…done
Request Intel(R) ME test result command…done vsccommn.bin was created on 04:35:50 08/08/2012 GMT SPI Flash ID #1 ME VSCC value is 0x2005 SPI Flash ID #1 (ID: 0xC22018) ME VSCC value checked SPI Flash ID #1 BIOS VSCC value is 0x2005 SPI Flash ID #1 (ID: 0xC22018) BIOS VSCC value checked FPBA value is 0x0 No Intel vPro Wireless device was found
Request Intel(R) ME Full BIST test command…done
Get Intel(R) ME test data command…done Total of 26 Intel(R) ME test result retrieved
Policy Kernel - Power Package: Live Heap Test - Passed
Common Services - LAN: Connectivity to NIC in M3 - Passed
Policy Kernel - ME Configuration: Wlan Power Well - Passed Policy Kernel - ME Configuration: PROC_MISSING - Passed Policy Kernel - ME Configuration: M3 Power Rails Available - Passed Policy Kernel - ME Recovery: ME Recovery mode check - Passed Policy Kernel - Embedded Controller: Power source type - Passed Policy Kernel - SMBus: Read byte - Passed
Common Services - General: Low power idle timeout - Passed Common Services - Privacy Level: Valid Privacy Level settings - Passed Common Services - EHBC State: Valid Embedded Host Based Configuration (EHBC) state - Passed Common Services - General: WLAN enabled only on mobile or desktop - Passed Common Services - General: Vlan not enabled on mobile - Passed Common Services - Provisioning: Both PID and PPS are set - Passed Common Services - Provisioning: MEBX password set when PID and PPS set - Passed Common Services - EHBC State: EHBC and Privacy Level states compatibility - Passed Common Services - LAN: Connectivity to NIC in M0 - Passed
AMT - Power: Valid LAN power well - Passed AMT - Power: Power-package 2 supported - Passed
Clear Intel(R) ME test data command…done Get EPID Group ID command…done
@plutomaniac@Lost_N_BIOS@lfb6 Thanks for your help so far! I was able to update boot block via SPI and the v2 cpu works great.
Regarding to "no valid OEM data" I tried reflashing BIOS, resetting CMOS, greset, fpt… no success. After reading this thread:
the last thing I tried was a downgrade to a version where FIT and ME versions match (BIOS 2.55) For safety, first with fwupdlcl and then with fpt again, followed by greset. As it was still manufacturing mode, I closed it with closemnf. This time closemnf said “Setting the ME Manufacturing Mode Done bit was successful” and I think this was only possible because I set all regions to read/write in the descriptor region before closemnf (…they were already in intel recommended mode or similar…)
The machine is running fine now with ME enabled, no manufacturing mode, v2 cpu but still “No valid OEM data, ICC not programmed”
I don’t care Many thanks again and please tell me if there is anything I could try out or if this message maybe is a bug or something.
Yes, ignore that if you know the BIOS and Engine firmware are ok. This is probably due to bad BIOS design from OEM, not reporting something finished initializing to the Engine co-processor or similar. I remember another motherboard a few years ago (Z170 ?, user jjxaker ?) which had the same issue even though the SPI image was stock/healthy. It’s rare to see that but you can ignore it in your case.
It might have to do with the buggy tools for C60x/Patsburg chipset. FITc shows different values for ME settings for this bios, too, when either using ME region or complete image. Maybe MEInfo gets wrong values, too, when ckecking?
Would be ‘interesting’ to check if a self- cleaned ME would solve the problem/ give different results, but I wouldn’t bother if everything seems to work fine
What do you mean by “self-cleaned”? Manually transferring settings from two FITC windows? Things is, with how broken FITC v8 was at PBG images, we can’t trust that the info it displays is proper so transferring them ourselves does not change anything really. From my limited testing at the time, I had “concluded” that the settings we see when loading a bare ME region are (more ?) proper compared to the ones from the full SPI image. You might be right though, this error could be because of FITC v8 + PBG but I think I’ve seen that message being displayed constantly at a SKL platform so maybe not? Ahhh, who knows…
I’m sorry, “self-cleaned” was meant like ‘using the tools available for creating and testing, which were supposed to work together’ and check if it’d be possible to get a ME region which passed all checks.
But I totally agree, there’s no meaning in this. HP should’ve had the latest tools (if there might be a newer version) and they’d know best how to create a working bios for this PC… And with a buggy toolset there’s possibly no way to get ‘correct’ settings since one doesn’t know which values were the right ones…
So far it’s unclear how to connect sop16 clip to the EZP2019. Is there adapter available with the clip? I don’t have 16pin clip just 8pin that came with the programmer.
The guide is unfinished a bout the Upgrading ME firmware v7 → v8 in OS Seems like this part of the guide is for Z620?
Follow up -
I did the following: starting from a dump v3.96 bios from my board, then replaced the ME and Boot Block with codes from the official v.3.96 BIOS (“J61_0396.BIN”). Flashed the modified BIOS into the board (using PI 3+B). Now I have 2013 boot block and 8.1.x ME. Everything is working. The only issue is that “ME is in manufacturing mode” msg during booting.
