Hello, i need to extract intel ME from a Insyde bios .fd file but i dont know where to look exactly, there are a bunch of tutorials but they made me even more confused with the amount of different methods/programs, i need the ME dump to change 2 things: remove the 0.50% downspread on ICC first and then if it works i will test a bclk overclock of 110mhz!
Ps: here’s the bios file https: //drive.google.com/file/d/1VojUSfDuNFK9Pr01_4Ga4wCl2w1hip6i/view?usp=sharing i couldn’t put a link 'cause the 3 post rule, also i’m messing with an old laptop so no worries about bricking the bios or hardware at all, the bios i can reflash easily!
No ME in file
Thanks for looking, so i guess not every bios update includes the ME part but i have a older version that saids it’s mainly for ME and MCU update https: //drive.google.com/file/d/16i7hRBM46ZgdFeu573uvBqlAThVLP3s5/view?usp=sharing
[Deleted]
it says invalid uefi volume ._. , could you post what is your system?
That’s weird Here’s a screenshot of hwinfo64…
That what it gave me.
Use UEFIToolNE
Cut the last padding, cut from the beginning of the file to 0x94D8F
Thanks!!! Will be working on that right away!
