Been having problems with my RAID functionality. Would like to try updating my OROM to see if that helps, or if I’m on the wrong track maybe some one could point me in the right direction. I am using intel C600 series OROM 3.5.0.1005. Intel RSTe is always showing that my drive on controller 0, port 0 is failing. I’ve changed drives and still the same problem. Newest version of IRSTe v3.6 is being used. I was guessing I could try updating the OROM to see if that would fix the issue. Im using the newest Asus Bios v4502. Any help would be appreciated, thanks. If theres anything I can add to help with getting this solved please ask.
@ Trumpz:
Welcome at Win-RAID Forum!
If the latest BIOS for your ASUS X79 Sabertooth doesn’t contain the newest Intel RSTe RAID ROM v3.8.0.1029, I recommend to update the current Intel RSTe RAID ROM module.
After having flashed the updated BIOS, you should install the appropriate Intel RSTe drivers v3.8.1.1006 WHQL.
Regards
Fernando
