This is the first dump.
p.s.
You can see in the previous archive that I changed important settings to be the same like this one.
First off, your dump/current config has AMT disabled. But even when enabled, the settings don’t appear. These old FITC worked in strange ways. The OEM could probably set the AMT settings only at first image creation. I suggest for you to take the latest RGN, open it in FITC, manually adjust settings from your dump + AMT etc enabled, build a ME region only (Number of Components to 0), padd the result so that it has a size of 0x2F7000 and flash it via “fpt -me”. Otherwise, replace the ME region of the dumped SPI with the one that you just created (change FD settings there) and flash it all together.
Do you think this ME I generated from latest RGN is it correct ?
thank you
edit:
ok I added FF from the end until the file length it is 2F5000 like the one I read it with fpt -me and now I have to flash it ?
ME-v01.rar (1.22 MB)
Yes I think it looks just fine. Attached is the padded to 0x2F7000 ME region. That size is taken from your FD which points to the ME region starting offset (0x3000) and size (0x2F7000).
me.rar (1.21 MB)
I read with FPT -ME region after each update and each time the file length it is 3.100.627 = 2F5000.
I think it is safe to stick with the shorter one ?
Update:
flashed ME-v01 generated from RGN only with the same result, No CIRA capability.
After flash I dumped the full flash FL-V01A and checked in FITC and everything it looks good.
Attached in case somebody need a good FLASH to fix his E5730.
No idea maybe 82801JD is not supporting CIRA, maybe BIOS support it is required or maybe other settings in eprom… who knows.
FL-V01A.BIN.zip (1.84 MB)
It’s good thing you uploaded a clean dump for someone else in need. As for CIRA, it is probably as you said but I wouldn’t know exactly.
I found something on this docs:
https://software.intel.com/en-us/blogs/2…-manageability/
https://software.intel.com/sites/managea…elplatforms.htm
Intel AMT SKU
CIM_RegisteredProfile InstanceID = Intel® ME:CIM_RegisteredProfile:Intel® AMT
CIM_ComputerSystem ElementName = Intel® AMT Subsystem
Intel Standard Manageability SKU
CIM_RegisteredProfile InstanceID = Intel® ME:CIM_RegisteredProfile:Intel® Std. Mgt.
CIM_ComputerSystem ElementName = Intel® Std. Mgt.
This E5730 now report:
Item #0:
CreationClassName = CIM_ComputerSystem
Dedicated = 32
ElementName = Managed System
EnabledDefault = 5
EnabledState = 2
HealthState = 5
Name = ManagedSystem
NameFormat = Other
OperationalStatus = 0
RequestedState = 12
Item #1:
Dedicated = 14
EnabledDefault = 5
EnabledState = 5
HealthState = 5
Name = Intel® AMT
NameFormat = Other
RequestedState = 12
Item #0:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Base Desktop and Mobile
RegisteredName = Base Desktop and Mobile
RegisteredOrganization = 2
RegisteredVersion = 1.0.0
Item #1:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Software Inventory
RegisteredName = Software Inventory
Item #2:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Boot Control
RegisteredName = Boot Control
Item #3:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Power State Management
RegisteredName = Power State Management
Item #4:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Indications
RegisteredName = Indications
Item #5:
AdvertiseTypes = 2
OtherRegisteredOrganization = Intel®
RegisteredName = Intel® Std. Mgt.
RegisteredOrganization = 1
RegisteredVersion = 5.2.71
Item #6:
AdvertiseTypes = 2
InstanceID = Intel® AMT:Sensors
RegisteredName = Sensors
Item #7:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Fan
RegisteredName = Fan
Item #8:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Power Supply
RegisteredName = Power Supply
Item #9:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:CPU
RegisteredName = CPU
Item #10:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:System Memory
RegisteredName = System Memory
Item #11:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Physical Asset
RegisteredName = Physical Asset
Item #12:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Simple Identity Management
RegisteredName = Simple Identity Management
Item #13:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Role Based Authorization
RegisteredName = Role Based Authorization
Item #14:
AdvertiseTypes = 2
InstanceID = Intel® ME:Common Services
RegisteredName = Common Services
Item #15:
This report is for am Lenovo M58p that support CIRA:
Item #0:
AdvertiseTypes = 2
Item #1:
AdvertiseTypes = 2
Item #2:
AdvertiseTypes = 2
Item #3:
AdvertiseTypes = 2
Item #4:
AdvertiseTypes = 2
Item #5:
AdvertiseTypes = 2
InstanceID = Intel® AMT:Remote Access
RegisteredName = Remote Access
Item #6:
AdvertiseTypes = 2
InstanceID = Intel® AMT:Audit Log
RegisteredName = Audit Log
RegisteredVersion = 4.0.0
Item #7:
AdvertiseTypes = 2
Item #8:
AdvertiseTypes = 2
RegisteredName = Intel® AMT
RegisteredVersion = 5.2.50
Item #9:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:User Initiated Connection
RegisteredName = User Initiated Connection
Item #10:
AdvertiseTypes = 2
Item #11:
AdvertiseTypes = 2
Item #12:
AdvertiseTypes = 2
Item #13:
AdvertiseTypes = 2
Item #14:
AdvertiseTypes = 2
Item #15:
AdvertiseTypes = 2
Item #16:
AdvertiseTypes = 2
Item #17:
AdvertiseTypes = 2
Item #18:
AdvertiseTypes = 2
InstanceID = Intel® AMT:CIM_RegisteredProfile:Profile Registration
RegisteredName = Profile Registration
If that profile it is based of the key from the settings then it can be changed to full AMT… with correct key.
Until now I found this keys and I tested first one without success, it can be found in the last dump:
Remote Connectivity Service Enabler Name = Intel Client Board Operations
Remote Connectivity Service Enabler Id = 1256F688-96F3-4FA3-81-8A-4E-ED-35-DB-18-61
Remote Connectivity Service Enabler Name = HP Business PC Group
Maybe it is linked with ethernet MAC ?
And now to conclusion:
"Intel AMT / Intel Standard Manageability – Intel Active Management Technology (Intel AMT).
If the system does not meet the minimum system requirements for Intel AMT, only Intel Standard Manageability will be selectable."
Q43 chipset -> Intel SM ( like Esprimo 5730 have )
Q45 chipset -> Intel AMT ( like Lenovo M58p have )
MEBx v4-8 docs
AMT upgrade
Hi. I’ve problem since i update bios with latest file from fijitsu site. Fan are all 100%.
I dont have touch cpu and tested all the bios version, but fan are allways full speed.
i’ve tried to update microcode, but nothing.
Can you help me ???
Thanks
