Help, i bricked my sp-neo10 laptop
I was changing setup values and for no reason i tried to disable the integrated gpu, it disabled it but now i cannot enable it back, because the screen doesn’t turns on. The laptop doesn’t have cmos battery and removing the internal battery doesn’t work .I have a dump of the bios, that contains a nvram section, but idk what to touch. I’ve seen a post here about the same for a Insyde Bios
Try one of the attached files, biosatom2 has empty NVRAM, biosatom3 has (probably) just reverted the last change.
I assume you have a programmer and the backup/dump is made after changing this setting. If that’s not the case forget about biosatom3.
[deleted]
