@ass9411 - all 00 or all FF means bad connection, or something else not correct.
What model is this about, where is your main thread for this issue??? I only have folder for you from 2019 for something, so I don’t think it’s same issue as today
So, nothing to do here now until you reply, sorry This is why it’s always best to make a thread to get help with any issues
Now we wait some more…
*Edit - Never mind! That is a bad dump, you should have put it in a zip and then you would have seen
This is 100% Blank, all FF
Please make a thread for your model, and in that thread link stock BIOS download page (not direct BIOS download)
And also give me your BIOS chip ID in that thread. Don’t carry on in PM again, that is why were are lost now and I can’t advise more here
@Lost_N_BIOS I don’t need help anymore, man. I managed to fix it here alone hahah. About the bad dump its because I didn’t do the “read” first before saving and send it to you. Everything is good now. This guide has helped me!
@Lost_N_BIOS I couldn’t wait because it was too late, I needed to sleep, and I didn’t want to take things apart and try again because I managed to make the program detect the bios chip, it was just a bad contact. Thanks man!
@ass9411 - Great to hear you sorted it out! So, serial, UUID, MAC all that sorted too?
Yes, you have to read then verify, then save, if you are wanting to dump chip contents
Glad you got it all sorted out
Before I ask for help, I just want to say big thanks for this forum and immense help you guys are doing.
So this is first time I am using CH341A(pro?) programmer for my Lenovo 470s laptop which for some reason won’t accept original supervisor password (or maybe we forgot it at all)?!
The thing is next:
- I started to disassemble motherboard and using friend’s help found that chip is under black plastic tape on back not underneath keyboard (u49) and this Chip
ebay.com/itm/New-WINBOND-IC-Chip-FLASH-128M-BIT-25Q128JVSQ-W25Q128JVSQ-SOP8-Package-/301006935484
- Afterwards I have started checking manual and found that this is 25 series, not 24
- I set programmer for 25 series and jumper on pins 2 and 3 [img]https://ibb.co/wcgHg7k[/img]image
- Then I set nippers on chip, and usb in PC (I tried all versions and all programmers but no luck)
- And my programmer show all the time NOT CONNECTED - and I don't know what to do, I tried all possible drivers and all possible ways :/
So what else I tried? When I set programmer on 24pin it shows it's connected, when I pull up the handle and move pins to 25, and it is connected, and it can read chip details.
But every time it gives different .bin file. When I compare in hex, It gives every 2 or 3 time different bin file, when I compare it is always different value, not same.
What can I do? What I am doing wrong?
How can I get connected and get every bin file same?
Thank you!
See here more images:
2
3
4
5
6
7
8
9
ibb.co/GWDbXxG
ibb.co/16WSVZb
ibb.co/sq0ngTP
ibb.co/XX87mNS
ibb.co/hFDKMmR
ibb.co/3C97WY3
ibb.co/55149wK
ibb.co/TMH6nVC
ibb.co/X73FY9t
Wires there are to drop voltage to 3.3v
I don't have idea.
When it says connected it's when I use 24 series :S and then I move manualy pins to 25 while it's connected, but it is not right.
update
friend of mine told me to try on linux with flashrom package, but i am so sceptic if this wont connect on windows 25 series why would it connect on linux?
My pleasure. Here are teachers and students.
Regards.
@zumzum - First, what is exact chip ID, your link to ebay cannot tell me this. Show me image if you are not sure
I assume it’s Winbond W25Q128JV, but not sure.
Second, do not move the jumper, it’s in correct position when you get the programmer delivered (1-2)
For W25Q128JV - Here is software package with below mentioned, confirmed working software versions for this chip - http://s000.tinyupload.com/index.php?fil…213094641136166
1.18 (read, not write) or ASProgrammer 1.40/1.41 (OK read/write)
Colibri ver. 1.0.1.62 confirmed read/write OK (use BV ID)
Some laptops need main battery connected and PSU cable connected, some only need one of those, some need neither.
You can only find out by testing until you figure out which your system needs.
@Lost_N_BIOS - first, I wanna say BIG thank to you!
Yes, it is Winbond W25Q128JV. I will upload picture here so you can see:
ibb.co/qJt9fbJ
Ok, I will leave jumper as is on (1-2)
Can you tell me why in this manual
docdro.id/ITgUVcV
Next, which location for EEPROM should I use?
ibb.co/VwkSd1M
ibb.co/Sm1v5zF
I will test as you said with PSU, without PSU, with battery, and without.
Can you tell me how can I know by testing which one my system needs is there any indicator or how .bin file should look like? I have to get same .bin file everytime I read, right? Is there any way to know that current state is the one I need?
Big thanks
Hi, i’m new of this forum!
I’m trying to program my laptop’s bios chip, and i’m unable to delete it.
The chip is soldered on the programmer board and when i press detect the programmer see it currectly.
With pin 8 not isulated the delete process is istant but when i try to check is the chip is blank…the program say that isn’t empy.
With pin 8 isulated, the delete process take time but fail at 30% and the programmer no longer sees the chip…
I have to remove the usb programmer and take in another time for see the chip currectly…
Is my chip broken?
The chip is a MX25L1005A (MX25L1005 from MXIC i think).
Thanks for the help…
thank you so much for the help, I will need this info to unbrick my laptop ![]()
(Problem solved. It was a bad contact, badly soldered chip…)
Good morning and happy new year!
I would need your help, I’m trying to flash the bios of an HP 840 G1, but if I use the adapter the bios is not detected by the program, if instead I don’t use the adapter but I attach it directly to the programmer while writing the lights computer LEDs flash and during the check it gives me an error, now if I try to turn on the laptop first the LED lights flash and then those of the keyboard light up and it turns off.
What can I do?
Thanks so much for your help
Hello everyone, first time poster, will try and keep it as short as possible. Been working on trying to flash a bios on my motherboard for about 8+ hrs now and feel like I am going around in circles. Nothing that Gigabyte troubleshooting recommends has helped me recover my motherboard (GA-Z77P-D3 rev1.0), its stuck on boot loop no matter what I do.
Purchased the CH341A mini programmer black PCB, with ribbon cable and all accessories. The clip is really cheap and barely makes contact, I have to play with it a lot before it catches. Anyways it has come down to me wanting to re-flash bios on both the M_BIOS and B_BIOS chips to try and recover it, this is what i have found:
bios chip: possible MXIC 25L6465E/6406E cant physically read it but it seems its detecting that, and searching around on the web it points toward the 25L6406E
symptoms: boot loop
last known good config: board was working fine with F7 bios until I flashed F8e in order to support a Pentium G2020 according to their CPU support list
current issues with programmer: Unable erase or blank chips keep getting “CHIPS ARE NOT NULL”, able to read and write but only with the following message “Chip with the contents are in disagreement” if i try and write, does get to 100% but always get same message.
Have tried Windows 7 laptop first and just tried my Windows 10 and same issues
-on the programmer my pins are in 1-2, should be serial converter mode
-set up for bios chips not EEPROM, pin one on ribbon is halfway down in line with lever if your looking from top down.
-tried motherboard with power supply plugged in and in the ON position
-tried with Power supply out
-CMOS battery IN and OUT
nothing helped
Software used:
Windows 7 laptop, i believe regular 2.0 usb ports, old 2nd gen intel i3 hp probook
-AsProgrammer 1.4.0 and 1.4.1
-installed CH341Parallel_driver, and recognized in device manager
-CH341A program V1.13, 1.18, 1.29, 1.30, 1.34
-on windows 10 used the flasher off a type C usb to USB 3.0 hub connector, that should of been more than enough power.
I am at a lost, and just tired, need to reset and start fresh tomorrow. I have no experience using this programmer, using youtube videos and a lot of reading is all ive done
Q1. New Bios is Z77PD3.F7 when downloaded from gigabyte, i renamed it to Z77PD3.F7.bin and the software is able to read it. is that ok?
Q2. installed drivers “DRVSETUP64” 6/05/2009 and driver—24CXX2XX in that order following youtube videos. saw some people on here post links to people only installing the 24CXX2XX drivers? does it matter which one first? do you need both?
Q3. for drivers should i use Parallel_driver or Serial_Driver?
Q4. User macnb on this forum, had a similar issue with a similar Gigabyte board and it ended being power, but he could not even get the chip to recognize, I can, so I don’t know if it could be that?
It think its driver related, If someone could sanity check me I would appreciate it, saw that there is a new AsProgrammer v2.1.0.13, could that be it?
@Lost_N_BIOS
Hello
I have a Chinese tablet that the manufacturer does not provide any support services
I deleted the BIOS password once and after restarting, it asked me for the BIOS password again! But in disbelief, the old BIOS password does not work
I do not have any BIOS backup files at this time
Can I use BIOS backups of other tablets that support the same CPU and RAM?
I have Z8350 CPU and 4 GB of RAM
The only difference is the screen size
Is this possible?
Hello, great thread going on here, very helpful but I find myself in a dilemma, hoping I can get a hand, @Lost_N_Bios
Asus laptop (Tuf A17 - FA607II), likely corrupt BIOS (long story short my brother forced shut down during a bios repair).
Read from BIOS chip using cha341a + clip.
Can’t be sure if the resulting read is intact or corrupt. It’s 2,048kb and contains FF from the start of file, all the way to line 000C1020. From there its like garbage text.
Tried multiple clip positions and two different programs but the result was always the same so i figured this is the best i will get.
(Didn’t understand the verify feature as I hadn’t read this forum up to this point. I did click verify and it just said ‘Verify Complete’)
So now I grab the BIOS file from Asus site… convert to ROM, open with UEFI tool and extract body. The result is 16,384kb (too large for the BIOS chip)
Can you help me pull out the needed data from this file? Is there some generic BIOS image that I can merge with, if my original bios is not readable?
BIOS chip is GigaDevice 25LB128BDSIG
I actually have since resolved this. For anyone experiencing similar…
Turns out, the reason it wasn’t reading / writing on chip properly was that i wasn’t using 1.8v adapter with the ch341a.
This time when i read from chip, it took a lot longer (5 mins) to read and came back with all FF’s (empty). This is because i managed to erase the chip in my last attempt.
Nevertheless, i proceeded with the file in the following way…
(1) downloaded file from Asus support (not the windows type, the exflash type).
(2) it had a funny naming convention like FA706II Asus.313. I simply renamed this to BiosNew.cap
(3) Downloaded a program called UEFI tool opened the BiosNew.cat in the program, right click AMI Aptio capsule → extract body → save as BiosNew.rom. This file was around 16,000kb also.
(4) Programmed the chip once again using AsProgrammer with the file BiosNew.rom. To my surprise this worked and PC booted up.
The only thing is i’m unsure of the consequences of not having the system serial number, MAC address etc inside the BIOS. Nevertheless, it’s running without issue!
I also wondering what may happen if running a Bios without your serials, tag asset…etc
And most important how these can be extracted from corrupted Bios and changed/replaced on the file that follows to be written … maybe someone could make a tutorial for this as is quite a big deal
Hello all,
I’m trying to flash a IC Macronix MX25L6406E with a USB CH341A mini programmer black,
The chip is new but has program on it and is detected fine with the CH341A
but I can’t erase it?
Verify memory…
Verification error on address: 00000000
Execution time: 00:00:00.148
Current programmer: CH341
11:46:18
Possible protection is enabled. Press “Unprotect” and check datasheet
How could I Unprotect so I can erase, make it blank and flash again?
Thanks a lot.
Pascal
Hello Pasmod1,
maybe this website can help you. https://khandishnetwork.com/2021/01/28/c…error-solution/
https://khandishnetwork.com/2021/01/28/ch341a-flash-erasing-error-solution/
Hi guys, first-time poster newbie here I hope everyone is good.
I’ve been following the thread from the beginning referencing some important tutorial links on youtube and other great extensive shared ideas on here which are really helpful. Thanks to the creator of this forum and all contributors bringing really good stuff to share and learn.
HELP needed I’ve got a Lenovo T460s 20FA model CHIP WINBOND 25Q128JVSQ and want to unlock the BIOS password. I recently bought the Dealikee SOIC8 SOP8 Test Clip EEPROM Flash BIOS USB +1.8V Adapter + Soic8 Adapter Programmer Module Kit Set for EEPROM 93CXX / 25CXX / 24CXX + CH341A 24 25 Series
I have already moded the CH341A downgrading voltage from 5v to 3v.
Is it possible to use that croc clip on a chip and save the original BIOS, Flash and replace the current BIOS with the generated patch file and send it back to the chip again without desoldering the chip from the motherboard?
Do I need to remove or unplug the CMOS battery during the process or it’s just the 2 main batteries?
Of the 3 programming software, NeoProgrammer, Colibri, and AsProgrammer which would you recommend using?
Also, do I need to plug in a 1.8v adapter into the CH321A together with the clip or 3.3v from CH321A is good enough for the process without needing the 1.8v adapter?
Thanks in advance.
