[HELP] Auto execute "comand" on bios start
hi, i have one motherboard asrock h470 phantom gaming , and this have one bug , with more than 3 gpu this mother boot on bios , and I have to go to the exit part of the bios and go to Boot Override, so I was thinking of making this happen automatically by modifying the bios
i use AMIBCP and find Boot Override on exit , 0072 (is the handle)
@GabyGameryt - So, with only two GPU installed, it boots correctly to windows? If yes, with three GPU installed, reboot to BIOS, and make sure windows is first in the boot list, maybe that is being changed when you install the third GPU?
There is no way to do what you are asking about. Report this bug to Asrock, then they can look into it and fix, if it’s an actual BIOS bug.
yes with 2 gpu boot correct , with 3 or more , boot bios and me select boot override and boot correct
