@Lost_N_BIOS
If it is the only dump that I have with version 1.29, I deleted it a serious error after making the dump with version 1.29
Good Morning Mate, I have a Machenike F117-V, RTX 2060, i7 10th gen, I need some help as my Bios has only been limited and I cannot overclock and undervolt my pc, the FIVR option in throttlestop is locked, I have already followed 1-3 of your instructions and here is the results, below is the screenshot of my bios
RESULT
H:\Intel CSME System Tools v14.0.20+ r10\Flash Programming Tool\WIN32>FPTw.exe -bios -d biosreg.bin
Intel (R) Flash Programming Tool Version: 14.0.36.1158
Copyright (C) 2005 - 2020, Intel Corporation. All rights reserved.
Reading HSFSTS register⊠Flash Descriptor: Valid
â Flash Devices Found â
ID:0xC84018 Size: 16384KB (131072Kb)
- Reading Flash [0x1000000] 12288KB of 12288KB - 100 percent complete.
Writing flash contents to file "biosreg.bin"âŠ
Memory Dump Complete
FPT Operation Successful.
@Alis1204 - Please link me to your stock BIOS download page, or upload your stock BIOS package you last flashed
The only BIOS I have for Tongfang OP-LP3 (or any GK7CN6S) is 1.04 and 1.08 and BOTH of those have FID (Flash ID) of GK7CN6SN1, but your BIOS has FID of GK7CN6SN0.
Even MechRevo X8Ti Plus GK7CN6S BIOS has FID of GK7CN6SN1. So all BIOS I have is not the same BIOS and I do not have stock BIOS with your FID (ie do not have your BIOS, stock or even in dumps from any users)
@klangun - WOW, that BIOS is the MOST limited Iâve ever seen for ANY of these! Is that really the root of advanced?
What error, if any, do you get when you run this command now >> FPTw.exe -bios -f biosreg.bin
And, I need you to upload biosreg.bin for now too
Unfortunately it is my bios mate, here is the FPTw.exe -bios -f biosreg.bin
Have I done it correctly?
Thank you so much for your help
here is the link to my biosreg
https://www.dropbox.com/s/bdupwe1blyczam8/WIN32.rar?dl=0
@klangun - Thanks, I just needed you to upload that BIOS file.
Wow, that is bad they hide so much from you in advanced? Are you sure, that is all you see at âRootâ of advanced, right when you go to advanced section? Never mind, I see now, itâs hidden from you We shall fix that
And, I also need you to run this command and tell me what error # you get, if any >> FPTw.exe -bios -f biosreg.bin
is this one correct?
Thank you sooooo much
Yes, good, that means nothing is locked to block you flashing in mod BIOS, so you donât have to do anything else for now.
Youâre welcome! Please wait, I will unlock BIOS for you
I will, tyt =) tyvm
Can you see ME FW version at bottom of Main? I donât need to see it, only asking so I can know if I need to make visible for you or not
yes it is there:)
@Lost_N_BIOS
The version that I downloaded and flashed was this vertion intel.cfl.GK7CN6S.STD.N.0.08_20180814
download from the official page, here is the link
https://mega.nz/file/r5xxFQrA#rgVnnfDTaTâŠLuNGTTZMLdnHJG4
https://www.opowered.com/lp3-support.html
What can I do to bring this laptop back to life?
@Lost_N_BIOS
came with this version
And update to this before death
@Alis1204 - OK, Hmm, that is VERY old BIOS at least if we are looking at âVersionsâ
I only have 1.04 and 1.08 (intel_CFL_GK7CN6S_ESI_BIOS_N.1.08_20181128-2), what you mentioned is 0.8. I noticed you linked STD, what I have and others here use (And all images weâve discussed here) are for ESI -
Please ask Overpowered what is difference between systems with STD and 0.0x BIOS and ESI w/ 1.0x BIOS, and which model you have based on serial # (All say âStandardâ in BIOS main page, so this is not what makes difference)
Your BIOS image of MAIN, shows you were already on 1.08. Did you flash EC FW too, or did it brick before you had a chance? Or is that not your image?
The first image above showing 1.03 BIOS, is not yours correct, serial and UUID does not match? Neither of those are the same BIOS that you linked, different model variant
Yeah, that BIOS you linked is not correct/same one, as what you have in there originally (unless those are not your images) This is for some other model, look at change log, all BIOS are 0.0x, none are 1.0x
This has FID of GK7CN6SN0 though, but, it may not be the correct BIOS for your model, due to BIOS images you showed.
Is the image you showed of BIOS with 2009 date and version 1.08, your actual BIOS image, or someone elses? Or is the other one showing BIOS version 1.03 your image?
If either are your actual images, then the BIOS you flashed is not for your model variant, those in image both have BIOS 1.0x type, you flashed in 0.0x type.
What graphics card do you have?
It worked!. Thank you Lost_N_BIOS.
@Lost_N_BIOS
again I apologize for my mistake, the serial of my laptop is OP-LP3BK18K01652 and it was in the version N.1.08 1.08.09
But then because on the official page the version that gives me is 0.08
The grafic card is gtx1060
@klangun - Here is your unlocked BIOS, flash via >> FPTw.exe -bios -f biosregm2f.bin
http://s000.tinyupload.com/index.php?filâŠ231969562550393
*** WARNING - To ANYONE with laptop and unlocked BIOS!!!
DO NOT try to enable this graphics card or disable that card, switch cards etc. Otherwise you will end up with no display output (ie black screen) and no way to recover except by blind flash or with flash programmer.
You can change graphics related settings, like changing memory sizes, or core speeds etc, just donât try to disable one card or change which is main etc.
Additionally, be very careful when trying to undervolt CPU, you can leave BIOS unbootable due to CPU voltage too low (Sometimes even 0.05 is too much)
WARNING - This BIOS is user specific! If you are not user klangun at Win-RAID.com forum, DO NOT USE THIS BIOS!!
If you do, and you are not klangun, then you will loose your serial, UUID, OG NVRAM, and possibly LAN MAC ID as well.
You have been warned!!!
@NoHope - Thanks for the test report back!
@Alis1204 - So, you flashed in wrong BIOS version then! This is not your fault really, itâs due to OP needs to make two sets of BIOS for OP-LP3 on their site, Iâve never ran into anyone with the BIOS type they have listed there now!
Did you flash in EC FW, or no? If not, then we can fix, with 1.08 BIOS type. If you flashed in EC FW, that chip will need dumped and re-written too.
If you did not flash EC BIOS, I will make you stock BIOS tonight with your MAC ID, Serial, UUID etc so you can program it in. Sorry, I canât do right now, just getting ready to leave.
ALL OP-LP3 users need to pay attention here, and NOT flash in N.0.08 BIOS if your BIOS type is currently N.1.0x ***
Lost_N_BIOS ![]()
when you can iâll be waitingđŹ
C:\Users\Crow\Downloads\Compressed\WIN32>FPTw.exe -bios -f biosregm2f.bin
GbE Region does not exist.
Processing Flash memory block 35 from 3071.
- Erasing Flash Block [0x424000] - 100 percent complete.
- Programming Flash [0x0424000] 4KB of 4KB - 100 percent complete.
Processing Flash memory block 926 from 3071.
- Erasing Flash Block [0x79F000] - 100 percent complete.
- Programming Flash [0x079F000] 2092KB of 2092KB - 100 percent complete.
- Processed memory blocks 3071 from 3071.
RESULT: The data is identical.12288KB of 12288KB - 100 percent complete.
thank you very much for saving my pc=)
@klangun - Youâre welcome! So, BIOS menu unlocked now, correct? If yes, thanks for the quick test and report back
@Alis1204 - You did not answer me about EC FW??
Bios menu unlocked now:) I confirm, thank you very much:) you are Gods gift
@klangun - Thanks, I appreciate the confirmation! Youâre welcome again, and thank you for the praise
