You cannot install Windows XP without a so-called "TEXTMODE" driver file named txtsetup.oem. The latest Intel RST driver with such file is v11.2.0.1006.
Btw: I have tried to create a txtsetup.oem file for newer Intel RST driver versions, but the XP installation failed with all my test packages.
Intel has never released
That is the latest Intel Chipset Device Software Set version with XP support, but regarding the INF file dates the latest package is the v9.3.2.1020. All files of the v9.3.2.1020 "All" folder are dated 02/27/2014, whereas the files of the v9.4.4.1006 are dated 08/01/2013.
Nevertheless there will be no big difference, because the date of the INF files say nothing about the date of their creation by Intel.
@Fernando :
I got Intel(R) 8 AHCI working with Windows 2000 on new ASUS Laptop R752LD (see Page 12). I used extended Kernel from blackwingcat. It makes no difference if Intel AHCI 11.2 (modded by Fernando) or Intel AHCI 8.9 (from blackwingcat) are used. The "jumping point" was ACPI. Windows 2000 seems not to understand BIOS, and this can cause setup to hang on "setup is starting windows 2000", before showing the harddisk. From this I followed a problem with iastor. But when hitting "F5" and choosing "Standard PC", iastor works fine, shows the harddisk and installs windows 2000 without problems. Now I would need tools to check if really BIOS is the problem. Can you give advice how to go on?
Greetings from Austria, Joe
@ Joe1962:
Hello Joe,
thank you very much for your contribution, which is very interesting and helpful for all users, who want to get an old Windows OS like Windows 2000 installed onto a brandnew Intel chipset system.
Just to avoid any misunderstandings: When you wrote "Intel(R) 8 AHCI", you probably meant your "Intel 8-Series chipset system running in AHCI mode". Is this correct?
This is an important find.
Since the "normal" users don’t know anything about blackwingcat and his "extended Windows 2000 kernel32.dll", it would be fine, if you could write a short guide about where to get and how to insert it into the W2k image.
I am not sure, if I will be able to help you with this. What sort of tools do you mean?
Thanks again!
Fernando
@ all:
If you want to know more about blackwingcat’s "extended W2k Kernel", you may look into >this< thread.
To avoid misunderstandings:
Yes, it is Intel 8 Series chipset system running in AHCI mode (there is no IDE compat mode available in bios).
To get more deep with extended kernel:
Blackwingcat, the japanese guru for windows 2000 has released two fantastic tools for windows 2000:
1) Extended core: hal and ntfiles are replaced with xp compatible ones, so driver sys files from xp (also some from vista) will work in windows 2000. This extended core files can also break processor (up to 12 processors) and memory limits (yes, I saw 8GB ram in w2k x86!!). Extended core is the one I integrated into slipstream cd (hfslip)and used for installation on new ASUS laptop.
2) Extended kernel: this is for applications; you can run firefox, google chrome etc on windows 2000.
+English source version: fortunally, there is no guide or tutorial needed to get these integrated. Blackwingcat produced a HFSLIP DVD, which you can download from his website (use: google: blackwingcat, extended kernel DVD); only the source windows 2000 CD has to be copied into the downloaded folders, then an burnable iso file is created (similar to nlite, which is used often here). Windows 2000 original CD must be english version.
+German version Windows 2000: a little bit more tricky for now, but blackwingcat announced a german version of extended core and kernel DVD coming soon. The advantage of the DVD: there are a lot of drivers and applications integrated which were ported to w2k from XP by blackwingcat, for example PCIE card reader, wireless network dev etc.
Problem with ACPI / Tools question: I really have no idea, why XP can recognize acpi correctly in the very first phase of txtmode setup and w2k cannot. if you press "F5" in XP installation when setup shows "press F6", it will show acpi mode as possible for installation. In w2k, it will only show "standard PC". That this may result from BIOS incompat with w2k was an idea of blackwingcat. So I think, there are two possibilities to get ACPI working in w2k exkernel installation:
a) examination of bios to see if there are incompatibilities -> mod bios -> installation
b) examination of txtmode setup (comparison of w2k and xp acpi and bios detection) -> take some components from xp and integrate in w2k txtmode setup -> installation
For a) and b) my knowlege is not sufficiant, because I never did edition or modding of bios components. Also for b), I don´t even know which files are loaded on "setup examins hardware configuration of the computer". So I thought perhaps you could help and give advice how to go on.
What I did yet: I used biosinfo.inf from XP, I modified txtsetup.sif and eliminated all really "OLD" devices which are not needed for installation. No success.
Greetings, Joe
@ Joe1962:
Hello Joe,
thank you very much for your detailed statement and instructions.
Since the ACPI problem at the beginning of the W2k installation has nothing to do with the topic of this thread, I suggest to move the last posts into Integration of Intels AHCI/RAID drivers into an XP, W2k or W2k3 CD thread, which I just have renamed for this purpose.
If you agree, I will put a link to your last post into the start post of the related thread.
According to my knowledge the original RTM version of Windows XP ("Gold" edition = SP0) and even the SP1 version of Windows XP doesn’t work properly. That is why I recommend within my guide to take a later XP version (SP2=minimum) as source for the Windows XP installation.
This is an important remark, which I will add into the start post of Integration of Intels AHCI/RAID drivers into an XP, W2k or W2k3 CD thread.
Regards
Fernando
Hello Fernando,
of course I agree with your suggestions how to place / link my posts. I am happy that some of the informations were helpful for other people. And - I did not realize this before - the F5 hit can show if modded intel drivers OR acpi problems are the reason for BSOD /Hang in the beginning of setup - a kind of "diagnostic tool".
Now I have running w2k with "standard PC" on ASUS R752LD and performance is still fast. I have LAN, WLAN, Intermediate lan/wlan drivers, Sound, Graphics (Intel 7 and nvidia graphics will not work even on XPSP3, but VESA from AnaPa can be used instead of standard VGA - Resolution: 1600x900x32 is possible in W2k with this trick). Problem is only Card Reader (installed, but yellow exclamation mark), because Card Reader AND LAN are controlled by the same hardware interface. But also XPSP3 did not like this, and when installing the driver for CARD reader, LAN disappeared from dev manager. Second problem is w2k floppy controller, it is present with yellow exclamation mark and I cannot get rid of it (but this is not really a problem, since this laptop does not have a floppy).
So I could use my "Standard PC" W2k system, but I want it to be done "really", and the beginning is w2k with ACPI on this laptop, because in standard mode I cannot have more than 1 core and 3,3GB Ram.
ACPI: Do you know which files are responsible when setup shows "setup is examing your hardware" in XP and w2k? TXTSETUP.sif , Biosinfo.inf and acpi.inf are used later, and 90% same content in XPSP3 and W2k, I think they will not have effect on this - is this true or wrong? Where can I find information about this? With google I did not find anything.
How do you consider the idea to make the bios compatible? Blackwingcat wrote to me, that I should try another BIOS and w2k could work properly in ACPI Multiprocessor mode. My BIOS version is APTIO setup utility 2.15.1236 / AMI BIOS Version 306 / VBIOS Version 2175.T15X550.007. And I saw you are experienced with bios and bios modding.
Greetings, Joe
Meanwhile I have moved the related posts into this thread and renamed the titles of the posts.
AFAIK it is the file NTDETECT.COM (in combination with the files NTLDR and NTOSKRNL.EXE).
I found it >here<.
I am sorry, but I cannot help you regarding the modifcation of system BIOS components.
Hey,
It is possible to install XP SP3 on Asus Z97-A?
I added the nlite driver Devid = 8c82 and I still have a blue screen 0x00000a5.
I installed from CD and USB, IDE mode, legacy mode, uefi off, when they have to show drives, screen of death.
Regards/Pozdrawiam
xpeu89
@ xpeu89:
Welcome at Win-RAID Forum!
Yes, it is not easy due to the modern chipset, but should be possible.
This indicates, that it is not the integrated driver, which caused the BSOD.
At what stage of the installation did you get the BSOD?
Have you used a clean (untoched) Windows XP image as source?
Did you unplug all unneeded storage drives before starting the XP installation?
According to my experience it is the best, if you
a) set all BOOT options within the BIOS to "LEGACY" and
b) boot off a CD running in IDE mode.
Regards
Fernando
I used a modified (NIKKA with Sata-v2) and clean version of XP, none of them works.
Bluescreen (0x000000a5) appears while loading the driver installer, before shows partitions.
Plugged into the motherboard there is only one HDD, DVD, and nothing more.
All options do I have for Legacy and IDE.
Pozdrawiam/Regards
xpeu89
The best source is a clean XP SP3 image.
Another idea: Hit F5, when you are prompted to hit F6. Maybe you can choose the correct ACPI support option.
Since I succeeded with the installation of Windows XP with integrated "Universally modded" Intel RST driver v11.2.0.1006 onto my Z97 system running in AHCI mode, I am pretty sure, that it should work for you as well.
Ok, I’ll try tomorrow, thanks for the quick reply.
Pozdrawiam/Regards
xpeu89
You were right, F5 does the trick, I focused on only on:
ACPI Multiprocessor PC
ACPI Uniprocessor PC
Advanced Configuration and Power Interface (ACPI) PC
At the bottom of the list was the "Standard PC" and it moved installations.
Thanks a lot for your time and help.
Pozdrawiam/Regards
xpeu89
Update on the "F5" Trick with W2k on modern hardware:
* Hit "F5" when Setup shows to hit "F6"
* W2k will show a list. On some modern hardware you will only see a few possibilities with the option "Standard PC", "MPS" and "other".
* Don´t choose "Standard PC" first. Scroll up to see the other possibilities. Don´t choose "ACPI Multiprocessor" or "ACPI Uniprocessor". Choose "ACPI-PC".
A) W2k will tell you if your BIOS is not compatible with ACPI with a BSOD message (this is only shown when choosing ACPI-PC, not shown with ACPI Multi- or Uniprocessor-PC) OR
B) Setup will show the harddisk for installation.
Now, A) Shut down the computer or B) Hit F3 to shut down the computer.
* Repeat setup with "F5".
* If you had A) before, choose "Standard PC" for installation.
* If you had B) before, choose "ACPI-Multiprocessor-PC"
Hello Fernando,
in reply to post 208 (w2k ACPI problem):
I found out that NTDETECT and NTLDR in combination with ntoskrnl is true for up and running system. On every startup, windows loads ACPI table from bios to see if it changed since last startup. In txtmode setup, things are more complicated. There is a "mini kernel" loaded and usetup.exe in combination with ntdetect and ntldr do the decision about ACPI. Usetup makes two directories and copies files into it. The first directory is used for loading hal and drivers (phase 1 of txtmode setup), then, when "setup is starting windows 2000" message is shown, protected mode is entered (phase 2 of txtmode setup). I don´t know exactly, if in phase 2 the mini kernel is used again or if ntoskrnl does it yet.
Phase 1 cannot be the problem, because setup will decide that the system supports ACPI. But when entering phase 2, setup doesn´t find the startup device any more in ACPI mode. The same effect occurs if I want to change HAL from Standard-PC to ACPI-PC on up and running system.
NTDETECT.COM cannot be the problem, because XP original file is used.
NTLDR cannot be the problem, because XP original file is used.
Problem files could be HAL.DLL and NTOSKRNL.EXE, or this mini kernel file from which I did not find out the name.
What could I try to let w2k find the start device after changing the HAL on up and running system? The system hangs on acpitabl.dat. Perhaps there are some registry or other tricks to get it solved after installation?
@ Joe1962:
Thanks for your contribution regarding the ACPI settings via F5 at the beginning of the OS installation.
To make it easier for the users to find your tips, I have just updated the chapter "Additional advices for the later OS installation" within the start post of this thread.
Your findings and thoughts regarding the Setup processes during the textmode phase of the OS installation are very interesting as well!
Since I am not an expert regarding this special topic, I cannot help you with this. Nevertheless I am very interested in the results of your further investigations.
Another story, which may be interesting for you:
Recently I tried to make newer Intel RST(e) AHCI/RAID drivers of the v12 series usable for a Windows XP/W2k3 installation. Since all these Intel AHCI/RAID drivers with a higher version than v11.2.0.1006 natively don’t have a TXTSETUP.OEM file, I have tried to create such file myself. At least I was able to get a modded variant of the 32bit Intel RST(e) textmode driver v12.9.4.1000, which seemed to work. That means, that I was able to integrate it as textmode driver into a Windows XP image by the tool nLite. Unfortunately the later XP installation onto my Z97 system failed with the message "Setup couldn’t find the file iaStorA.sys", although this file was present even within the i386 folder. Then I tried to integrate the driver by using the tool XP-Isobuilder, but got the same result. At least I tried to integrate the textmode driver manually, but during the XP installation I got the message, that there was an error within the TXTSETUP.SIF file. I gave up my tests in July, because I didn’t have the needed time.
Since you seem to be a person, who may be able to find out the reason for the XP installation failure, I attach 2 different test versions (1 with, 1 without SCSI filter driver) of a 32bit Intel RST(e) textmode driver v12.9.4.1000.
If you should have any idea, please let me know it. Thanks in advance!
EDIT 1:
Due to a leak of my personal memory I didn’t remember the exact error messages I got during my textmode driver tests done in July. That is why I have corrected the last part of my post.
EDIT 2:
Today I have done a new test with the re-modded Intel RST(e) driver v12.9.4.1000 (without iaStorF.sys) by integrating it manually into a Windows XP SP3 CD using the $OEM$/WINNT.SIF method. The start of the XP installation worked fine, but as soon as the loading of the integrated Intel AHCI driver was shown by the Setup, I got again the message, that the file iaStorA.sys could not be found. I don’t know the reason for this message and how to prevent it.
Special 32bit RSTe AHCI & RAID drivers v12.9.4.1000 mod by Fernando.rar (285 KB)
Special 32bit RSTe AHCI & RAID drivers v12.9.4.1000 re-mod by Fernando.rar (271 KB)
Hello.
I have a problem installing SATA AHCI Drivers under Windows XP SP2 Professional (32 bit) for the Intel DH77EB. I have slipstreamed the drivers using nLite. Windows Setup seems to detect the HDD, because it formats it. It even copies the installation files and loads the drivers (I saw that while looking at the grey bar at the bottom of the installation screen). After that it restarts the computer (which is the way it’s supposed to be), the XP logo shows up in the center of the screen, and after that BSOD with the 7B error.
My configuration:
Intel DH77EB Desktop Board
2TB WD Green Power HDD connected via sata 6GB port - the HDD supports Sata 6Gb/s.
DVD-+RW connected on SATA 3Gb/s port
Drivers slipstreamed: “Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller” and “Intel(R) 7 Series Chipset Family SATA AHCI Controller” downloaded from the Asus website for the Asus P8H77-M board (Version 11.1.0.1006 &11.5.0) - first package on the download page (about 26 MB) - http://www.asus.com/Motherboards/P8H77M/HelpDesk_Download/
No USB devices except mouse and keyboard are attached during installation, and the SATA mode selected in BIOS is AHCI.
My hardware IDs for the Sata controllers which works in IDE mode are:
PCI\VEN_8086&DEV_1E08&SUBSYS_20328086&REV_04
PCI\VEN_8086&DEV_1E08&CC_010185
for the Intel 7 series/C216 Chipset Family 2 port SATA Storage Controller - 1E08 (I suppose that this is the SATA 6Gb/s controller)
and
PCI\VEN_8086&DEV_1E00&SUBSYS_20328086&REV_04
PCI\VEN_8086&DEV_1E00&CC_01018F
for the Intel 7 series/C216 Chipset Family 4 port SATA Storage Controller - 1E00 (I suppose that this is the SATA 3Gb/s controller).
I even changed the iaAHCI file, because originally it supported the 1E02&CC_0106 and 1E03&CC_0106 Ids. I have replaced the following lines
PCI\VEN_8086&DEV_1E02&CC_0106.DeviceDesc = "Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_1E03&CC_0106.DeviceDesc = "Intel(R) 7 Series Chipset Family SATA AHCI Controller"
with these ones
PCI\VEN_8086&DEV_1E08&CC_0101.DeviceDesc = "Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller"
PCI\VEN_8086&DEV_1E00&CC_0101.DeviceDesc = "Intel(R) 7 Series Chipset Family SATA AHCI Controller"
and no luck
Could you please help me out Fernando? I have been trying to solve this on my own for a week or so (read the whole thread) and can’t figure out what’s wrong.
@ Mulder:
Your Intel 7-Series Chipset desktop has an "Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller" and nothing else.
So you should highlight just this Controller, when you get the nLite textmode driver popup window. The "Intel(R) 7 Series Chipset Family SATA AHCI Controller" is the on-board Intel AHCI Controller of Intel 7-Series Chipset Mobile systems (Notebooks etc.).
That was a big mistake, because
a) your modded HardwareIDs do not support AHCI at all (the extension "CC_0101" means "IDE" mode) and
b) your desktop system doesn’t have an on-board "Intel(R) 7 Series Chipset Family SATA AHCI Controller" (see above).
Why didn’t you just follow my guide?
This is what I recommend to do:
1. Integrate the Intel RST driver v11.2.0.1006 WHQL by using nLite.
2. When the textmode driver popup flashes up, highlight just the listed "Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller".
Regards
Fernando
Fernando - Thank you for all the help and responses.
In my case, I was not able to use the methods prescribed, but I did manage to use an even older-skool “trick” to get my existing XP Pro 32 OS installed on a hard-drive with 100+ programs to work on a brand new GigaByte Z97X-UH3 motherboard.
First off, my XP install is…10 yrs old…at least. Ive used this same install on 3 previous motherboards, originally installed on a Pentium 2 BM, then PIII, then P4, this will be the 3rd on an i7 4GHz. (by install, I mean I have not re-installed XP for 10 yrs…even though its no longer on its original hard-drive or MB…another old trick which I can share…KEEP your old install from any hard-drive onto brand new hard-drive without needing to Ghost)
The Chipset on my new GB Z97X is of course the Intel 9700 series. The drivers appear to be version 04/03/2014,13.0.3.1001, and the DEV is 8CA2. I have not found a way to force any driver to work, because I havnt found an 8CA2 .inf .cat or any other file…the only way to get that particular driver appears to be an .exe executable install file directly from Intel…they are wising up.
So…How did I get my hard-drive to boot up and run on this new MB? Old-Skool - install a SIGG PCI S-ATA card into my old dying computer with any old SATA hard drive attached, power on existing XP OS and load the SIGG PCI SATA card drivers, power off, now unplug the XP OS from the MB and plug it into one of the SATA slots on the SIGG PCI SATA Card (still installed in the old computer) and boot up…this works almost every time (its worked for me for years on lots of different computers). Play around a few minutes to make sure the system is fine and power off. Take the SIGG PCI SATA card and existing XP OS Hard drive and plug them into the new Z97X Motherboard (Hard drive still plugged into the SIGG PCI SATA card), power on. Boom…it boots up to windows XP, which will find drivers…in my case Windows XP integrated the SIGG card’s driver into the Motherboard’s SATA controller by itself, I clicked Cancel on all other “new hardware found”. I then powered down, unplugged and removed the SIGG PCI SATA card and plugged the existing XP OS harddrive into one SATA slot on the new Z97X MB - and it booted. I now have a 10+ yr old install of XP (with SP3) running on an i7 Z97 motherboard. Of course it only sees 4 or my 16 GB DDR3 ram, but its running.
When I attempted to force one of the Fernandos drivers thru “update driver”, such as Chipset 9X…8C82, the new system BSOD’s on me, and it wont load the driver from the intel .inf file…but its working nonetheless. Ive tried about 20 different ways…so Im gunna leave it as-is for now. Its working…and far faster than my old set-up.
a little off topic - I also was able to get the on-board Intel 1Gbe Gigabit Network card to work…Intel Specifically states it is NOT supported on XP 32 bit. Yeah, right…how to make that work? Click on the device, “update driver” and Install one of last years 1Gbe Gigabit PCI-E driver and it will magically work…Intel has purposely inserted text and compiled the new drivers .sys and .exe files to detect XP 32 and force a non-install…THANK YOU NOT Intel and the rest of Mfgrs attempting to rail-road users off XP.
btw - I currently work on a SLUG of a Win 7 i5 8GB DDR3 ram station at work…its ****-Slow compared to my P4 2GB XP station at home…only reason im upgrading my P4 at home is the graphics card started failing, and I want a really good card, and a system to last…its 4 yrs old and im sure the MB or socket 775 processor will soon follow suit…
XP simply put, does EXACTLY what it needs to do…why the forcing people to “upgrade” to slower systems MS and Intel? Are you attempting to force people onto slower systems so you can then sell them faster and faster systems? Did we reach a pinnacle of speed on XP to where shear processing was no longer an issue?
At least I got my XP on a new system…and its Blazingly fast…hopefully my experience will help others…always think OutSide the BoX
