Hi all. I was trying to mod the bios of my asus laptop. But it ended up bricked. I bought a SPI flash programmer, the ch341a, and tried some repairing.
I got some dumps and the original firmware from the manufacturer site. The model is ASUS f550cc.
You can try the attached file. Please compare the written file in a separate read, best with another program, and compare the files byte for byte. Clear the CMOS.
[edit: file deleted since no information if it was used/ did work]
I’m sorry, i tried flashing it but the chip didn’t work. It gave different readings every time. I was discouraged and forgot all about that. Now i got the opportunity to buy two other chips. I can try with these, if you still want may i use your file? Thanks anyway!
