Flash extracted .bin from .fd
Hi, I analyzed a BIOS.fd from a Insyde BIOS update for my Lenovo laptop. I used an extractor to get the .bin file from the BIOS.fd. I used HxD to compare the .bin with the .fd. The only difference is that the .bin is missing stuff at the beginning and at the end. I attached the whole .fd, the data of the beginning and the end of the .fd file. The extracted .bin file has the size 16,777,216 bytes just as a complete BIOS dump with FPTW (I use FPTW.exe -d Dump.bin). Can I flash my BIOS chip with a flash programmer with the extracted BIOS.bin from the BIOS.fd file? And what would happen?
Files
Why did you post your question into the “Off Topic” section?
It should better be located within the “BIOS Modding” section.
