I dumped and modified my bios using AfuWin64/AMIBCP but when i try to flash it back, i get secure flash verify fail. This is AMD platform so FPT won’t work.
Any suggestions/ideas?
1
2
3
4
5
6
7
8
Reading flash ............... done
Secure Flash enabled, recalculate ROM size with signature... Enable.
- FFS checksums ......... ok
- Check RomLayout ........ ok.
Loading capsule to secure memory buffer ... done
18 - Error: Secure Flash Rom Verify fail.
OEM bios can be downloaded from here:
http://motilecustomerservice.com/m142.html
@jmandawg - Use this method, only pay attention to the last spoiler, and download the tools attached so you have that AFU version
https://linustechtips.com/main/topic/592…r-motherboards/
Thanks for the suggestion, Unfortunately that version of AFU won’t work with my laptop:
1
2
3
4
5
6
7
8
s>AFUWINx64.EXE PF4PU1FN106.ROM
| AMI Firmware Update Utility v5.05.04 |
| Copyright (C)2013 American Megatrends Inc. All Rights Reserved. |
46 - Error: Problem getting flash information.
That’s odd, it should work for that BIOS I checked BIOS type and version etc before I sent you the link.
There is another AFU that will work, but can cause issues later, and or brick the device right when you flash it, so I suggest against trying that, but if you want the AFU and info I will give to you.
If I do give you this file and method, you will need to make backup with this AFU First and then redo your modifications, then flash it back.
I suggest instead, you purchase a CH341A + SOIC8 test clip with cable and wait till they arrive, it’s less than $7 total on ebay.
I can help you unlock BIOS, if AMIBCP doesn’t do what you wanted, once you find flash/programming solution
