oh yes
I also dont have a backup bios
I did a bios update and that messed everything up
cheers
@Tonnage - I believed you it was damaged, just wondered/asked how/what happened and if you were sure only the programmer got damaged.
Yes, ignore the exception and continue, many of them do that for me. Use 1.30 or 1.34, as mentioned, and tested shown above.
1.34 is in the link I always give out, probably earlier in this thread too, but here it is again
http://s000.tinyupload.com/index.php?fil…257455007472602
I can help you fix a BIOS with serial and your LAN MAC ID once you make a backup, messed up or bricked doesn’t matter, do the usual backup until you get a good copy of the backed up BIOS (It wont be empty)
