Yes, I find the Hardware IDs of the SATA AHCI Controller which is used by the Apple SSD in Windows device manager(boot by another SATA SSD) is
PCI\VEN_144D&DEV_A801&SUBSYS_A801144D&REV_01
PCI\VEN_144D&DEV_A801&CC_010601
@wangyu1221
Thanks for posting the HardwareIDs of the in-use SATA AHCI Controller. Since its manufacturer is Samsung, the inserted M.2/PCIe BIOS module should be compatible.
I tried many things but nothing worked. So this Apple SSD seems cannot be a bootable disk in my Dell Optiplex 7010. Things maybe change after I find the missing driver to make the bios recognize this SSD, because I’ve seen someone succeed on Gigabyte GA-H81M-DS22 and Asus B85M-G MB.
@wangyu1221
Provided, that
a) the in-use M.2/PCIe connected SSD is a Samsung one and uses the SATA AHCI protocol,
b) the module named SAMSUNG_M2_DXE.ffs has been properly inserted and
c) the modded BIOS has been successfully flashed,
the M.2 SSD should be bootable in UEFI mode.
If the SSD should not be detected by the BIOS as being bootable, I recommend to create the required EFI boot partition named “Windows Boot Manager” by following “Step 4” of >this< Guide, which has been written for NVMe SSDs, but should work with M.2/PCIe SATA AHCI SSDs as well.
Yes, my Apple SSD is a Samsung product with AHCI SSD Controller. here and here
Done. I’ve tried 2 versions of the SAMSUNG_M2_DXE.ffs(6,796Bytes and 6,741Bytes).
Done, with fptw64.exe.
Now I finished all steps of “Step 4” what you suggesed in >this<, but SSD still cannot de detected by the BIOS, I mean there is no device in legacy mode, and no EFI item in UEFI mode.
@wangyu1221
If you really were able to complete my Guide’s “Step 4”, you got Win10 or Win11 successfully installed onto the PCIe connected M.2 SSD and should see the device named “Windows Boot Manager” as bootable device within the BIOS.
This means, that the SSD is bootable in UEFI mode, although its original name “Samsung XYZ” is not listed within the BIOS.
I’m sorry, there is a mistake.
I followed the steps of “STEP4”, I finished 4.B.7, but I couldn’t finish 4.B.8.
The win10 installer needs a rebooted once after the file copy is finished to continue the installation.
After installer make a reboot automaticly, windows installation interrupts, because still no boot option in UEFI mode(usb device has been removed).
Please attach your modded BIOS (or give me a link to it).
How did you verify, that the BIOS update was successful?
Please make a BIOS dump and post a link to it.
bios_samsung_modded.rar (5.7 MB)
I redumped the bios and confirmed that SAMSUNG_M2_DXE is indeed in the bios.
@wangyu1221
Thanks for the quick response. and the modded BIOS.
The insertion of the SAMSUNG_M2_DXE module seems to be correctly done.
Interestingly the DXE Volume of the BIOS contains additionally 2 mysterious modules named “AHCI” and "PCI_Express_DXE. Their function is rather unclear for me. Maybe there is an interference with the SAMSUNG_M2_DXE module, which prevents the ability to boot off the Samsung M.2 SSD.
My support ends here, because I don’t know how to solve this specific problem.
Thank you all the time. I’ll try more and I’ll reply here if there are good news.
Hi,
I have a Samsung PM951 128GB Nvme that i will like to use in my Abit IP35 Pro.
The PM951 is an AHCI type Nvme.
The last official Bios (ID 17) for Abit Ip35 Pro has AHCI fonctionality.
Does this mean that motherboard will recognize the SSD and accept it as a boot drive ?
Or there is more to it than simply adding 1+1.
Please advise, thank you.
@Habato Welcome to the Win-RAID Forum!
Probably not. “AHCI functionality” usually means “Support of the AHCI protocol for HDDs/SSDs, which are connected to one of the on-board SATA ports”. To be able to boot in AHCI mode off a PCIe connected M.2 SSD like the Samsung PM951 an additional “DXE Driver” module is required within the BIOS.
Good luck!
Dieter (alias Fernando)
My apologies for jumping into a completely different topic.
Thank you for your help. I will be more cautious from now on.
