Hi all ,
I have exact bios with differents version V1.29 to V1.4 -->ok
I have open the V1.31 dumped bios with amibcd and modify all in " user " for see all hiden parameters -->ok
I have erase write et blanck and verify with the V1.31–>ok
I have reboot my laptop and no effect in my bios -->Problem
All dumped Bios are in my folder : https://drive.google.com/drive/folders/1…bU0EKVIAT–mGd8 I upload the file " Dumpv131full.rom" is it good ?
Identify the bios/spi chip correctly and his voltage required.
As long ur getting FFFFFFFFFFFFFFFFFFFFFF, its not a valid dump.
Its not always that easy to work with different chips and behaviors of supplied current and/or not.
Try other software solutions and versions.
And what exactly is the problem that u want to solve…u want to mod the bios and flash it?
Do u know what variables u should mess with, in AMIBCP?
[Guide] Using CH341A-based programmer to flash SPI EEPROM
all is ok for dump and upload
but when i reboot my laptop no change are avalaible ?
can you modify my biosmod ? look the name in the picture and download from my personal folder (dumpv131full.rom) → https://drive.google.com/drive/folders/1X6Z1Jq8mijsjOcIcKbU0EKVIAT--mGd8
big thx
I’ve looked ur dump and checked bios version and integrity.
Im not qualified to to mod ur bios upon what u request.
I noticed that u already made a [REQUEST] on the appropriate topic, wait for a answer.
thx for reply,
this night , i trie again with Ch341a programmer , if i have a good biosmod it’s Super !
thx
