I built a WinUSB driver for this programmer to use in WinXP x86/x64.
Installation Guide:
- if we already have some CH341A drivers in the system then you need to uninstall them and also remove the oemX.inf file from WINDOWS\Inf because after reconnecting WinXP will automatically install those that were
- we are now installing the update Microsoft WinUsb 2.0 WINUSB_UPDATE_XP-SRV03.exe for our platform, i.e. x86 or amd64
- we connect the programmer under USB and in the window that appears, choose manual installation and indicate the folder with my driver that is where the file CH341A.inf
- after installation, the driver will be in Device Manager in the Interface section
D:\Pobieranie\flashromw>flashrom
flashrom p1.0-109-g3bcd922 on Windows 5.2 (x86)
flashrom is free software, get the source code at https://flashrom.org
Calibrating delay loop… OK.
Found Winbond flash chip “W25Q64.V” (8192 kB, SPI) on ch341a_spi.
No operations were specified.
flashrom_WinUSB.zip
