I’m using an UEFI Bios on my P67A-UD3R-B3. Everything works fine so far. However 4 pin fans never work correctly.
I’ve even tried to disable PWM control setting in Bios. But they are either stop at 0rpm (CPU 4 pin fan), or crazily ran at full speed (System Fan 2.)
Good news is that I tried to flash P67X-UD3-B3’s UEFI Bios and 4 pin fans could work without any issue. I’m wondering if there is a way to replace P67A-UD3R-B3’s PWM control module from P67X-UD3-B3’s one? Or any other solution to fix the UEFI?
I’m appreciative of your helps!
GA-P67A-UD3R-B3 - U1b
GA-P67X-UD3-B3 - U1b
MMTool report about P67A-UD3R-B3 - U1b:
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
+-----------------------------------------------------------------------------+| MMTOOL 4.50.0023 |
| Copyright (c)2010 American Megatrends, Inc. |
| Firmware Image Information |
| Image Size : 400000 |
| FV | FV TYPE | Location | Length | FFSs |
| 00 | Non-FFS FV | 00180000 | 020000 | 001 |
| 01 | Non-FFS FV | 001C0000 | 1A0000 | 003 |
| 02 | Nested FV | 00000000 | 5ED000 | 174 |
| 03 | Boot Block FV | 00360000 | 0A0000 | 043 |
| Nested Firmware Volume Information |
| FV | Nesting Information | Length | FFSs |
| 02 | Parent Fv : 01 Parent FFS : 00 | 5ED000 | 174 |
| NCB Information |
| NCB No : 0 Location : 00000000 Length : 180000 |
| NCB No : 1 Location : 001A0000 Length : 020000 |
| Driver Information |
| Firmware Volume : 00 Location : 00180000 Length : 020000 |
|NO | FileName | GUID |Location| Size |Type|
|000| |CEF5B9A3-476D-497F-9FDC-E98143E0422C|00180048|01FFB8|RAW |
| Bytes Free : 000000 ( 0 KB) Bytes Used : 020000 (128 KB) |
| Firmware Volume : 01 Location : 001C0000 Length : 1A0000 |
|000| |AE717C2F-1A42-4F2B-8861-78B79CA07E07|001C0048|172EA3|FV |
|001| |17088572-377F-44EF-8F4E-B09FFF46A070|00332F08|020818|RAW |
|002|S3Restore |EFD652CC-0E99-40F0-96C0-E08C089070FC|00353720|0025BC|PEIM|
| Bytes Free : 00A338 ( 40 KB) Bytes Used : 195CC8 (1623 KB) |
| Firmware Volume : 02 Location : 00000000 Length : 5ED000 |
|000|IntelSaGopDriver|5C266089-E103-4D43-9AB5-12D7095BE2AF|00000048|001335|DRVR|
|001|IntelIvbGopDriv|5BBA83E6-F027-4CA7-BFD0-16358CC9E123|0000137D|00B224|DRVR|
|002|IntelSnbGopDriv|8D59EBC8-B85E-400E-970A-1F995D1DB91E|0000C5A1|00AE64|DRVR|
|003| |17088572-377F-44EF-8F4E-B09FFF46A070|00017405|020818|RAW |
|004|CpuDxe |E03ABADF-E536-4E88-B3A0-B77F78EB34FE|00037C1D|0034A1|DRVR|
|005|FileSystem |93022F8C-1F09-47EF-BBB2-5814FF609DF5|0003B0BE|007EA1|DRVR|
|006| |DAC2B117-B5FB-4964-A312-0DCC77061B9B|00042F5F|0090F9|FRFM|
|007| |9221315B-30BB-46B5-813E-1B1BF4712BD3|0004C058|0006B9|FRFM|
|008|CORE_DXE |5AE3F37E-4EAE-41AE-8240-35465B5E81EB|0004C711|175881|DXEC|
|009|Runtime |CBC59C4A-383A-41EB-A8EE-4498AEA567E4|001C1F92|012C01|DRVR|
|010|ReFlash |70E1A818-0BE1-4449-BFD4-9EF68C7F02A8|001D4B93|0032B5|DRVR|
|011|PciBus |3C1DE39F-D207-408A-AACC-731CFB7F1DD7|001D7E48|00E079|DRVR|
|012|AmiBoardInfo |9F3A0016-AE55-4288-829D-D22FD344C347|001E5EC1|00A769|DRVR|
|013|EBC |13AC6DD0-73D0-11D4-B06B-00AA00BD6DE7|001F062A|0037D9|DRVR|
|014|It8728SmmFeatur|078485F1-0C1F-4B1B-AFB3-4A09C0EF87A1|001F3E03|0022E9|DRVR|
|015|IT8728SioAcBack|AA893E19-A641-4819-AD23-011B7C24250D|001F60EC|0013AD|DRVR|
|016|CpuInitDxe |62D171CB-78CD-4480-8678-C6A2A797A8DE|001F7499|00E4A1|DRVR|
|017|SmmRelocDxe |7FED72EE-0170-4814-9878-A8FB1864DFAF|0020593A|000F69|DRVR|
|018|SmmRelocPeim |ABB74F50-FD2D-4072-A321-CAFC72977EFA|002068A3|000BAD|PEIM|
|019|SmmBaseRuntime |5552575A-7E00-4D61-A3A4-F7547351B49E|00207450|004F6D|DRVR|
|020|SmmDisp |9CC55D7D-FBFF-431C-BC14-334EAEA6052B|0020C3BD|0056C1|DRVR|
|021|SmmThunk |8D3BE215-D6F6-4264-BEA6-28073FB13AEA|00211A7E|000CD5|DRVR|
|022|CpuPolicyDxe |15B9B6DA-00A9-4DE7-B8E8-ED7AFB88F16E|00212753|00158D|DRVR|
|023|MicrocodeUpdate|F3331DE6-4A55-44E4-B767-7453F7A1A021|00213CE0|005B01|DRVR|
|024|CpuSmmSaveRes |326E7ACE-2133-1BA2-800A-B9C00ACCB17D|002197E1|001DAD|DRVR|
|025|CpuSpSMI |116E1ACF-2533-4CC2-820A-BBC10A2AB07C|0021B58E|001595|DRVR|
|026|SBDXE |B7D19491-E55A-470D-8508-85A5DFA41974|0021CB23|008235|DRVR|
|027|SBRun |E23F86E1-056E-4888-B685-CFCD67C179D4|00224D58|00299D|DRVR|
|028| |22046D50-F390-498C-92E5-5BA4F8E7F8B6|002276F5|00020E|FRFM|
|029|SmmChildDispatc|753630C9-FAE5-47A9-BBBF-88D621CD7282|00227903|0032C9|DRVR|
|030|SmmChildDispatc|E53734A3-E594-4C25-B1A2-081445650F7F|0022ABCC|004929|DRVR|
|031| |750890A6-7ACF-4F4F-81BD-B400C2BEA95A|0022F4F5|002851| |
|032|SleepSmi |6298FE18-D5EF-42B7-BB0C-2953283F5704|00231D46|0026D5|DRVR|
|033|SBSMI |7B8DB049-C7C7-4D3B-809F-926DEE47CCA2|0023441B|0032B1|DRVR|
|034|PchSpiWrap |B716A6F8-F3A1-4B8E-8582-5A303F1CDD64|002376CC|000E29|DRVR|
|035|WdtAppDxe |CE366D33-B057-4C03-8561-CAF17738B66F|002384F5|0012F5|DRVR|
|036|SataDriver |91B4D9C1-141C-4824-8D02-3C298E36EB3F|002397EA|02DDF9|DRVR|
|037|ActiveBios |BFD59D42-FE0F-4251-B772-4B098A1AEC85|002675E3|000909|DRVR|
|038|IoTrap |2374EDDF-F203-4FC0-A20E-61BAD73089D6|00267EEC|0017E1|DRVR|
|039|IntelLegacyInte|C1C418F9-591D-461C-82A2-B9CD96DFEA86|002696CD|000515|DRVR|
|040|PchInitDxe |DE23ACEE-CF55-4FB6-AA77-984AB53DE823|00269BE2|00BB2D|DRVR|
|041|PchSmiDispatcher|B0D6ED53-B844-43F5-BD2F-61095264E77E|0027570F|005E55|DRVR|
|042|PchPcieSmm |ACAEAA7A-C039-4424-88DA-F42212EA0E55|0027B564|002681|DRVR|
|043|PchReset |BB1FBD4F-2E30-4793-9BED-74F672BC8FFE|0027DBE5|001785|DRVR|
|044|PchS3Peim |271DD6F2-54CB-45E6-8585-8C923C1AC706|0027F36A|0016DC|PEIM|
|045|PchS3Support |08F2C63B-08DE-4CCD-8670-ACFE644A1C48|00280A46|000D45|DRVR|
|046|SataController |BB65942B-521F-4EC3-BAF9-A92540CF60D2|0028178B|001A29|DRVR|
|047|PchSerialGpio |FC1B7640-3466-4C06-B1CC-1C935394B5C2|002831B4|000DED|DRVR|
|048|SmartTimer |90CB75DB-71FC-489D-AACF-943477EC7212|00283FA1|000909|DRVR|
|049|PchSmbusDxe |E052D8A6-224A-4C32-8D37-2E0AE162364D|002848AA|001A19|DRVR|
|050|SmmControl |A0BAD9F7-AB78-491B-B583-C52B7F84B9E0|002862C3|000C29|DRVR|
|051|PchSpiSmm |27F4917B-A707-4AAD-9676-26DF168CBF0D|00286EEC|0025E5|DRVR|
|052|PchSpiRuntime |C194C6EA-B68C-4981-B64B-9BD271474B20|002894D1|002E8D|DRVR|
|053|PchSmbusSmm |59287178-59B2-49CA-BC63-532B12EA2C53|0028C35E|001459|DRVR|
|054|WdtDxe |5AAB83E5-F027-4CA7-BFD0-16358CC9E453|0028D7B7|000BE1|DRVR|
|055|NBDXE |E4ECD0B2-E277-4F2B-BECB-E4D75C9A812E|0028E398|005701|DRVR|
|056|NBSMI |D933DEDE-0260-4E76-A7D9-2F9F2440E5A5|00293A99|001DFD|DRVR|
|057|MiscSubclassDxe|16271FCA-55D9-4A33-93FC-5A3EB128DE21|00295896|001125|DRVR|
|058|UpdateMemoryRec|24CCD374-3DF6-4181-86F6-E3C66920A145|002969BB|001BF5|DRVR|
|059|LegacyRegion2 |FE6F8ACD-55A6-4C6B-B448-64E659DE94B3|002985B0|000D9D|DRVR|
|060|PciExpressDxe |A89EC8E0-0BA1-40AA-A03E-ABDDA5295CDE|0029934D|002BA1|DRVR|
|061|PciHostBridge |8D6756B9-E55E-4D6A-A3A5-5E4D72DDF772|0029BEEE|002AED|DRVR|
|062|SmBiosMemory |EDA39402-F375-4496-92D3-83B43CB8A76A|0029E9DB|002A75|DRVR|
|063|SmmAccess |1323C7F8-DAD5-4126-A54B-7A05FBF41515|002A1450|000D55|DRVR|
|064| |27E569D5-0AFC-4D8F-8C90-783AC4A318AB|002A21A5|00009F|FRFM|
|065|SaInitDxe |DE23ACEE-CF55-4FB6-AA77-984AB53DE811|002A2244|0060F5|DRVR|
|066|BdatAccessHandl|6DB9486F-6AF6-4090-984D-238482CE3EA4|002A8339|0008E9|DRVR|
|067|SaLateInitSmm |2D1E361C-7B3F-4D15-8B1F-66E551FABDC7|002A8C22|003C01|DRVR|
|068| |878AC2CC-5343-46F2-B563-51F89DAF56BA|002AC823|001184|RAW |
|069| |0F729F33-25C1-41A7-86B2-23A737A91823|002AD9A7|0010D1|RAW |
|070|PciTestAdapter |3F79BEE2-6B14-4B5E-916B-101D8F7E15BE|002AEA78|001211|DRVR|
|071|OnboardControll|1601E050-BE0C-41B7-8F96-9F48F72B7E26|002AFC89|001CFD|DRVR|
|072|RtkUndiDxe |2851E234-20FD-4D1E-9041-DCB8F3025CAE|002B1986|0161D1|DRVR|
|073|ACPI |16D0A23E-C09C-407D-A14A-AD058FDD0CA1|002C7B57|00984D|DRVR|
|074| |26A2481E-4424-46A2-9943-CC4039EAD8F8|002D13A4|003229| |
|075|S3Restore |EFD652CC-0E99-40F0-96C0-E08C089070FC|002D45CD|0025BC|PEIM|
|076|CryptoDxe |20D8FFFE-15C3-4EA9-9D28-CFE2745D78F3|002D6B89|0111B5|DRVR|
|077| |842A454A-75E5-408B-8B1C-36420E4E3F21|002E7D3E|0021AD| |
|078|AHCI |8F5A2E02-538C-4D59-B920-C4786ACBC552|002E9EEB|006915|DRVR|
|079|AINT13 |67820532-7613-4DD3-9ED7-3D9BE3A7DA63|002F0800|001C31|DRVR|
|080|AhciSmm |BC3245BD-B982-4F55-9F79-056AD7E987C5|002F2431|002951|DRVR|
|081|BDRDXE |5E06E249-3A4C-49B5-8A37-02058CC12691|002F4D82|0043D1|DRVR|
|082|BDRSMM |ACA87EA5-D839-4F41-BCCE-9E19E9F2C2AD|002F9153|004555|DRVR|
|083|DualBiosDxe |C74D1B0B-91B1-484A-A038-FE7A0847AA07|002FD6A8|005AC9|DRVR|
|084|DualBiosSMM |88B468B3-A48B-4B87-ABE2-8E56DFFDAF8D|00303171|0002DD|DRVR|
|085|KbcEmul |3B24F79D-91A0-46FF-BE29-458AE211FAC5|0030344E|0040F5|DRVR|
|086|CSMCORE |A062CF1F-8473-4AA3-8793-600BC4FFE9A8|00307543|05E931|DRVR|
|087| |A08276EC-A0FE-4E06-8670-385336C7D093|00365E74|000421|FRFM|
|088|BIOSBLKIO |25ACF158-DD61-4E64-9A49-55851E9A26C7|00366295|003395|DRVR|
|089|CsmVideo |29CF55F8-B675-4F5D-8F2F-B87A3ECFD063|0036962A|004415|DRVR|
|090| |60AC3A8F-4D66-4CD4-895A-C3F06E6665EE|0036DA3F|0000D6|FRFM|
|091|iFfsDxe |B6B9295F-CABF-4CEC-BB14-FE4246F2173A|0036DB15|001C89|DRVR|
|092|iFfsSmm |43172851-CF7E-4345-9FE0-D7012BB17B88|0036F79E|001A05|DRVR|
|093|iFfsDxePolicyIn|DDB412A6-E3F3-4E9E-90A3-2A991270219C|003711A3|001035|DRVR|
|094|HeciDxe |55E76644-78A5-4A82-A900-7126A5798892|003721D8|002FC1|DRVR|
|095|HeciSmm |921CD783-3E22-4579-A71F-00D74197FCC8|00375199|001AD5|DRVR|
|096|PlatformReset |9A9A912B-5F53-4586-8820-704485A29D21|00376C6E|000DFD|DRVR|
|097|MdesStatusCodeD|DF5CD25A-8E55-46BA-8CDA-BC7DB7BF9C64|00377A6B|000C85|DRVR|
|098|MePlatformPolicy|BA67550C-3628-4137-A53E-42660E081604|003786F0|00148D|DRVR|
|099|MePciPlatform |459C70C3-9344-4484-9F93-7822530D0D11|00379B7D|0007CD|DRVR|
|100|IccPlatform |14257B56-BDA2-4FAF-8E4F-C885DF75583C|0037A34A|00176D|DRVR|
|101|IccOverClocking|5BBA83E5-F027-4CA7-BFD0-16358CC9E123|0037BAB7|0049D1|DRVR|
|102|Smbios131 |2B341C7B-0B32-4A65-9D46-E1B3ABD4C25C|00380488|000EE5|DRVR|
|103|MERecoveryDxe |F1FCD66F-8966-441E-909C-77F211AB9C3E|0038136D|0042AD|DRVR|
|104| |821D110C-D0A3-4CF7-AEF3-E28088491704|0038561A|040025|FRFM|
|105|MouseDriver |2ADB8F5B-C7D4-4E7E-BE2A-23634DF668A1|003C563F|003989|DRVR|
|106| |76D5CF91-0C55-434E-97C2-D2825C82E610|003C8FC8|001D65| |
|107|AcpiPlatform |8B5FBABD-F51F-4942-BF16-16AAA38AE52B|003CAD2D|003141|DRVR|
|108|AcpiPlatformSmi|DFD8D5CC-5AED-4820-A2B6-5C55E4E640EF|003CDE6E|001A71|DRVR|
|109|PlatformInfo |1314216C-CB8D-421C-B854-06231386E642|003CF8DF|000FED|DRVR|
|110|SMBIOSUpdateData|B98999A4-E96F-475A-99FC-762126F50F5A|003D08CC|000AA5|DRVR|
|111| |FB045DB2-598E-485A-BA30-5D7B1B1BD54D|003D1371|0001A7|FRFM|
|112|OFBD |57E56594-CE95-46AD-9531-3C49310CA7CE|003D1518|001411|DRVR|
|113|PowerManagement|8C783970-F02A-4A4D-AF09-8797A51EEC8D|003D2929|004D1D|DRVR|
|114| |299141BB-211A-48A5-92C0-6F9A0A3A006E|003D7646|000937|FRFM|
|115|AmiPpmPolicy |1CE12314-AFBC-11F0-8A3E-AB44B8EE3120|003D7F7D|00195D|DRVR|
|116|QFlash |132EC73B-3025-4FBF-B193-8ACB50EFBD89|003D98DA|007D59|DRVR|
|117|EzFileBrowser |56B70419-7103-4D0E-83F4-F3546BD21E40|003E1633|00400D|DRVR|
|118|SecureBootMod |A95C1D60-CB9F-4BD8-A030-3F1C4A185156|003E5640|00177D|DRVR|
|119| |FBF95065-427F-47B3-8077-D13C60710998|003E6DBD|001159|FRFM|
|120| |9D7A05E9-F740-44C3-858B-75586A8F9C8E|003E7F16|00064D|FRFM|
|121|SecFlashUpdDxe |A0EF80E3-F9AB-4CBA-98FD-704620F4048D|003E8563|0011C1|DRVR|
|122|CmosManagerSmm |6869C5B3-AC8D-4973-8B37-E354DBF34ADD|003E9724|003A21|DRVR|
|123|GenericComponen|199FD111-0785-4132-A9B3-1F66573F0060|003ED145|0239DD|DRVR|
|124|SMBiosBoard |CEF68C66-06AB-4FB3-A3ED-5FFA885B5725|00410B22|001A09|DRVR|
|125|SMBios64 |B13EDD38-684C-41ED-A305-D7B7E32497DF|0041252B|006349|DRVR|
|126|SmbiosGetFlashD|DED7956D-7E20-4F20-91A1-190439B04D5B|00418874|000F0D|DRVR|
|127| |DAF4BF89-CE71-4917-B522-C89D32FBC59F|00419781|00199D|FRFM|
|128|SmbiosDMIEdit |E2A74738-8934-48F5-8412-99E948C8DC1B|0041B11E|003805|DRVR|
|129|SMIFlash |BC327DBD-B982-4F55-9F79-056AD7E987C5|0041E923|005C99|DRVR|
|130|SmiVariable |BE216BA8-38C4-4535-A6CA-5DCA5B43ADDF|004245BC|001D49|DRVR|
|131|AMITSE |B1DA0ADF-4F77-4070-A88E-BFFE1C60529A|00426305|076225|DRVR|
|132| |A59A0056-3341-44B5-9C9C-6D76F7673817|0049C52A|0000A8|FRFM|
|133| |294B1CEF-9BEB-42D5-9971-0C8963CDAF02|0049C5D2|004EBD|FRFM|
|134| |EFCB2FDB-0662-4A59-A5D7-03033EA97CAE|004A148F|0104C9|FRFM|
|135|SmmRuntime |A56897A1-A77F-4600-84DB-22B0A801FA9A|004B1958|001479|DRVR|
|136|DpcDxe |399CF3A7-82C7-4D9B-9123-DB11842986D3|004B2DD1|0008B9|DRVR|
|137|ArpDxe |8DD91798-EE87-4F0E-8A84-3F998311F930|004B368A|002F59|DRVR|
|138|SnpDxe |3DD7A87B-D5BD-44AF-986F-2E13DB5D274C|004B65E3|0037F9|DRVR|
|139|MnpDxe |C30B94E3-C8F2-4AB0-91AB-FA8DF621B1C9|004B9DDC|004B59|DRVR|
|140|UefiPxeBcDxe |0EF8A3B1-388A-4B62-8BE6-C7877D50AEDF|004BE935|00D025|DRVR|
|141|NetworkStackSet|0029DE6A-E024-4EB8-A91D-9F23AA1F4E92|004CB95A|000BF9|DRVR|
|142|TcpDxe |B1625D3C-9D2D-4E0D-B864-8A763EE4EC50|004CC553|00BB59|DRVR|
|143|Dhcp4Dxe |8DD9176E-EE87-4F0E-8A84-3F998311F930|004D80AC|006F1D|DRVR|
|144|Ip4ConfigDxe |8F9296EF-2880-4659-B857-915A8901BDC8|004DEFC9|0047C5|DRVR|
|145|Ip4Dxe |8F92960F-2880-4659-B857-915A8901BDC8|004E378E|008BD9|DRVR|
|146|Mtftp4Dxe |61AFA223-8AC8-4440-9AB5-762B1BF05156|004EC367|0056BD|DRVR|
|147|Udp4Dxe |10EE5462-B207-4A4F-ABD8-CB522ECAA3A4|004F1A24|005719|DRVR|
|148|Dhcp6Dxe |8DD9176D-EE87-4F0E-8A84-3F998311F930|004F713D|00689D|DRVR|
|149|Ip6Dxe |8F92960E-2880-4659-B857-915A8901BDC8|004FD9DA|010459|DRVR|
|150|Mtftp6Dxe |61AFA251-8AC8-4440-9AB5-762B1BF05156|0050DE33|00565D|DRVR|
|151|Udp6Dxe |10EE54AE-B207-4A4F-ABD8-CB522ECAA3A4|00513490|0053D9|DRVR|
|152|GbtCustomizeBut|4DCBF9BA-DEC1-42B0-8A09-01555694F6CF|00518869|0013AD|DRVR|
|153|RTCWakeup |534A6A34-CF78-4A56-BEDB-CB49A8D8060C|00519C16|001739|DRVR|
|154|UHCD |580DD900-385D-11D7-883A-00500473D4EB|0051B34F|00D711|DRVR|
|155| |04EAAAA1-29A1-11D7-8838-00500473D4EB|00528A60|0146C1| |
|156|USBINT13 |4C006CD9-19BA-4617-8483-609194A1ACFC|0053D121|001A25|DRVR|
|157|x1x4Switch |629FA771-C081-560A-A599-1986011859E0|0053EB46|0013E9|DRVR|
|158|OnoffchargeDXE |51071023-7C6C-4DE8-A109-29F5DF3A3F88|0053FF2F|000FC5|DRVR|
|159|OnoffchargeSMM |1555ACF3-BD07-1458-B668-A8694567890A|00540EF4|001AC5|DRVR|
|160|SmartFanCtrlDXE|D8AAB432-93CC-48D2-9F34-3496CAF92185|005429B9|001921|DRVR|
|161|OemLOGO |7D1686A9-1EE3-446C-825C-5A26F449CE52|005442DA|001061|DRVR|
|162|MyOemLogo1 |86EE84E1-3375-41A1-AFBA-847BD29663AA|0054533B|000A98|FRFM|
|163|MyOemLogo2 |86EE84E2-3375-41A1-AFBA-847BD29663AA|00545DD3|00011B|FRFM|
|164| |0A602C5B-05A0-40C4-9181-EDCD891D0022|00545EEE|002F3D|FRFM|
|165| |0A602C5B-05A0-40C4-9181-EDCD891D0023|00548E2B|002F3D|FRFM|
|166| |0A602C5B-05A0-40C4-9181-EDCD891D0020|0054BD68|002F3D|FRFM|
|167| |0A602C5B-05A0-40C4-9181-EDCD891D0021|0054ECA5|002F3D|FRFM|
|168|OEMDXE |BFE205C9-5B17-4F8F-9375-89614AF8E199|00551BE2|000E55|DRVR|
|169|Setup |899407D7-99FE-43D8-9A21-79EC328CAC21|00552A37|052059|DRVR|
|170| |7BB28B99-61BB-11D5-9A5D-0090273FC14D|005A4A90|044C8D|FRFM|
|171|CRBDXE |16271FCA-55D9-4A33-93FC-5A3EB128DEB6|005E971D|000C91|DRVR|
|172|CRBSMI |221F1D4F-034C-4BEA-B2BB-B7A9672B06D7|005EA3AE|0013A1|DRVR|
|173|CspLibDxe |CD84562C-6864-40A3-A081-C8D35E82B920|005EB74F|000275|DRVR|
| Bytes Free : 00163C ( 5 KB) Bytes Used : 5EB9C4 (6062 KB) |
| Firmware Volume : 03 Location : 00360000 Length : 0A0000 |
|000|MemoryInit |3B42EF57-16D3-44CB-8632-9FDB06B41451|00360048|02C832|PEIM|
|001|UsbBotPeim |8401A046-6F70-4505-8471-7015B40355E3|0038C880|001968|PEIM|
|002|Recovery |E008B434-0E73-440C-8612-A143F6A07BCB|0038E1E8|003D93|PEIM|
|003|CRBPEI |0D1ED2F7-E92B-4562-92DD-5C82EC917EAE|00391F80|00097A|PEIM|
|004|WdtPei |1D88C542-9DF7-424A-AA90-02B61F286938|00392900|000796|PEIM|
|005|CORE_PEI |92685943-D810-47FF-A112-CC8490776A1F|00393098|023DB2|PEIC|
|006|IT8728SioAcBack|F5042177-1D29-45C5-BA4D-4D0EB2E88575|003B6E50|0002A0|PEIM|
|007|CpuInitPei |01359D99-9446-456D-ADA4-50A711C03ADA|003B70F0|001C4E|PEIM|
|008|CpuS3Peim |C866BD71-7C79-4BF1-A93B-066B830D8F9A|003B8D40|001590|PEIM|
|009|SmmBasePeim |8B8214F9-4ADB-47DD-AC62-8313C537E9FA|003BA2D0|000560|PEIM|
|010|CpuPolicyPei |0AC2D35D-1C77-1033-A6F8-7CA55DF7D0AA|003BA830|000762|PEIM|
|011|CpuPeiBeforeMem|1555ACF3-BD07-4685-B668-A86945A4124D|003BAF98|0006E0|PEIM|
|012|CpuPei |2BB5AFA9-FF33-417B-8497-CB773C2B93BF|003BB678|00160E|PEIM|
|013|SBPEI |C1FBD624-27EA-40D1-AA48-94C3DC5C7E0D|003BCC88|003C78|PEIM|
|014|AcpiPlatformPei|333BB2A3-4F20-4C8B-AC38-0672D74315F8|003C0900|00087C|PEIM|
|015|SmBusPei |9EA28D33-0175-4788-BEA8-6950516030A5|003C1180|0013CA|PEIM|
|016|WdtAppPei |0F69F6D7-0E4B-43A6-BFC2-6871694369B0|003C2550|00052C|PEIM|
|017|PchInitPeim |FD236AE7-0791-48C4-B29E-29BDEEE1A838|003C2A80|003960|PEIM|
|018|PchResetPeim |FF259F16-18D1-4298-8DD2-BD87FF2894A9|003C63E0|000962|PEIM|
|019|PchSmbusArpDisa|643DF777-F312-42ED-81CC-1B1F57E18AD6|003C6D48|000BA0|PEIM|
|020|PchSpiPeim |AA652CB9-2D52-4624-9FAE-D4E58B67CA46|003C78E8|0015BE|PEIM|
|021|PchUsb |6B4FDBD2-47E1-4A09-BA8E-8E041F208B95|003C8EA8|00036E|PEIM|
|022|NBPEI |79AA6086-035A-4AD9-A89A-A6D5AA27F0E2|003C9218|0028B8|PEIM|
|023|SmmAccessPeim |6ECFCE51-5724-450C-A38A-58553E954422|003CBAD0|000884|PEIM|
|024|SaInitPeim |FD236AE7-0791-48C4-B29E-29BDEEE1A811|003CC358|005036|PEIM|
|025|CryptoPei |D6D2FBA6-EF60-4C38-A83E-6769814D23B0|003D1390|002AC1|PEIM|
|026|BDRPEI |90E9D266-C229-4474-8D18-AAF3745F3EAA|003D3E58|000546|PEIM|
|027| |56E14F88-234B-4C34-B204-299670447247|003D43A0|00046C|FRFM|
|028|DualBiosPei |97BB442B-F9FE-45E3-8A28-439EEDCD1813|003D4810|000420|PEIM|
|029|Capsule |FAC2EFAD-8511-4E34-9CAE-16A257BA9488|003D4C30|000998|PEIM|
|030|iFfsPei |53F019E9-BB0C-424B-870A-1FAF10B1CB4C|003D55C8|004170|PEIM|
|031|HeciPei |9CF30325-DC5C-4556-A8B0-74215C5F7FC4|003D9738|000C18|PEIM|
|032|PchMeUma |8C376010-2400-4D7D-B47B-9D851DF3C9D1|003DA350|00080E|PEIM|
|033|MePeiPolicyInit|12C67BE1-AD2E-4F13-A95F-6EDC2C4392DE|003DAB60|000538|PEIM|
|034|PeiRamBoot |08EFD15D-EC55-4023-B648-7BA40DF7D05D|003DB098|001082|PEIM|
|035| |CC0F8A3F-3DEA-4376-9679-5426BA0A907E|003DC120|000489|FRFM|
|036| |9FE7DE69-0AEA-470A-B50A-139813649189|003DC5B0|00092C|FRFM|
|037| |5B85965C-455D-4CC6-9C4C-7F086967D2B0|003DCEE0|00003C|FRFM|
|038|FwCapsuleRecove|83FA5AED-5171-4949-BDC9-0CBC9E123663|003DCF20|002325|PEIM|
|039| |FD44820B-F1AB-41C0-AE4E-0C55556EB9BD|003DF248|000828|FRFM|
|040| |0DCA793A-EA96-42D8-BD7B-DC7F684E38C1|003DFA70|0000A4|FRFM|
|041| |3FD1D3A2-99F7-420B-BC69-8BB1D492A332|003DFB18|0000A4|FRFM|
|042| |1BA0062E-C779-4582-8566-336AE8F78F09|003FF220|000DE0|SECC|
| Bytes Free : 01F660 (125 KB) Bytes Used : 0809A0 (514 KB) |
| Total Bytes Free : 029998 ( 166 KB) Total Bytes Used : 3D6668 (3929 KB) |
