[Guide] Clean Dumped Intel ME/TXE Regions with Data Initialization
Look into this archived thread, see #12.
For the errors during cleaning- you have to follow the guide really “to the letter”! But since correct bios settings / bios support seems to be required, too, it’s not enough to have PTT ‘enabled at startup’ in ME.
Yes, I have configured the bios. The first thing I tried was in that post. How didnt work I started to modify the bios with amibcp from nothing in meinfo about ptt to enabled in ME but still disabled in fpf(attachted file in previous post)
this is the problem from the previous post
this is to show how ptt is activated but still showing fpf ptt disabled and nothing in windows
@Lavand Please post a picture of the last lines of your MEInfo- output. The last lines are difficult to read if posted as text.
I should look like this:
If the PTT really is disabled in FPF this is a one time setting which gets fused into the PCH at the end of manufacturing:
u mean is game over? with ptt fpf disabled
Looks to me like that, yes.
Hello!
I received an error message when entering the command “AMTNVM.exe -edit intermediate.bin config.txt -out outimage.bin”. The message says:
Invalid Parameter Value Error:
An illegal parameter value was entered for
Default Power Package
The original input image would be the bios dump that I want to clean, correct?
Could anyone help me resolve this?
Thanks!
ME 2 - 3 is really old, so I’d assume there are very few people with experience out there who can answer this question with only this unspecific error message.
Maybe someone can reproduce the error if given the files / machine type.
I used iAMTNVM version v2.6.0.1025.
In version v2.1.1.1030 of iAMTNVM a different error message appears:
DHCP Enabled
lfb6: I’m not finding where to attach the bios dump I’d like to clean
Or simply zip the file and drop into the answer- textboc
Or put it somwhere else (google drive [with access for all], other hosters…) and post the link to the file.
Thanks :pray: :slightly_smiling_face:
bios dump I’d like to clean:
6910P IBT00 LA-3262P Rev-1B GPU.rar (1.4 MB)
Thanks!!!
OK, never worked on such an old ME!
I just have a pragmatic proposal- edit config.txt manually and put in the desired value when AMT should be enabled- possible values are 1,2 or 3. Might be part of the corruption that the tool fills in 16777473?
The output is consistent, the command works for 1,2,3 - gives a valid error message for 4 and 5 and all other values are ‘invalid’
config.txt
Manageability Mode = 1
Manageability Mode Lock = 0
Local Firmware Update Enabled = 1
Local FWU Override Counter = -1
Local FWU Override Qualifier = 0
Flash Descriptor Override Pin-Strap Ignore = 0
AMT Compatibility Mode = 0
AMT Configuration Mode = 0
ZTC Enable = 1
Configuration Server Port =
Configuration Server Name =
Configuration Server IP =
AMT Host Name =
AMT Domain Name =
DHCP Enabled = 1
AMT Ping Response Enabled = 1
AMT Static IP Address = 0.0.0.0
AMT Static IP Subnet Mask = 0.0.0.0
AMT Static IP Default Gateway Address = 0.0.0.0
AMT Static IP Primary DNS Address = 0.0.0.0
AMT Static IP Secondary DNS Address = 0.0.0.0
AMT Dedicated MAC Address = 00-11-22-33-44-99
VLAN = 0
PET Language Code = 0xff
PET OEM Custom Fields 00-15 = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PET OEM Custom Fields 16-31 = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PET OEM Custom Fields 32-47 = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PET OEM Custom Fields 48-63 = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PET OEM Custom Fields Length = 0
PET Community String = public
AMTManuf Test Counter = 8
IDER Boot Capable = 1
SOL Boot Capable = 1
BIOS Reflash Capable = 0
Boot into BIOS Setup Capable = 1
Pause during BIOS Boot Capable = 0
HostIf SOL Enabled = 1
HostIf IDER Enabled = 1
Remote Wake Timer = 1
ME Visual LED Indicator Disabled = 1
LAN Power Well = 2
WLAN Power Well = 2
Power Package 1 Supported (Mobile: ON in S0) = 1
Power Package 2 Supported (Mobile: ON in S0, S3/AC) = 1
Power Package 3 Supported (Mobile: ON in S0, S3/AC, S4-5/AC) = 1
Power Package 4 Supported (Mobile: ON in S0; ME WoL in S3/AC) = 0
Power Package 5 Supported (Mobile: ON in S0; ME WoL in S3/AC, S4-5/AC) = 0
Default Power Package = 16777473
Kedron Driver WA = 1
AMT Legacy Provisioning Mode Supported = 0
AMT VLAN Local Configuration Blocked = 0
iQST Supported = 0
ASF Supported = 0
AMT Supported = 1
Hash 0 Active = 1
Hash 0 Friendly Name = VeriSign Class 3 Primary CA-G1
Hash 0 Stream = 74 2C 31 92 E6 07 E4 24 EB 45 49 54 2B E1 BB C5 3E 61 74 E2
Hash 1 Active = 1
Hash 1 Friendly Name = VeriSign Class 3 Primary CA-G3
Hash 1 Stream = 13 2D 0D 45 53 4B 69 97 CD B2 D5 C3 39 E2 55 76 60 9B 5C C6
Hash 2 Active = 1
Hash 2 Friendly Name = Go Daddy Class 2 CA
Hash 2 Stream = 27 96 BA E6 3F 18 01 E2 77 26 1B A0 D7 77 70 02 8F 20 EE E4
Hash 3 Active = 1
Hash 3 Friendly Name = Comodo AAA CA
Hash 3 Stream = D1 EB 23 A4 6D 17 D6 8F D9 25 64 C2 F1 F1 60 17 64 D8 E3 49
Hash 4 Active = 1
Hash 4 Friendly Name = Starfield Class 2 CA
Hash 4 Stream = AD 7E 1C 28 B0 64 EF 8F 60 03 40 20 14 C3 D0 E3 37 0E B5 8A
Hash 5 Active =
Hash 5 Friendly Name =
Hash 5 Stream =
Hash 6 Active =
Hash 6 Friendly Name =
Hash 6 Stream =
Hash 7 Active =
Hash 7 Friendly Name =
Hash 7 Stream =
Hash 8 Active =
Hash 8 Friendly Name =
Hash 8 Stream =
Hash 9 Active =
Hash 9 Friendly Name =
Hash 9 Stream =
Hash 10 Active =
Hash 10 Friendly Name =
Hash 10 Stream =
Hash 11 Active =
Hash 11 Friendly Name =
Hash 11 Stream =
Hash 12 Active =
Hash 12 Friendly Name =
Hash 12 Stream =
Hash 13 Active =
Hash 13 Friendly Name =
Hash 13 Stream =
Hash 14 Active =
Hash 14 Friendly Name =
Hash 14 Stream =
Hash 15 Active =
Hash 15 Friendly Name =
Hash 15 Stream =
Hash 16 Active =
Hash 16 Friendly Name =
Hash 16 Stream =
Hash 17 Active =
Hash 17 Friendly Name =
Hash 17 Stream =
Hash 18 Active =
Hash 18 Friendly Name =
Hash 18 Stream =
Hash 19 Active =
Hash 19 Friendly Name =
Hash 19 Stream =
Hash 20 Active =
Hash 20 Friendly Name =
Hash 20 Stream =
Hash 21 Active =
Hash 21 Friendly Name =
Hash 21 Stream =
Hash 22 Active =
Hash 22 Friendly Name =
Hash 22 Stream =
Do you mean that the value 0 in the Default Power Packege setting is not being accepted by iAMTNVM.exe? So does the value 0 mean disabled? That’s my guess…
I don’t understand how the edit command completed successfully if the config.txt you attached is the same as the one I have here. What changes were made to config.txt to complete successfully?
I’m sorry for my English! I’m using Google Translate and I suppose it doesn’t do it very well
Again, I thank you for your help!!! :pray: :pray: :pray:
The quoted config.txt is the unchanged. Bold are the enabled and disabled packages and the default value. . Replace 1677423 with 1, 2,or 3 depending which behaviour you wish for AMT
The file “outimage.bin” is not in the FITC folder, but appeared in the Build subfolder with 3 similar files of different sizes. Here is the screenshot:
Build subfolder
Which “outimage.bin” should I use? I assume it’s the 4MB one, am I correct?
Oh, I forgot… I’m cleaning ME 8 (HM76 Mobile, Intel 7 Series Chipset)
I thank you in advance
Seems your 6 MB firmware is distributed on 2 chips, a 4MB and a 2 MB one. Normally it’s both, but it depends on how the firmware is distributed over the chips. Sometimes there are changes just in one chip. Use HxD or any other hex editor to compare chip content before and after.
The notebook has 2 bios chips. The bios dump with the ME is 4MB. In this case, I would have to flash the 4MB one, right?
It depends
I get it now… The 2MB image produced by FITC only has FFs in it.
Very grateful for the help!!! :pray: :pray: :slightly_smiling_face: :slightly_smiling_face:
5 posts were merged into an existing topic: ASUS All In One: Intel ME Firmware needs to be Repaired
