Salute dear community,
I have tried very often to mod my BIOS and change information like the UUID or serial number.
But unfortunately my BIOS always resets after flashing, if it works at all.
I have already tried per:
AFUDOS with /GNA
INTEL ME (FPG or whatever it’s called)
MMTools
I’m really new to this topic.
However, I wanted to unpack my CH314A again and try it with it.
But before I build nonsense and break everything,
what do I have to consider with the BIOS file?
Is it enough if I just take the original .CAP and edit everything there?
or do I have to remove the encapsulation and then flash as ROM?
or do I have to use the trick with the extract and paste again?
As you can see I would be very grateful to you to answer some of my questions ![]()
Until further notice I wish every success in modding.
