[HELP] Macronix 25U12873F Programming
Hi,
i´ve got a Macronix 25U12873F BIOS Chip that i wan´t to reprogramming. The problem what i have is that i can´t find any programmer software that support this chip. This chip is sitting on an ASUS GL702ZC Mainboard. Can anybody help me?
SPI programmer from South pole or North pole model… software for a washing machine version %$W#^$^&$^%$@^#^&E
Too much detailed information provided… most users will be confused and recommend u to change the spare tyre of the the running toaster, as its running too fast!
Just a quick note, the SPI uses 220v…
https://www.macronix.com/Lists/Datasheet…8Mb,%20v1.2.pdf
I cant recommend a software as the list witch supports SPI was too long…so good luck.
