Hi, I am trying to adjusting voltage options in BIOS to solve the problem of bsod caused by my low default voltage, I also want to disable c-state to solve some strange problems
The MSI H310M don’t have any option of the voltage or CPU core setting, also does not have the msi OC settings. Basically no oc menu show up, no option to change. You can refer to the picture below.
I tried to change some setting to UESR using AMIBCP, but it still does not show up after flashing in BIOS. I don’t know what I did wrong.
I think this is because these options are in the OC SETTING menu, but the stock bios hides the oc menu, even if I modify it will not help
Anyone can help me unlock voltage offset and c-state setting? This is my bios link http://s000.tinyupload.com/index.php?fil…187125935686389
Is there any way to add oc menu settings?
Thanks for the help!
