I need to undervolt my gpu radeon rx 540 (hp version) but it’s locked by manufacturer and I try to get the BIOS of the card and use ‘‘more power tool’’ to undervolt it but I can’t find the bios version of this gpu online and I can’t extract it. I would appreciate it if someone has my BIOS version or help me find one on the internet! I’m using Radeon ID driver.
Probably because it’s an embedded vbios on main system SPI IC and code, with shared bus of a laptop/cheap desktop board HP system with GPU soldered… and not a discrete GPU with its own vBios IC…
But all this is because the forum can’t “Guess” that “HP system” info from such user posts…when not provided.
And if so, the chances of achieving the desired “mods” are almost impossible.
