Hi everyone,
i have a motherboard H-JOSHUA-H61 with non 3XXX non K and working.
But i want to swith to i7 3770K and motherboard boot but print a message that this processor is not compatible.
Do you know if i upgrade with ubu the bios it will work ?
Thank’s in advance
i found this
0x5AE8B One Of: Limit CPUID Maximum, VarStoreInfo (VarOffset/VarName): 0x2E, VarStore: 0x1, QuestionId: 0x2B, Size: 1, Min: 0x0, Max 0x0, Step: 0x0 {05 A6 53 01 54 01 2B 00 01 00 2E 00 10 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00}
0x5AEB1 One Of Option: Disabled, Value (8 bit): 0x0 (default) {09 0E 5C 01 30 00 00 00 00 00 00 00 00 00}
0x5AEBF One Of Option: Enabled, Value (8 bit): 0x1 {09 0E 5B 01 00 00 01 00 00 00 00 00 00 00}
0x5AECD End One Of {29 02}
@yop038 I don’t think it might work,you could modded the option of the prompt(If had).Or you could only modded the bios with the disassemble software,and I think it might be hard for you.
