I shorted two pins and it’s not working. I tried it five times. I’ve de-blobed me region already, but i want to disable it in descriptor region too.
chipset → ALC255
ME 11.8
Read the Intel Management Engine section on the forum and Plutomaniac guides.
You’ll have to rebuild the ME FW image
EDIT: The HDA is one of the methods… as you already noticed it doesnt apply to all systems, has to much to do with hardware board design… and yours a laptop…
I’ve already done.
It’s a laptop and have realtek alc255 with me 11.8
- Shutdown the system completely (S5 power state)
- Locate the two HDA pins and start shorting them
- Keep shorting the pins and power on the system
- Once the BIOS/OS starts to load, stop shorting
- The Flash Descriptor should now be unlocked
Thats what i tried.
But it’s not working.
Regions are still locked.
Doesn’t hda work with laptop? I saw somewhere it does.
It does… can we say its valid for all laptop motherboards around… i wont bet on it so im not surprised.
EDIT: Not if following the guide, and i dont need no info… the methods on the guide works or not, to your system motherboard, period.
Am i doing something wrong? I can provide more info if needed.
Anyone can ask for it.
