Help Disable default Intel C State in MSI GF63 Thin 11SC-497IT
Hello forum members. This laptop has the problem that when you enable the CPU C states feature in the BIOS, it reboots while Windows is loading. It works perfectly on battery power only. By setting the CPU C states setting to disabled, it works perfectly even with AC power connected. I would like to disable CPU C states by default so that even when loading the BIOS defaults, this feature remains disabled. I tried AMIBCP, but the laptop won’t boot. I also tried uefitool, but that doesn’t help.
dump3.bin.zip (7.1 MB)
