Gigabyte G5KC brick
Help!
When starting the laptop, the keyboard lights up for a second and the laptop turns off. The process happens constantly until you get the battery.
Can’t get into bios. Cyclic reloading and nothing else.
I suspect it’s a bios problem.
What are the possible fixes?
What makes you think it’s a bios problem?
What was done before brick? Undervolting? Firmware updates? Trying to flash a modded bios? Other mods?
Flashed bios. so I’m pretty sure that’s the problem.
CH341 programmer, read the firmware from the chip (do at least 2 100% identical dumps and check the structure with UEFIToolNE) and post it. Do you have a link to a stock bios-region or firmware?
Follow this link to find the official versions for this model:
https://www.aorus.com/laptops/G5--RTX-30-Series/Support
The problem is that this programmer is not at hand now (I ordered it. Should come soon)
Gigabyte provides at least a complete firmware image, but by simply flashing this image you’d loose the machine specific data (MAC, serial…)
Don’t forget to check for spi chip voltage. .
