Hello All.
I have 2 server Fujitsu RX300S7 and RX300S8.
RX300S7 - flash and have NVMe Support.
RX300S8 - give me error (add images).
I use MMTool and UEFITool, but bios give me error when I try flash.
Maybe anyone have this problem? Thanks!
Hello All.
Correct, on CAPSULE bios files and other OEM securities.
Preventing this only working with extracted Intel Image or Bios region (UEFI tool) from the original bios update or spi dump of the system.
This happens more frequently on AMI V core bioses, less in AMI IV based.
EDIT:
The bios is an AMI IV core, use UEFItool_NA for extraction, UEFItool 0.25/0.28 for replacing.
Keep an eye on structure changes and/or missing pads when performing these operations.
A little more guidance here, [GUIDE] NVMe on UEFI bios lacking space volume
EDIT: The file D2939-B1.UPD doesnât have any CAPSULE, use MMtool v4.x, not v5
How I can fix it?
Maybe you have manual?
Thanks for you help information!
Hello. I tried to follow your instructions but got the same error. ![]()
Edit:
I use MMTool Aptio 4.50.0023, edit D2939-B1.UPD and save.
When save dont see error, but when I flash this D2939-B1.UPD
have:
Flash Service Interface reports Image Signature Error!
ERROR - GABI Progress Code: 833D
EDIT 22.10.2023
Hello All. I find solution how to flash.
Thanks all for Help!
@andriiwork @MeatWar
Since your recent discussion was mainly not about how to integrate the NVMe module into the BIOS, but about how to get the modded BIOS properly flashed, I have moved the related posts into this better matching thread and hope, that you agree with me.
Good luck!
i managed to flash the latest bios for my supermicro x10slh-f using the ami tool that came with the bios.
simply use rufus to create a freedos and flash the bios via the ami.bat file and it should work.
what happened in my case was after POST, it went into a restart loop for like 4-5 times but each time it got further and further in the POST process until it just goes through.
Good luck!
@clarencelimzj Thank you for your feedback.
Was the restart loop a one time thing or does it happen on every fresh start ?
hi
i am trying Modding my bios with afuwin ami
but i keep getting this error
18 - error: secure flash rom verify fail
my mother board is msi B760m-p
i searched about Solution in your website i did found this but i didnât understand what is
MEAnalyzer
what i should do with it ?
thanks
Nothing to do with mods flashâŚ
platomav/MEAnalyzer: Intel Engine & Graphics Firmware Analysis Tool (github.com)
Bios mod on modern motherboards only flashed with Intel FPT tool (Should be v16)
or an SPI programmer.
Dump your bios with the tool, (bios_region must allow writing, MSI usually allow it) mod it and flash it back.
If no experience on this area and not familiar with the tools, do not procede, i will not teach this to anyone as itâs no easy task and time consuming.
VERY high risk of getting a braked board.
You should wait for others users pov.
EDIT: Use the search box on the forumâŚyour task and your time, not mine.
sorry if i bother you can i get the link of FPT v16 ?
@almajed
Since you are obviously searching for a tool to get a modded MSI BIOS properly flashed, I have moved your request (and the reply given by MeatWar) into this already existing and much better matching thread.
Donât forget to read its start post before sending new posts.
Good luck!
since i looking for fpt (CSME System Tools v16) i found the last 2 version of it and i would like to upload it for others if they looking for it later
thanks for helping @MeatWar https://mega.nz/file/tddyRJYA#USa3sj1qh2g2c-RNlbP-XzLHGR8WUOboUF1Ewu6oMgQ
Those tools are present in the forum, in the correct section and thread related to ME tools.
I just told you to search for it⌠all users will find it in the:
Intel Converged Security Management Engine
Drivers, Firmware and Tools
CSME 16+
Lates v16.0 is the CSME System Tools v16.0 r8
Lates v16.1 is the CSME System Tools v16.1 r0
7 posts were split to a new topic: [Problem] Change of the MBâs Serial Number
Need some help with this Asus TUF H370 Pro Gaming Bios, i have modded this Bios but can´t Flash it.
First of all here is the Original Bios File:
TUF-H370-PRO-GAMING-ASUS-3101.zip (8.5 MB)
Preparations:
Cleared all Keys in Secure Boot and set System to âOther OSâ Secure Boot: shows deactivated
First i looked for locked Bios with USB Stick and Shell.EFI with GRUB but it´s unlocked as standard
(Bios LOCK 0xBC9 = 0x00 i set it to 0x00)
(FPRR 0x5BE = 0x00 standard)
(BIOS GUARD 0x1CC = 0x00 standard)
Then I have tried to Flash it in several ways:
This Asus Mainboard have no Bios Flashback so it´s more complicated
Flash from UEFI Bios itself: Says Can´t Flash this Bios File
Next i tried AFUDOS this says 22 - Error Problem allocating memory.
FTP (DOS) & FTPW says this Error 167 Protected Range Registers are set by Bios, preventing Flash access.
Same if I first make a Bios dump of original Bios with âftp -d backup.binâ, when i wan´t to reflash this with âftp -bios -f backup.binâ Same Error 167
Then I tried Asus AI Suite and replaced the .CAP File (as in Guide), it flashed the Bios 3101 but without Modifications.
Last i tried Flashrom 1.2 with programmer âinternalâ
Here are the Errors from Flashrom:
Bios Region SMM Protection is enabled
SPI Configuration is locked down
FREG0: Flash Descriptor Region (0x00000000 - 0x00000fff) is read only
FREG2: Management Engine Region (0x00003000 - 0x002fffff) is read only
Enabling Hardware Sequencing because some important OPCODE is locked
Found programmer Flash Chip âOpaque Flash Chipâ
Aborted
Here is my MEInfo64 Output:
Meinfo.zip (1.5 KB)
Who can help me to get this working or have some Guides for me that i haven´t found at this time ?
Hello.
I am modifying the bios of the original motherboard. ![]()
It works fine, but there is one problem.
Non-existent hardware appears in Device Manager.
It is a device called GDIX1001, and this board is a board that has converted the hardware originally used in a tablet PC into a mini PC. (The model of the board is unknown, but it says U35FL002)
I modified the ACPITable in bios to try to remove this.
The fix is using ACPICA and UEFITool and flashing with AFUWIN (I tried this, but an error occurred: 18 - error secure flash rom verify fail. So I dumped the entire BIOS, modified it with UEFITool, and flashed it with a ROM programmer.)
The result is like this:
ROM Image update denied has appeared in the BIOS.How can this problem be solved? :0 (Or is it not editable?)
I use a translator.
BIOS Dump and my edited
U35FL002 â Google Drive
@Kang-Jinsu
Welcome to the Win-RAID Forum!
Since you obviously had problems to get a modded AMI UEFI BIOS properly flashed, I have moved your post into this already existing thread. The Guide is within the first post.
By the way - the âdeviceâ named GDIX1001 is an ACPI one. You may find a driver [>here<].(ACPI\GDIX1001 download driver for Windows 10 x64 | DriverPack).
Good luck!
Dieter (alias Fernando)
At least you can get rid of the following.
Just delete ReFlash dxe.
Thank you for solving it. (Booting is still slow, but it doesnât matter) ![]()
I have a modern motherboard ASUS B760M-A D4 without flashback usb port.
I canât use flashromâs -p internal since it canât detect any eeprom.
So wonder what my options are?
Is it Intel FPT tool or ch341? Looks like the board have 2 bios chips so which one should i flash?
Where can I find Intel FPT tool for alderlake/raptorlake mbâs? Do not seem to find any download links.
